Can anybody tell me what type of glue or adhesive I need to reattach the ribbon cable from the screen back to a replacement t-con board on a TCL 32S331 TV? What is the process and where can I get the materials and or the tools to do this? Thanks in advance!
TCL 32S331 ribbon cable to t-con board
Tags: None
Re: TCL 32S331 ribbon cable to t-con board
Is there a way to do this without the machine in the video?Comment
Thanks diif! Any suggestions? I've been looking for ACF tape but the only place it's available is China, as far I can find. I have found a t-iron attachment on Amazon. Are there any other tapes or adhesives that can be used in place of ACF tape? Looking forward to your reply. Thank you!
No, only ACF tape can be used. It's conductive in one direction. https://www.silmantech.com/whats-acf...-does-it-work/Comment
Are there any places to get the ACF tape in the United States? It will probably take about a month to get it from China.Comment
Will this work?
https://www.amazon.com/gp/product/B0...ref_=pd_gw_unkComment
No, it's not conductive in the way ACF tape is.Comment
Any chance you might have some of this acf tape I could buy from you for this job? Or, maybe there is somebody else on here that might have it for sale that you're familiar with?Comment
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
Channel: Troubleshooting Computer Displays
by advantThis thread is about trying to get an Universal Main Board to work with a Sharp TCON and panel.
I have a Sharp LC-46D85UN TV that has had a main board issue. Since this model is from 2009, I am not able to find an exact replacement of the main board. Instead, I decided to see if I can future proof this tv by getting a Universal Main Board (T53U21.2) from China to work with the Sharp TCON (CPWBX4291TPZA) and panel. The universal main board supports a 8 bit dual channel LVDS interface whereas the TCON requires a 10 bit dual channel LVDS input. I have modded the LVDS connector to match... -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by Tr0llHi guys! I realized you have a lot of knowledge here so i am hoping you could point me in right direction with my odd issue.
Original T-con:
First replacement T-con:
I thought it might be t-con and ordered new t-con from china(supposedly tested)... -
by HakuuHi There,
More Details
TV Model - LG OLED77G1PUA
Got the same exact TCON board from TVPartsToday and replaced it. But didnt transfer the EPPROM data (didnt... - Loading...
- No more items.
