PSLF201501B BN96-03057A Blown Capacitor
  • LugNut
    Eager to Learn
    • Oct 2017
    • 8
    My TV uses the board BN96-03057A, model PSLF201501B.
    The original issue was the standby light would go on then immediately turn off - TV would not turn on. Pulled the board to found 3 caps bulging so I replaced them.
    After replacing the caps and confirming the fuse was good, I plugged the board into the wall. At that point the board was not generating power. Checked the fuse and it was blown.
    I replaced the fuse a second time, plugged it in, and poof - cap NT811S made quite a pop! In hindsight, I had read somewhere that you can use a 40 watt bulb in place of the fuse. If it lights you have a short.
    Here is my thought process for trouble shooting:
    1. Pull the bridge rectifier to isolate the AC from DC
    2. Test the bridge rectifier
    3. Replace the popped cap. Not sure I can read a number off it
    4. Apply AC power and check for 120v potential where the rectifier was
    5. Check for a short on the DC side by injecting low power into the rail
    6. If no sort found, install the rectifier and the light and give it a go.
    Is my thought process close? I do not have the schematic, but I can kind of make out the paths.
    Thank you.
  • petehall347
    • Jan 2015
    • 4440
    • United Kingdom
    Re: BN96-03057A Blown Capacitor
    one of the caps you changed was installed backwards or wasn't suitable .
    • LugNut
      Eager to Learn
      • Oct 2017
      • 8
      if you changed NT811S it was installed backwards or wasn't suitable .
      Thank you, but I did not change NT811S. Pretty sure it is a nonpolarized cap.
      • petehall347
        • Jan 2015
        • 4440
        • United Kingdom
        i looked at pic after then edited my post .
        • R_J
          • Jun 2012
          • 9594
          NT8115 is NOT a capacitor, it is a NTC thermistor 5Ω cold. Check that QP801s is not shorted, if it is, RP819 is also likely open. Check if FS802s fuse is ok, if it is ok then that eliminates most of the power supply circuit.
          • R_J
            • Jun 2012
            • 9594
            The thermistor is likely a 5D-13
            • Robinsosa
              • Nov 2013
              • 19
              • kenya
              I hope this is the schematic diagram for the power supply.
              • LugNut
                Eager to Learn
                • Oct 2017
                • 8
                Thanks RJ. FS802S is ok. I pulled QP801S out of the circuit and tested it with my component tester, which shows it is good. I did the multimeter test and it checked out good. I also pulled out RP819 - it is not open but has 0.3 ohms resistance. Is that good?
                I looked at the datasheet for QP801S to learn more about it. I found some test circuits I am going to breadboard up to learn a little more before I stick it back in the board.
                One thing I could not find information on is that the drain(2) is shorted to the back plane of the TO-247 package. Is that correct? Unless I missed it, it does not show in the datasheet. It was late when I checking it.
                Thank you for helping me get this fixed.
                • R_J
                  • Jun 2012
                  • 9594
                  Re: PSLF201501B BN96-03057A Blown Capacitor
                  Yes the mosfet drain is connected to the tab, if the mosfet is not shorted drain to source it is likely ok. it sounds like the thermistor could be all that is wrong.
                  • LugNut
                    Eager to Learn
                    • Oct 2017
                    • 8
                    You were spot on with the 5D-13. Ordered a couple from mouser. Should be here in a couple of days.
                    • LugNut
                      Eager to Learn
                      • Oct 2017
                      • 8
                      UPDATE: Replaced the thermistor and fuse. There was 6V on the standby. Installed the board in the TV. When I turned it on, the MOSFET shorted and caused a bit of smoke and blew the fuse. I have replaced the MOSFET and fuse. Confirmed there is 6V on the standby. Installed the board back in the TV.
                      Now the standby light comes on but immediately goes off. Pushing the power button does nothing.
                      On the bench, the 6V is constant. I am concerned that it may be something in the main board now.
                      If I jump the ST_BY6.0V pin to the PWR-ON/OFF will that start the board and provide the 5.4VLINE and 24VLINE voltage to confirm they are working?
                      • Babbar
                        by Babbar
                        04-12-2024, 01:12 AM
                      • drscoot
                        HP X360 convertible battery blown fuse error, not charging
                        by drscoot
                        HP Modelnumber: 14-dh0061nb​
                        This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
                        The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
                        I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
                        And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
                        All these 3 batteries are charging...
                        12-15-2023, 05:54 AM
                      • beetle1303
                        Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                        by beetle1303
                        I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                        On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                        01-13-2025, 08:49 PM
                      • whc14765
                        Gigabyte 980TI Windforce - Blown PCIE Fuse
                        by whc14765
                        Hey,
                        I have a Gigabyte 980TI Windforce. No shorts on the main 8 pin PCIE power connectors. The 8 phase buck converter inductors are showing 2.5ohms.
                        The card doesn't power up at all - no lights, no fans, nothing. I noticed that all of the 8 phase inductors are showing 0V. I couldn't find a fuse for the 8pin power connectors.
                        I did notice that the PCIE x16 connector 12V line has a fuse F3 (10A marked on it) which is blown. It is reading 16ohms on one end.
                        1st Question: Is there some logic on the board that checks the 12V on the PCIE x16 bus connector...
                        04-08-2022, 06:22 PM
                      • NConstantinou
                        Lenovo nm-d471 fv1 fuse blown
                        by NConstantinou
                        I found that fv1 on one side i have 19v and on the other side 0v.
                        The fuse is 3a 32v FOR BACKLIGHT.
                        I do not have such a tiny fuse.
                        Can i replace it with a wire and what size.
                        I know i am overpassing fuse but i don't have any other solution.
                        02-14-2023, 06:44 AM
