EZP2019 Programmier winbond 25q128fv??
  • samtron786
    • Aug 2016
    • 154
    • germany
    Hello how can I erase the chip 25Q128FV and write it again when I try to do that, in the end such an error comes up
    i leave a picture too
    Flash check error address:0h
    Thanks very much
  • Repdata
    • May 2020
    • 67
    • Deutschland
    Re: EZP2019 Programmier winbond 25q128fv??
    Hello
    look here
    EZP2019 Programmer MOD
    https://www.youtube.com/watch?v=8_sCP9a56cw
    • samtron786
      • Aug 2016
      • 154
      • germany
      Unfortunately, it didn't help that the chip doesn't find it automatically
      still the same bug
      is there a new firmware update for my programmer?
      • Bonzas
        • 469
        • Indonesia
        Did u use clip for programming ?
        • samtron786
          • Aug 2016
          • 154
          • germany
          Yes,
          I also have other chip unfortunately not recognized as automatic
          when I press the test but there is another chip info
          Clip
          the Ebel do you mean that?
          • CapThatBrass
            RT809F Chip Write Failure - Winbond 25R256JV
            by CapThatBrass
            I've managed to take an image dump in BIN format of my Dell Latitude 5420, which had a Winbond 25R256JV chip installed.
            I used an RT809F programmer to obtain the BIN, using the supplied iFix RT809F programmer application (latest version being 20220830).
            The programmer automatically found the settings to read the chip but selected the Winbond W25Q256FV instead (my actual model isn't available on the listing within the software). The image came out fine - I did this multiple times to clarify the data being read was the same each time.
            10-04-2022, 11:56 AM
          • testaccgta
            Unable to verify IC or write/erase/flash BIOS file to XMC QH128AHIG SPI chip using NeoProgrammer/AsProgrammer
            by testaccgta
            Hi, everyone!
            I've recently acquired two brand new SPI chips to replace the one currently in my Acer A514-54G laptop MB (FH5AT LA-K092P). The reason why I'm replacing the current SPI chip is because I had some difficulties with a third-party IT assistant who pretty much lacked the soldering skills and ended up destroying the current SPI chip soldered to my MB from factory.
            I've decided to do this on my own because I spent the past month or so learning some soldering skills and BIOS modding through Badcaps and WinRaid forums, hence the attempt. I've also chosen to buy...
            09-01-2024, 08:24 PM
          • Syseng
            Lenovo P14s Gen 5 SVP unlock
            by Syseng
            This sums up discussion related to Lenovo P14s Gen5 in this thread. Credits go to Sbaro and especially Maxpower3. The locked dump is attached.
            The device is based on NM-F871 motherboard with Nuvoton NPCK397 series controller. The motherboard also contains three BIOS chips: two different Winbond chips for main BIOS and external EC flash, and also a Gigadevice chip which purpose I do not know. The password information is contained directly in controller and thus can be manipulated by reprogramming it, so reprogramming BIOS chips is technically not required, however you may wish to make...
            06-22-2025, 07:44 AM
          • ChaosLegionnaire
            bug of the month: write caching setting for the hard drive in device manager
            by ChaosLegionnaire
            i recently bought a new wd re4 2tb with 2014 datecodes. when i got around to testing it tho in victoria hd tester, the write speed was very slow at 14 mb/s with a 256 sector transfer size. when i increased the transfer size to 1024 sectors, the write speed increased slightly to 44 mb/s. read speeds and sector verify speeds were fine and at normal speeds.
            so i just ass-u-med the drive's poor performance was due to it being an advanced format drive and i was using it on winxp. when i tried cloning my system disk to this wd re4 2tb drive and writing to it in linux, the write speed...
            10-06-2019, 01:39 PM
            Add chip support to EZP2019, EZP2019+, EZP2020, EZP2023, EZP2025, MinPro Programmers
            by SMDFlea
            This is a Github project, i have not used this software as i don`t own any of these programmers.The software looks good though,so i might just
            have to buy one,you can never have enough programmers
            QT based editor chip database for EZP2019, EZP2019+, EZP2020, EZP2023, EZP2025, MinPro programmer devices.
            For linux:
            https://github.com/bigbigmdm/EZP2019...ip_data_editor
            Authors homepage where there`s a windows version -> https://antenna-dvb-t2.ru/EZP_programmers.php
            05-26-2024, 07:33 AM
