Assistance identifying component on 820-3455-A IO board
  • Iph
    • Jan 2021
    • 3
    • Norway
    I've been unable to source any schematics for this (820-3455-A) A1466 (Macbook Air 2013-2015) power/IO daughterboard, and I don't have a replacement on hand.
    I've narrowed my issue down to this diode(?) marked in these images, right behind the MagSafe port, but it has a big blow-out crater in it. Could any of you help me identify this part, closely enough that I can source a replacement?
  • mon2
    • Dec 2019
    • 14510
    Re: Assistance identifying component on 820-3455-A IO board
    The part is a no stuff. Just checked it on a local board.
    • piernov
      • Jan 2016
      • 4437
      • France
      Refer to 820-3213 schematics.
      • mon2
        • Dec 2019
        • 14510
        Adding the schematic for 820-3213.
        • ACS-Repair
          • Feb 2021
          • 204
          This might be a bit late but, if this is referring to the diode in the picture, it is D6904, a protection diode.
          • Dale65
            • May 2018
            • 14
            Can anyone supply me with a link to purchase D6905 5v 10pf SLP1006P2T-SM For 820-3213 I/o board ?
            • mon2
              • Dec 2019
              • 14510
              https://www.digikey.com/en/products/...1TQTCT/4501981
              • Dale65
                • May 2018
                • 14
                Thank you
                • Tynan Dill
                  by Tynan Dill
                  Assuming...
                  11-22-2024, 01:46 PM
                • howardc64
                  by howardc64
                  07-24-2025, 05:17 PM
                • ugamazing
                  Assistance with identifying resistor value on 820-02918 A2992 board?
                  by ugamazing
                  Working on a 2023 M3 A2992 unit with 820-02918 board, and it uses a new USB-C power architecture, with rectangular controllers. I do not have a perfect-matching board, so have been repairing this one the old-fashioned way (slowly).
                  I managed to blow-away a single resistor that I can't find and can't determine the value of. It connects to ground, so I went ahead and stuffed it with a 100K resistor in case it's a simple pull-up. But, I'm now having issues with that side of the board, and am curious if it's possibly related to this resistor! I have no schematics and no board view, so...
                  09-06-2024, 08:33 AM
                • snipersquad100
                  Dewalt DCR020 Power Board – No Power, Need Help Identifying ICs / Possible Replacement
                  by snipersquad100
                  I’m working on a Dewalt DCR020 jobsite radio that won’t power on.
                  So far, I’ve checked the following:
                  • The mains is reaching the transformer
                  • Transformer outputs ~15-20 V AC
                  • Bridge rectifier outputs ~15-20 V DC
                  • All fuses test OK
                  • The on/off button signal reaches the PCB connector
                  Despite this, the unit does not power up at all.
                  Inside, I’ve identified some of the ICs:
                  • ST7317 (appears to be an LCD driver, not the main MCU)
                  • LM2937L (voltage regulator)Not putting out power, 0.5V on the input
                  • Markings like FS1235, unknown IC
                  • Board number:
                  09-01-2025, 10:57 AM
                • m1ch43lzm
                  by m1ch43lzm
                  05-12-2025, 08:37 PM
