HP 15 day11amb6e0 y11a Shutdown Issue
  • ronelex
    • Oct 2016
    • 195
    • Philippines
    Good Day,
    Model : HP 15-p004nx
    Boardcode : day11amb6e0
    Issue :
    When plug in, fan spins for a seconds then off,
    When power on current responds up to 0.12A then back to 0A but no fan spin.
    Checking the voltages, VCORE is missing checking enable signal, VRON also missing and already tried to flash bios and replace the SIO but same issue.
    Another signal is also missing HWPG, i tried to look for the cause, I already tried cutting the lines coming from powergood signals of 1.05V , 1.35v ram supply and 5v supply ic but nothing change
  • ronelex
    • Oct 2016
    • 195
    • Philippines
    Re: HP 15 day11amb6e0 y11a Shutdown Issue
    another unit receive same issue
    • Sephir0th
      • Oct 2020
      • 1289
      The fault must be earlier in the sequence. Find Out what exactly is Missing should give the clue. Of course, Schematics will Help a lot Here.
      And it Would be also a good start to Check whether PGood is released at Supplys with Expected Voltage present.
      A few days ago i Had a Board Here, some technicians already Messed with it. 1.05V PGood Not released and additionally the EC was somehow "stuck" after fixing the PGood. A bit of "stabbing" the the EC and corresponding components of Missing PM_SLP_S3# solved the issue. Board works stable since then.
      And this is Not the First Time i fixed Something while "stabbing" around the EC and the VRM. Happened already a few Times to me.
      FairRepair on YouTube
      • daryl_rasta
        • Jul 2019
        • 14
        • philippines
        up for today !!!!
        • ronelex
          • Oct 2016
          • 195
          • Philippines
          I have already checked all the supply connected to the Pgood signal and All of them released the voltage output before it shutdown but PGOOD signal is missing. Can you help me trace the THermal IC? I will try to remove and put back it to reset
          • Sephir0th
            • Oct 2020
            • 1289
            You're talking about U16? Probably not present because a optional component.
            Which PGood exactly is missing? H_PROCHOT# low or high?
            • SuperJames
              Dell G3 17 3779 Weird power cycling and shutdown/restart issue
              by SuperJames
              This one's a weird one, and still unsolved despite it having gone back to Dell once.
              Specs
              i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
              Backstory
              I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
              10-23-2023, 04:09 PM
            • kalilinux25
              Power Issue, if shutdown it wont power on again.FH5AT LA-K092P REV 2.0
              by kalilinux25
              Hi good day I have a issue of this motherboard laptop, if doing a cmos reset the the motherboard ( discharge the current inside the board) it will power on and if you shutdown
              the laptop it wont power , it will shows led light for a second then shutdown.
              Tried clean Me bios smae issue
              tried to bypass thermal protection ( remove RB7 and RB1 and jumper each pad of the DB1 )
              ive check the motherboard for corrion but no avail
              Hope someone can guide which part of the board should I focus to narrow down the issue
              FH5AT LA-K092P REV 2...
              10-06-2023, 12:49 AM
            • yaya3gmax
              Laptop Power Issue – Works on Battery, Fails on Adapter Load
              by yaya3gmax
              Dell laptop (E7440, uses the notorious CD3301B power controller + MEC5075 EC + BQ24715 charger IC)
              Symptoms:
              • Laptop works normally on a pre-charged battery.
              • Battery does not charge when adapter is connected.
              • Without battery:
                • Laptop powers on from DC adapter, passes CPU/RAM init checks, then cuts DC power abruptly.(seems to shutdown one of the mosfets in the charger path). Then the loop continues indefinitely
                • Speakers “pop” when power cut occurs indicating harsh sutdown.
                • If RAM is removed, the system shows RAM missing blink error code indefinitely without cutting DC power
              08-21-2025, 07:16 AM
            • rounin
              MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
              by rounin
              Hi everyone,
              I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
              🛠 Original Issue
              The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
              Diagnosis showed PP1V5_UPC0_LDO_CORE shorted to ground.
              I replaced U3100 (UF400) using a donor board (A2179), and the machine powers on fine now.
              ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
              04-19-2025, 01:18 AM
            • ugamazing
              Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
              by ugamazing
              I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
              We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
              12-17-2024, 07:05 PM
