Lenovo Flex 14IWL Bios Editing Help
  • grimacelord
    • Jan 2017
    • 363
    I have a Lenovo Flex-14IWL here that I believe might be suffering from a corrupt BIOS. The device tries to power on, but black screen and no fan spin. The power LED then quickly turns off. I admit I am not 100% certain it's corrupt BIOS, but this is something relatively easy that I can rule out before I begin diagnosing board-level hardware problems. So far, I have:
    1. I have saved the original (possibly corrupt) BIOS from the chip using a programmer. This file is 16,384KB in size and is in .BIN format.
    2. I have extracted the BIOS image from the Lenovo BIOS update file downloaded from Lenovo's website here. This file is a .ROM image and is 18,093KB in size, or ~2MB larger than the original.
    Here is where I am lost. The file sizes are different. I understand I need to edit using a hex editor, but honestly, I am not versed enough in this sort of thing. I'm not sure what I am supposed to be doing with the hex editor. Seems like I need to remove 2MB of data from the update to make it 16MB like the original, but I don't know how to determine what 2MB to remove. I'd really like to learn how to determine that myself, so if someone is willing to give me a hand with this, could you also spend a moment to explain exactly how it is you know what to edit? I'd appreciate that very much.
    My ultimate goal here is to have a file I can flash back to the BIOS chip using my programmer and then see if this fixes my problem or not.
    Attached are the two files I have prepared. The original BIOS file named original.zip and the extracted BIOS image from the downloaded update named EL4C1211.zip. I am hosting the files on my mediafire account.
    Files:
    original.zip
    EL4C1211.zip
  • grimacelord
    • Jan 2017
    • 363
    Re: Lenovo Flex 14IWL Bios Editing Help
    Oh, crap. Can a mod move this to the BIOS requests section? I didn't see until after I posted. Ugh. Sorry!!!
      • 20645
      Thread moved .
      There`s a guide you can follow https://www.badcaps.net/forum/showthread.php?t=98038 .Its the same method to cut the bios to the right size. The same method for the DMI and win key ,the offsets in your bios are different though.Follow the guide but use the offsets below. D is the DMI, W is the key.
      D 620000 - 6207FF
      W A90000 - A9003F
      If you followed it ok and made a new bios you can check its SHA-1 hash using Hxd. Analysis -> Checksums -> SHA-1 -> OK
      0DF475F4267F8987509F29BC309B912820F89D9F .If its the same hash youve done a good job.
      • grimacelord
        • Jan 2017
        • 363
        Originally posted by SMDFlea
        Thread moved .
        D 620000 - 6207FF
        W A90000 - A9003F
        Nice, thanks!
        I'll try this once I get to work later and come back to let you know how it went. Thanks again.
        • grimacelord
          • Jan 2017
          • 363
          Well, I followed everything twice and I am not getting that SHA-1 checksum you have. After two separate attempts, two different test bios files I made, I get the same checksum, but it isn't matching to yours.
          The file that I end up with is indeed the same as the original backup, but the SHA-1 is different than what you posted.
          I did try flashing it anyway and it doesn't appear to have made any difference in behavior at all. Now I'm not sure if that is due to the BIOS image I made being bad or if it never was a BIOS problem to begin with.
            • 20645
            Here`s one i made earlier .Compare it with the one you made .Flash it and if it doesn`t work i`d say the problem is somewhere else .If you need any more help with it just start a new thread in the main laptop forum https://www.badcaps.net/forum/forumdisplay.php?f=23
            • grimacelord
              • Jan 2017
              • 363
              Awesome! It worked! I flashed your BIOS image and as soon as I pressed power and saw a fan spin, I knew it was going to be fixed. Of course, I waited for full boot and I can happily report that it is indeed working as expected.
              So, I was right. It was a BIOS problem. Now I'm going to compare the bios files I made versus the one you made and see where I went wrong so I can try and learn more about this sort of this and try the next one by myself.
              Thanks again for your help!
              • Vesko356
                VIP Moderator
                • Aug 2018
                • 4386
                • Bulgaria 🇧🇬
                Become a Badcaps supporter
                Thanks to all supporters.​
                • Forest79
                  Lenovo ThinkStation P520 BIOS file needed
                  by Forest79
                  I got a Lenovo ThinkStation P520 (Type 30BF) from a friend, asking me for a repair. Windows 11 offered a firmware upgrade as an optional update, and it failed.
                  The emergency flash procedure from the hardware manual has also failed. So, I asked an acquaintance with better skills to flash the BIOS directly.
                  However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                  07-23-2023, 07:39 AM
                • survivalbloke
                  Unable to extract bios file from Lenovo bios exectuable
                  by survivalbloke
                  I'm trying to extract a flashable bios file(ch341a) from the lenovo bios executable download. I have tried the instructions from this site https://starkeblog.com/lenovo/uefi/2...pdate-exe.html, which are not working. According to those instructions, after issuing the command
                  Code:
                  "innoextract 7wcn38ww.exe"
                  it should create an \app folder, inside which, I should find a newly created "7wcn38ww.exe" file. I should then be able to extract that using 7zip and find my .FD file.
                  The trouble I'm having is that I'm not getting the newly...
                  06-12-2024, 07:55 AM
                • claws77
                  lenovo flex 5 14ITL05 bios and motherboard fault
                  by claws77
                  my laptop is lenovo flex 5 14ITL05
                  recently my power supply for this laptop developed a fault.
                  which caused a short in my usb c port -- verified with a new charger.
                  rant: so, i went to the repair tech in my country, he asked for a huge repair cost when i decided to get it done someplace else this "great person" nicked my bios chip, asked me to be aware for repair scams lol.
                  I was stupid and unable to find the flaw at the moment. Another repair tech told me that my bios chip was stolen and an 8mb bios chip is in place of that. he told me that a 32...
                  07-05-2024, 04:33 PM
                • maanee11
                  Help to get Lenovo BIOS bin file for Thinkpad T560
                  by maanee11
                  Hello Everyone,
                  I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
                  https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
                  In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
                  05-15-2022, 11:59 AM
                • survivalbloke
                  Unable to extract Lenovo BIOS file from installer
                  by survivalbloke
                  I'm working on a Lenovo LOQ 15APH8, Serial# MP2L9MAV. I want to flash a new BIOS onto it, but I'm also trying to learn this process for my own enrichment and professional development.
                  I was watching some tutorials, copying the serial info blocks from the old bios to a new bios. Before that though, they use innoextract on the Lenovo .exe. I downloaded Innoextract v1.9 but it tells me my .exe is not a supported inno setup installer(see screenshot). So if I unpack this using 7zip, I do get a .ROM file, but according to my tutorials, I'm looking for a .FD file.
                  How can...
                  07-16-2025, 03:21 PM
