Need Help Identifying Component For Printer Main Logic Board HP M570DN
  • grimacelord
    • Jan 2017
    • 383
    Hello. I know that I am asking for help with a printer, but this is specific to the printer's logic board so I figured it would be best suited under the motherboard repair forum - please move if better suited somewhere else.
    I have an HP M570DN printer that has stopped being recognized by USB. This apparently happened after a lightning strike. I pulled the logic board out of the printer and did a visual inspection of the board under a microscope. Board looks ok. Then I started checking random caps looking for a shorted line somewhere. I eventually discover one. I inject 1V into the line and look under thermal camera and find a component just behind the USB port that is getting hot. This component is 6 pins and labeled "NFTF".
    I did some Google searching and I did find some images of it, but the websites where those images are located on don't describe what it is. Here is the site I found that had it: https://www.indiamart.com/proddetail...732612462.html
    It's sort of vague and just says it's made by Texas Instruments, but I am not even sure of that's true.
    I was hoping someone could help me identify this component so I could replace it and see if it restores USB connectivity rather than having to replace the entire logic board.
    Thanks. Pics attached.
    • 22135
    Re: Need Help Identifying Component For Printer Main Logic Board HP M570DN
    It is a TI part.
    https://www.ti.com/packaging/docs/partlookup.tsp Entered the first 3 digits then googled TPD2S017
    https://www.ti.com/product/TPD2S017
    https://www.aliexpress.com/wholesale...t=tpd2s017dbvr
    • grimacelord
      • Jan 2017
      • 383
      Originally posted by SMDFlea
      Awesome. Thanks!
      • Dani_2024
        by Dani_2024
        10-28-2024, 05:06 PM
      • ygorsan
        LG 55NANO77SRA TV – Menu scrolling by itself even after removing button board (Main Board EBU66792103)
        by ygorsan
        Hi everyone,
        I’m looking for help with a persistent issue on an LG TV model 55NANO77SRA, which uses the main board EBU66792103 (also used in LG UQ80 and NANO75/NANO80 series).
        🧩 Problem Summary:
        • The TV keeps scrolling through the menu or selecting items by itself.
        • I removed the physical button board (the entire panel with power and volume buttons) and also disconnected the flat cable (CN202) from the main board.
        • The remote control is not in use (batteries removed), and the TV still shows the same behavior.
        • I
        07-28-2025, 08:34 AM
      • jb_Bak
        by jb_Bak
        CN6401
        Pin 01 NC
        Pin 02 NC
        Pin 03 "BL_ON": 0V
        Pin 04 "N/C"
        Pin 05 "STBY 3.3V": 3.5V
        Pin 06 "GND": N/C
        Pin 07 "AC_OFF"...
        09-27-2021, 04:52 PM
      • JDC
        (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
        by JDC
        ONN 100012588
        Issue: No Power, Then Rebooting After Main Board Change
        Short answer: replace main board and power board
        Technical answer: replace main board and Q306 & Q307 on power board.
        Long answer:
        TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
        07-15-2022, 07:39 AM
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
