A 2200lm 7057 LED car lamp...
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8703
    I ended up finding one of these bulbs and tried lighting it...
    WOAH yeah I think 2200lm is about right - it's blindingly bright. It's yellow unfortunately, but that's expected to be 7057 replacement.
    From what I found it's 12V 1.75A so this thing is dissipating about 20W, though unsure how much is light vs heat. It does get hot fast - cannot hold onto it in about 20 seconds. Not sure how much of the metal frame is actually functioning as a heatsink or not.
    I do wonder how long this thing will last if I run it 100% duty cycle, I suspect it was intended for blinkers with much lower duty cycle?
    Note that at 2200lm, this is brighter than a 100W incandescent rated at 1600lm.
    • Jul 2011
    • 6070
    Re: A 2200lm 7057 LED car lamp...
    If you were to run it more than 50% of time then put a current limiting resistor or a PWM controller which would be my pick
    • petehall347
      • Jan 2015
      • 4445
      • United Kingdom
      have had to dispose of a few that look like that cos they end up falling to bits . then i replace with proper bulbs .
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8703
        What was the failure mechanism when they "fall to bits"?
        It looks like a lot of different bulbs are out there, would be nice to tell which specific ones.
        I found out the metal base seems to be conducting part of the heat so it's definitely doing something to conducting heat around.
        • petehall347
          • Jan 2015
          • 4445
          • United Kingdom
          ones i had trouble with are sidelight bulbs inside the headlights . they turn to dust . maybe its the heat from the main and dip bulbs .
            • 31259
            the chinese are now making led car lamps that look original using mini led filaments!!
            i saw them on ali the other day - not sure how bright they are though.
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8703
              wtf the "LED filaments" will not survive vibration.
              Those "LED filaments" was entirely an aesthetic thing that will never be seen in an enclosure...
              Ah interesting - they chose 1.75A so that the power consumption of the device matches the original incandescent 7507 bulb: 21 watts. So this abomination uses the same amount of power, gets (almost) equally as hot... but generates 8 to 10x the amount of light!
              Another interesting characteristic...found that these LEDs seem to go down in power consumption slightly as it heats up - down to 1.5A when it becomes too hot to hold. Dimming slightly most likely... is it self limiting?
                • 31259
                the filaments arent effected by vibration, and they allow much more leds resulting in lower power per led.
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8703
                  They sure are affected by vibration, it's not the LEDs themselves but the mounting onto the stalks, heavier the "filament" the more torque it supplies onto the stalk, potentially breaking welds when shaken.
                  Unless they use more supports which would cost more...
                  • redwire
                    • Dec 2010
                    • 3912
                    It looks like 3 LED's in series strings and 16 groups of those, for 48 LED. It's to get ~9.6V LED and then resistors to drop the 12-14V down for that.
                    That looks like about 110mA/LED and dissipating maybe ~16W plus the resistors ~5W.
                    It's just the heat is too much if they were lit all the time, i.e. a brake light in a traffic jam.
                      • Jul 2011
                      • 6070
                      It would probably be better if it had a PWM controller ic chip instead of a resistor for current limiting control
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8703
                        Since it's yellow, it was intended to be for turn signals.
                        There is one heck of a lot of LEDs on the cob: there's 78 total - 6 faces of 12 plus another 6 on the end - so 26 strings of 3.
                        Current limiting Resistor(s) is(are) probably in the core somewhere. Does not appear to be a PWM unfortunately.
                          • Jul 2011
                          • 6070
                          You could do away with the current resistors and use a PWM controller the led module would last a lot longer doing it that way and you could adjust the brightness of the leds
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8703
                            How hot is too hot for LEDs..
                            Apparently commercial heatsinked LEDs fail the "if you can't put your finger on it you need a fan" test...
                            Then again it seems any LED lamp that produces more than about 100lm (1W) eventually gets hotter than you can leave your finger on.
                              • 31259
                              these are designed for a 50/50 duty cycle remember
                              • eccerr0r
                                Solder Sloth
                                • Nov 2012
                                • 8703
                                It was not written explicitly, not sure where you remembered that?
                                  • 31259
                                  it's an indicator lamp for a car.
                                  • petehall347
                                    • Jan 2015
                                    • 4445
                                    • United Kingdom
                                    or brake or fog light
                                    • eccerr0r
                                      Solder Sloth
                                      • Nov 2012
                                      • 8703
                                      If there is no duty cycle listing written, 100% duty cycle must be assumed.
                                      Fog, head, dome, courtesy, etc. lights might well be 100% duty cycle...
                                      Aren't yellow lamps frequently used for fog lights too?
                                      • redwire
                                        • Dec 2010
                                        • 3912
                                        I've found it's a heat-limited situation. An incandescent bulb can run quite hot, much hotter than electronics. So expecting to dissipate 20W of heat in an enclosed light fixture, well it's going to just be too hot. Especially on a hot summer day. The limit is melting the socket and reflector.
                                        My limit for touch is around 160°F/80°C and LED's are run even to 100°C in cheap crap.
                                        • pedrolopesbe
                                          Galax 3090 bad duty cycle on mem phase
                                          by pedrolopesbe
                                          I got this 3090 wich I own, same board as the common 388_50 boardview.
                                          I'm new to SMD work, and in a moment of stress trying to solder a 0402 filter cap that I've knocked out I've made a big solder mess in the "U42" drmos.
                                          As past is past, after getting a pre heater now I succesfully unsoldered the chip but I'm having problems soldering it back again.
                                          At the last time I've worked on it, I had to reflow it as it was not giving any out signal, measuring using the Hz function in my multimeter.
                                          Now I get a reading of something like 1.7kz while other phases 3.09khz...
                                          01-20-2025, 11:46 PM
                                        • meraklinetx
                                          Asus Z97-a power cycle, no boot no cpu voltage
                                          by meraklinetx
                                          Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                                          05-10-2023, 06:08 AM
                                        • spice_disc
                                          Vizio TV M50-C1 reboot cycle and static on screen
                                          by spice_disc
                                          I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                                          The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                                          09-08-2024, 02:37 PM
                                        • vestaviascott
                                          Epson 5040UB Projector No Lamp Strike Stuck in Startup - Blinking Status/Lamp Lights
                                          by vestaviascott
                                          Hoping someone here can put me on the right track. I'm trying to troubleshoot/flowchart the "internal projector error" on my newly acquired Facebook Marketplace bought Epson 5040UB projector (3LED, not DLP). Owner said it needed new lamp, actually error code blink pattern indicates "Internal Projector Error, call Epson support". Unit is out of warranty as of 8/19
                                          Here's what happens:
                                          1) Power on
                                          2) Blue power indicator lights and the lens cover motor opens the lens cover, light fan noise heard
                                          3) Blue status light flashes for appx 4 minutes...
                                          07-29-2020, 06:08 AM
                                        • AJ847.63e
                                          BenQ TH681 Originally overheating now wont fire the lamp - Colour wheel not starting
                                          by AJ847.63e
                                          Hi All.
                                          Does anyone have any reference materials or something I can use to try troubleshooting a BenQ TH681? Google unfortunately has turned up zip. I did find a service manual for a W series BenQ but that is pretty much useless, it's more a glorified user manual. A list of voltages would be great as I suspect my mainboard is faulty, the colour wheel voltage is not dipping like it should.
                                          The one I am troubleshooting now was originally overheating after a lamp replacement. It originally would take 2 minutes or so for it to shut off and blink the temp and lamp lights...
                                          09-18-2023, 06:42 PM
