JVC LT-40C860 stuck on logo
  • ioanban
    • Dec 2020
    • 47
    • uk
    Hi guys,
    I have a JVC LT-40C860 stuck on logo.
    I have tried all sorts of resets but nothing seems to help.
    I have checked the fuses on the main board and power supply and capacitors everything seems ok.
    From what i was reading on the forum I tend to believe it's a firmware problem.
    Now the question, is anyone who can give me the firmware so that i can put it on a usb drive and see if it solves my problem ?
    Tried contacting JVC but i got no reply.
    I've attached some pictures with the boards in case anyone wants any extra info.
    Thank you,
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: JVC LT-40C860 stuck on logo
    Is U13 an MX25L512 EEPROM or equivalent. If so I would freeze it with freezer spray and make cerain it gets really cold (set powered off) and then attempt to reboot the TV. You may have a failing EEPROM
    • ioanban
      • Dec 2020
      • 47
      • uk
      It is KH25L1606E. I'm just going to buy a spray and I'll give it a go
      • ioanban
        • Dec 2020
        • 47
        • uk
        I have frozen the EEPROM and it went over the logo but got reseted in a few seconds.
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          if you cant find a firmware dump this maybe be your board maybe worth sending the seller a lower price offer
          https://www.ebay.co.uk/itm/234098833...EAAOSwpL5g-Jxy
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            Try freezing it again and allow the EEPROM to get really cold. Give it several good blasts. Very often the inside of the IC hasn't become cold enough.
            • ioanban
              • Dec 2020
              • 47
              • uk
              I'll try gain, thank you
              • angelos
                • Dec 2012
                • 573
                • South Africa
                I saved a tv like that. I desoldered the chip off the board and fit it in my eprom reader. Then i sprayed it ice cold and started the read process. During the read i sprayed it again. I got a data image. Saved it, and dumped it into a new blank chip and viola. It worked , tv went out back to customer, fixed.
                • ioanban
                  • Dec 2020
                  • 47
                  • uk
                  Unfortunately the freezing didn't work for me and i don't think it's worth me buying a eeprom reader. I was looking for a firmware to use with an USB drive but no one seems to have one . I'm thinking on getting another main board.
                  • arizanotlari
                    • Nov 2014
                    • 158
                    • Turkiye
                    try this : https://yadi.sk/d/_zlpfQXu5tD28w
                    https://www.badcaps.net
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      The EEPROM reader/writer is dead cheap and worth having in your tool box.
                      • ioanban
                        • Dec 2020
                        • 47
                        • uk
                        Originally posted by arizanotlari
                        I have tried with this file but nothing happens, doesn't start updating
                        • ioanban
                          • Dec 2020
                          • 47
                          • uk
                          I have just ordered an EEPROM reader/writer . Thank you
                          • ioanban
                            • Dec 2020
                            • 47
                            • uk
                            Hi guys,
                            I have ordered an eeprom reader/writer but i couldnt get a working driver to be able to access the info on the eeprom so I bought a replacement main board and got it in. Tv is working perfect now.
                            If any of you has a reliable software for win10 that i can use with the eeprom reader/writer please share'it with me !
                            Regards,
                            • dick_barton
                              • Aug 2015
                              • 6643
                              • Wales
                              Which EEPROM reader/writer did you buy?
                              If it was the CH341A then here are a few progs that should work.
                              • lotas
                                • Jan 2016
                                • 4840
                                • Russia
                                Here is another program for CH341A.
                                • ioanban
                                  • Dec 2020
                                  • 47
                                  • uk
                                  I bought the CH341A.
                                  I'll try the progs you've given me.
                                  Thank you
