xbox 360 smd cap fault
  • risting
    • Jun 2015
    • 32
    • macedonia
    i installed JR Programmer v2 to jasper motherboard i think on correct points i connected power cable only no run! on jrunner Im getting the error: Flash Config: 0x00000000 Can not Continue now i see burning smoke on 2 smd capacitors on point C3B8 and C1D7 i don't know why motherboard demaged before motherboard working very well how to fix that ? pls help me
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: xbox 360 smd cap fault
    Just remove the two capacitors. Ceramics go short a lot of times for no reason.
    A working TV? How boring!
    • risting
      • Jun 2015
      • 32
      • macedonia
      Before install rgh chip console works well after rgh no run i lost red light on rgh chip ind blocked my adapter to red light, i remove smd cap on point C1D7 and again console run i desolder all wires but if replace new capacitor again burn and again no works this cap block one mosfet on motherboard if again remove this cap and solder rgh wires console again run well but give me error E76 sometime E75 when press eject buton i have hell reloaded cpu key and dvd key with out this cap console work but now error i see on internet this E76 is network isc chip if isc is dead is reason to burn this smd cap ? this is very starnge before isc chip no have this error E76 rgh console run to xbox live without this smd cap if ics demage voltage is high on this capacitor C3B8 and C1D7 i buy this ICS 1893BFLF on ebay i will try to reflow this chip sry for my bad english
      • risting
        • Jun 2015
        • 32
        • macedonia
        if install new capacitor i have short to ground on one mosfet and smd caps i don't know what is wrong with this xbox
        • risting
          • Jun 2015
          • 32
          • macedonia
          i need help for capacitor
          Xbox adapter capacitor 100uf 400v have 92uf is good cap or bad ? because my xbox won't turn on no any power no red ring nothing, adapter on yellow light
          when press power i have only beep sound motherboar is trinity 16mb
          • gabri2211
            Xbox Series X Console Won't Turn On - Broken Nexus Connector on Mainboard
            by gabri2211
            Inside the console there is a small circuit board (see photo) that contains the main power switch, the one on the front.
            This circuit board connects to a 10-pin flat cable called NEXUS that terminates on the motherboard.
            This NEXUS connector broke.
            Can anyone tell me, while waiting for a replacement, if it's possible to turn on the Xbox by disconnecting this circuit board and making some modifications (like adding a small power button) on the motherboard?
            The Xbox has a power supply that provides 12 volts on all outputs, so the power...
            07-28-2025, 07:13 PM
          • TMTGTR
            An Xbox One PSU Odyssey
            by TMTGTR
            Firstly I am not a tech. You guys may see mistakes or oversights in my methods so don't be bashful and feel free to post corrections/opinions.
            =>Background:
            I bought my son a used Xbox One original model: A12-220N1A Rev: 02 with original PSU & 2 controllers 7 years ago. I “modded” the unit placing a 4.5” 12V exhaust fan with a 9v wall wart adapter on top of the vent/fan of the unit. And plugged the Xbox PSU into a Tripplite LTR-600 voltage regulator. Also connected to the Tripplite are a 275w computer tower, an Xbox 360 PSU and a Westinghouse 52” LED TV. ...
            06-17-2022, 05:40 PM
          • Wigs
            XBOX 360 Jasper
            by Wigs
            I trained many years ago as an electronic engineer, in the 80's, but never really went into the field. Things are a lot different these days, components the size of specks of dust instead of family cars etc. Anyway, I have a strange problem with my xbox 360, I noticed one day that it would switch itself on and the disc tray would repeatedly open and close. I searched the internet for information, to no avail. I did find some circuit diagrams, it appears as though the machine thinks the ODD button is being continually pressed. I found the section where the eject button is and figured...
            08-15-2024, 05:23 AM
            HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green EliteDesk 800 i5-7500 Specification for Upgrade or Repair
            This specification for the HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green boardview and EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
            09-12-2024, 02:00 PM
          • Stevedb
            Boardview xbox 360 , xbox fat , xbox one x and xbox one s
            by Stevedb
            Hi all
            I will share the boardviews i found internet from the xbox 360 , xbox fat and xbox one x and xbox one s
            Pasw netcomchetumal.
            Enjoy it.
            Greetings Steve
            From Belgium...
            04-04-2023, 12:42 AM
