line powered filament LED lamps...
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8713
    I was playing with one of those "filament" LED lamps. I noticed it seemed to flicker a bit...so I tried powering it with different things to try to extract information about it - noticed it seems to be 100% LED - no droppers, no PSU, no rectifiers, nothing - the LED "filaments" are hooked straight to the contacts!
    Wondering what's the distribution of how "filament" LED lamps are driven? Do any have capacitive droppers? rectifiers? CC PSUs?
    Found another "filament" LED that does have a PSU in it, seems to be a capacitive dropper type, possibly CC as well. Runs better than the first one - does not flicker.
    On another note, found a little multichip LED (has 24 1206(I think) SMT LEDs in it on two crossed PCBs) all in a unit about 1" long and ⅜" diameter (12VAC/DC, about 1W dissipated) that contains its own tiny switching PSU in it, can see a SOT23-5 IC(?) and a coil in it, and of course rectifier diodes. All embedded in silicone. Wonder how much these cost to make...
  • PeteS in CA
    • Aug 2005
    • 3586
    • USA, Unsure of Planet
    Re: line powered filament LED lamps...
    With traditional incandescent light bulbs, brightness is average voltage dependent. LED brightness is current dependent.
    Hooking a simple series string of LEDs across the line would result in an uncontrolled current and therefore uncontrolled brightness. And since LEDs are diodes, conduction would only occur on the appropriate half cycle. Or so it would seem to me.
    At the other extreme of LED lighting, LED street lamps are driven by a switching power supply that regulates output current rather than output voltage.
    PeteS in CA
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8713
      I'd imagine street lights, since aesthetics doesn't matter too much, use standard high reliability LEDs. I suspect that the LEDs could then be binned unlike "filament" LED strips.
      The first "filament" LED seems to contain two sets of LEDs in inverse paralled to deal with AC.
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        Big Clive makes lots of videos on LED lights, just browse through or search and you will find several on filament LED's too
        https://www.youtube.com/c/Bigclive/videos
        • cubytus
          Samsung UN50TU8000FXZC shows thin horizontal green line when warm
          by cubytus
          Hi to all,
          I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
          I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
          Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
          01-10-2024, 01:26 AM
        • EvazX
          ASUS ROG G513QY – RX 6800M powered but not detected intermittently + random crashes (Motherboard: 6050A3254002-MB-Axx)
          by EvazX
          I am working on an ASUS ROG G513QY laptop with RX 6800M dGPU.
          Originally, this laptop was completely non-functional. I replaced the motherboard (part number 6050A3254002-MB-Axx), and with the replacement board it started working fine.
          For a long time, the dGPU worked perfectly stable. I played several hundred hours on very demanding games such as Cyberpunk 2077 without any crashes, instability, or detection issues. Performance was excellent and there were no warning signs of failure.
          However, after some time, the replacement motherboard...
          08-25-2025, 06:09 PM
        • otaku_nut
          Vizio E701i-A3 fixed but now has red vertical line
          by otaku_nut
          Hi all, I tried searching the site for answers but I'm a bit over my head understanding some of what might apply and what doesn't, so please be patient with me. I used Freakaftr8's fix to remove the left driver board to restore picture to a black screen with sound Vizio E701i-A3. After doing so, I now have a large red vertical stripe down the center of the screen. The fix did require getting another t-con board from online, I ordered it before I knew about the mosfit fix for the old t-con board. I have tried cleaning the cable connections to the t-con board. I swapped the cables going from...
          08-19-2025, 06:11 PM
        • TrueSword88
          Kogan - KALED65XU9220STB - Blue Vertical Line
          by TrueSword88
          Hi all.
          I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
          The line just happens to coincide with the end of COF and start of the next COF (attached).
          The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
          Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
          Hoping to fix...
          05-05-2023, 04:28 PM
        • mindoverflow
          ASUS GTX 1650 Gpu.Initialize Interrupt request line stuck asserted
          by mindoverflow
          hello,
          there is an asus gtx1650 which displays fine in windows but if i run a benchmark test it displays artifacts and the driver crashes after a second or two.
          I changed pads and thermal paste.
          I run mats test but it is reporting 0 errors.
          I then tried to run the mods version 400.271_1650 test, it first ran and stopped with a 'breakpoints limit reached after 5 retries' error and the fans went full speed.
          After a reboot, I tried to run the test again, but now the test fails and says "ERROR: Couldn't clear GPU's interrupt...
          02-09-2022, 03:22 PM
