Macbook A1286 not charging no power from bat BUT WORKS ON AC
  • marce002
    • May 2018
    • 316
    • Argentine
    Hello
    Anyone can help me out this rare issue ... macbook a1286 2010.... it is 820 2850
    Works fine from ac power and disconnecting AC also works from battery no issues
    But
    It will not power on from bat ony
    No amber lednonly green
    Power on only with magsafe attached
    Rest is Normal
    Pd: replaced u7000 but does the same.
    Thanks for any clue!
    Marcelo J
  • mon2
    • Dec 2019
    • 14721
    Re: Macbook A1286 not charging no power from bat BUT WORKS ON AC
    hi.
    1) with battery only connected - what is the voltage of PPBUS_G3H ?
    2) power down & remove all power (adapter & battery not connected); meter in resistance mode (200 ohms).
    Check for shorted mosfets @ Q7055; Q7080; Q7085; Q7030; Q7035.
    For each, check the resistance between
    SOURCE & DRAIN
    SOURCE & GATE
    GATE & DRAIN
    • marce002
      • May 2018
      • 316
      • Argentine
      thanks mon2 i will post them, but i want to add a little strange thing, which is that
      in "cold overnight start" i have no power, but when I warm it up a little bit around resistor (R6995) it will just start fine.... also if put finger on R6995 it just turns off
      something weird arround that zone, I thought was the GPU but it is exactly at R6995 and removed and it is fine 1Mohm.... maybe is the IC but the effect is on that Resistor...
      if the mother was warm becasue left working some time, it will power on fine..... but after several hours it will not.
      like some temperature issue, but related to that r6995,,,,, any hint?
      thanks in advance
      Marcelo J
      • reformatt
        • Feb 2020
        • 1534
        Check those FET's, particularly Q7055. With no magsafe, you should get battery voltage on the input of U6990. Troubleshoot that circuit if you have no PP3V42_G3H. This area is right on the edge of the board and usually corroded.
        • marce002
          • May 2018
          • 316
          • Argentine
          yes I have U6990 with bat volt at pin 3 BUT ALSO in pin 2?? and should be 3.42v i think... you are right seems to be NOT 3.42v in that pin 2....
          clean and no corrosion zone.
          volts at U6990 are (with no ac and bat connected only):
          is this wrong?
          1- 1.20v
          2- 10.97v
          3- 10.97v
          4- 0v
          5- 0v
          6- 1.05v
          7- 2.08v
          8- 1.053v
          9- 0.054v
          10- 0.448v
          Q7055 seems to be fine.
          Note: battery state is unknown but each cell is at 3.98V and if i remove AC laptop continues with fans turning but removes screen image..
          And i repeat, that the mac works almost fine except that CPU is slow, (fans normal speed though), and of course main issue
          is that it Works fine from ac power and disconnecting AC also works from battery no issues
          But
          Marcelo J
          • mon2
            • Dec 2019
            • 14721
            hi.
            1) your DCIN voltage is too low. It should be much higher than the posted 10.x volts.
            2) post the voltage @ pins 1 & 2 of J6900. Do you see the same low voltage ?
            If yes, power down -> remove adapter & battery power.
            Meter in resistance mode. Check the resistance to ground on F6905.
            Value in ohms ?
            This logic board either has a short on the same PPDCIN_G3H rail or your external power adapter is not working properly.
            As a suggestion, if the voltage @ F6905 is still low, desolder this fuse so that you can confirm that the adapter voltage is capable of powering this logic board.
            If indeed, the adapter voltage is 15-20V (without the fuse completing the circuit), then proceed to review all parts that are connected to this rail. Leave the fuse out so that you can study the condition of downstream parts like mosfet Q7080, etc.
            • marce002
              • May 2018
              • 316
              • Argentine
              Hi Mon2
              1) it was not DCIN, it was battery only (since i was told above to measure with no magsafe by reformatt)
              2) volt with ac and bat the same:
              1- 18.11v
              2- 18.11v
              39kohm fuse is ok f6905
              power adapter is fine, it is my bench unit t and magsafe 1 cable as always.
              when power on volt in fuse is 18.17v steady
              the problem is NO AMBER LED ON MAGSAFE no charging, and not powering on from bat only!
              Marcelo J
              • mon2
                • Dec 2019
                • 14721
                Magsafe led is a single wire communication using Dallas semiconductor interface that is powered from +3v42.
                Can you confirm this power rail is stable at 3v42?
                That is the first requirement.
                • marce002
                  • May 2018
                  • 316
                  • Argentine
                  yes in the coil hgave 3.38V steady but sometimes does not start, and when touching coil L6995 zone it starts, some weird behaviour is in that U6990 zone...
                  anyway now that is powered on it is steady at 3.38vol (just now no battery, with AC only)
                  attached battery and AC and remains steady at 3.38vol too
                  only battery also it is 3.38v
                  Marcelo J
                  • mon2
                    • Dec 2019
                    • 14721
                    In my opnion, you should see +3v42 @ L6995, pin # 2. Perhaps others can supply their feedback on this rail or check Louis' youtube videos on the topic.
                    Based on the touching of L6995, consider to flux and reflow the inductor and also U6990. Do so with care so that parts are not flying around - low air pressure but with higher heat (400-500C) should be ok due to the multilayer PCBs used by the factory. Perhaps you have some corrosion causing this fault.
                    After the reflow, check the voltage again to see if the value is closer to +3v42 - keep in mind this is a low current rail and the feedback resistors (Ra & Rb) for the power supply IC @ U6990 have been selected to yield this output voltage.
                    Next, remove all power (adapter & battery) - meter in resistance mode -> check the resistance to ground on L6995, pin # 2. What is the reading ? Perhaps you have some excessive load causing this small voltage drop.
                    Last comment - is your meter accurate for this measurement? Maybe you can test with another meter as well to confirm ?
                    • marce002
                      • May 2018
                      • 316
                      • Argentine
                      ok updated status is: Replaced big Resistor R6995 1004 in the 3.42v generation zone, wich despite its value reading with MM was ok, it did the trick, and now overnight or "cold"/warm issue is gone and turns on as expected butt.... still no battery charge no amber led BUT works on battery only and also plugged in with battery...in the scope smbus CLK line is always HIGH (no "movement" is freeze high) but smbus SDA line has some activity... what can be wrong... (remember macbook start and boots fine, works on bat only , works with both AC and BAT only issue IT DOES NOT charge
                      Marcelo J
                      • mon2
                        • Dec 2019
                        • 14721
                        Good to hear that you are making some progress.
                        Is the battery a known good battery? Most of the time, the battery is the fault.
                        If you are confident that the same battery is able to charge on another box then can continue the investigation.
