Help me understand this schematic Harman&Kardon tape deck (TD470)
  • edugimeno
    • May 2017
    • 581
    • Spain
    Hi there!
    Im trying to service an old Harman&Kardon tape deck (TD470) player, which after being put away for many years, is now lacking sound randomly (first time I tried it worked, called the owner and said it wasn't working for him, tried again myself and sound was gone)
    This intermitent issue led to to go straight to the PS & Caps...I found at least one voltage missing (sorry now I can't remember which one), and one of the 3 fuses in the PS was open (this is strange as an intermitent failure wouldn't relate to a blown fuse).
    First thing I suspected was the capacitors but they all seem in very good condition. Then I found the schematic and Im having trouble to understand some parts of it, specially the -24v section (lower part of the schematic), and the p.mute in which Im totally lost on what it does and where it takes power from....
    Can you help me understand how these 2 sections work?
    Also why do f1 and f2 carry alternating current directly to the electronics?. What's their function? That transformer output puts out 5v ac.
    Im attaching the original schematic and also another one modified by me which is how I believe it should be, as there are non-clear crossings/connections that lead me to error
    Thanks in advance!
  • edugimeno
    • May 2017
    • 581
    • Spain
    Re: Help me understand this schematic (tape deck PS)
    Also, this is the link to the original's full service manual. LINK
      • 31285
      F1&2 are for driving a display heater.
      P-Mute is 50Hz pulses timed to match the mains.
      it may be used to time the powering of the speakers to avoid the "POP" sound.
      if P-Mute is missing it wont turn the outputs on.
      • edugimeno
        • May 2017
        • 581
        • Spain
        Ok, this clarifies a lot.
        Then, in the schematic, P.mute "brings" the positive pulses from both sides of the -12 and +12 block. This makes sense so far
        F1&2 ok, I didn't know of those heater but seems about right
        I still don't understand how the -24v gets generated with all that mess of componentes at the botton, zenners (one is 6.2v other is 24v), switching diode 1ss133 and resistors.
        Can anyone clarify? Just in case that getting new caps is not enough to fix it, I need to understand the rest of the board
        Thanks!!
        • R_J
          • Jun 2012
          • 9624
          The -24 volt circuit: C904 couples the AC from FU2 to the diodes D911,D912. D911 rectifies the ac and provides negative dc to C905 (R902 is just a dropping resistor). ZD902 clams the voltage to a negative 24v.
          ZD902 provides a small bias voltage to the filament circuit to raise them above ground ( prevents ghosting)
          Usually this random audio problem would be caused by an oxidized record/playback switch, this unit does not use one but does use a relay RL101. It's contacts could be oxidized and need cleaning (or replace the relay) When playing a tape and if there is no audio, just tap the relay a couple times and see if the audio returns.
          • edugimeno
            • May 2017
            • 581
            • Spain
            Ok, this all helps a lot.
            I see the relay "opens" the +12 and -12 lines to the main board, probably feeding op amps for general audio amplifiers, right?
            I will swap all those caps tonight and see if I still get no audio, check that relay as you mentioned.
            Thanks a lot!
            • edugimeno
              • May 2017
              • 581
              • Spain
              Mmmm weird thing, I just replaced all electrolityc caps on the PS, and no good
              Voltages measured at PS outputs:
              F1 and F2 -> ...AC
              12v -> 20v (too much, right?), But there's no regulation on board...
              POWER -> 0.18v...seems to little to switch the transistor on, but the relay is ON
              -12v -> -17v
              +12v ->17v
              -24v -> -21v
              P.Mute-> 12v
              I've checked the relay contacts and they seem to be fine. Continuity always from COM to NC side when power OFF, and continuity from COM to NO as soon as power is turned on until 2 seconds after it's powered off
              -24v is a little low, while all other PS's are way high...Should I check zenners? Board was a little darkened near R902...see attached.
              Oh wait, now that I see the photo... is DZ902 broken inside? Or is that normal?
              Any help would be appreciated!!
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8710
                Since there's no regulation, these are probably expected voltages, though -24 's absolute value is a little low...
                However you have a fairly high offset across the board, what are you using as your ground point? You're right, that transistor and hence relay should NOT be on with that few volts, you should check your measurements or perhaps that transistor is burned on (or .. hah .. dummy transistor like in the caterpillar ECU thread... LOL!)
                Are these the voltages when the deck is not working since you mentioned it was intermittent? These voltages seen should be acceptable to get at least some sound out of the machine I'd think.
                • edugimeno
                  • May 2017
                  • 581
                  • Spain
                  Those voltages were measured while the unit was on, and using the ps pin labeled GND as ground. It checked 0 ohm to other spots like chassis.
                  The transistor seems to be driving the relay correctly as the relay switches from NC to NO while powered on, and viceversa while powered off
                  At these times I have not been able to make it work (put out any sound) again
                  It did put out sound only the very first time after it was stored for years. I suspect there is some relationship between the specific fault and the fact that it worked only once (and continuously all the time for half an hour) the first time after years and then never again the next times in the same day
                  • petehall347
                    • Jan 2015
                    • 4448
                    • United Kingdom
                    will be high if relay not on .
                    but all unreg voltages high suggests high wall voltage .
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8710
                      I still think that these voltages will not cause an intermittent failure. It would cause catastrophic failure if any at all, but you're not saying so..
                      BTW which specific outputs are not "working" ... and motors spinning? Will it record if it won't playback and vice versa? Does Dolby NR selections make any difference?
                      Do you have small amplifier or oscilloscope you can probe with?
                      • edugimeno
                        • May 2017
                        • 581
                        • Spain
                        Re: Help me understand this schematic Harman&Kardon tape deck (TD470)
                        Yes, it looks like it works for the very first time after a long time unplugged. Or it was just coincidence.
                        What is missing is only the audio output (it's only PRE-amplified, it's a LINE OUT signal).
                        Motors are running perfectly, display counting back and forth, search function works, all buttons under the LCD work and toggle their action on the screen (dolby, mpx, counter reset...).
                        So basically all works (logic, controls, motors) but audio output
                        If I understood the mute function (does it mute when 12v is present? When absent?) I would probably be more able to diagnose it.
                        For now I don't know where to start....
                        Thanks!
                        • edugimeno
                          • May 2017
                          • 581
                          • Spain
                          Sorry I forgot other comments. PeteHall, wall voltage is fine, 230v approx, and this issue was present at the owners house months ago when he first found it faulty
                          Eccerror:, yes, I do have an amplifier (right now Im using a bluetooth speaker with external input) and I do have a digital oscilloscope
                          Thanks again
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8710
                            This narrows down the search space a bit as now we know it's not the tape side path.
                            When absent. Check the voltage at pin 10 of the 30-pin CN801, if it's 5V then P.Mute isn't the problem.
                            • R_J
                              • Jun 2012
                              • 9624
                              Your voltages are normal, See page 62 of the manual, WA501 +12v (17.4v) -12v (-19.3v) -24v (-23.3v).
                              There are two separate +12v. I would also check if your +9 and -9 volts are there. (Q612 & Q613) Can be checked on WA519 pins 1+ & pin3- Also check the + & - 6 volt regulator voltages (Q117 & Q118)
                                • 31285
                                if you have +/- 12v on the output then power-on is active, and the relay/transistor are fine.
                                and probably p-mute is good.
                                check all the connectors for cracked solder joints.
                                • edugimeno
                                  • May 2017
                                  • 581
                                  • Spain
                                  Checked, this pin has 4.5v both while playing and while powered off
                                  • edugimeno
                                    • May 2017
                                    • 581
                                    • Spain
                                    I've tried wiggling all the conectors and pushing everywhere on all the boards while the tape was playing and no change, no crack/noise/anything on the speakers
                                    • budwich
                                      • Jul 2015
                                      • 3097
                                      Thanks!
                                      if you look at the block diagram on page 10 of posted manual. Do you have a way input a signal to the input jack... something like a 1khz tone from a computer file or test cd or test tones from an audio receiver? You should see that signal coming out of the ic702 (dolby stuff) and going directly into the tape monitor relay which provides a "selected control" of whether you get the tape output signal OR the input signal coming out to the output jack. You should be able to scope for that signal somewhere near that relay. IF you get nothing there, then you can move back towards the ic702 to see what conditions it needs to pass the signal directly to the monitor relay.
                                      This may at least check the basic source audio path without any involvement of the tape.
                                      • edugimeno
                                        • May 2017
                                        • 581
                                        • Spain
                                        Yes sorry I found those numbers on the schematic after sending last question, I realized my voltages match those, yes, ty
                                        +9 and -9 are present (+8.5 & -8.5 specifically)
                                        Mmmm we might have something here...:
                                        Q117 has voltages around -6 on all 3 pins
                                        BUT Q118 only has voltage (close to +6) on collector. Nothing on base or emitter....
                                        Could this lead to all this lack of sound?
                                        • RetroComputingGrotto
                                          IBM LTO 7 Tape Drive - Dust Sensors??
                                          by RetroComputingGrotto
                                          I have a Quantum SuperLoader robotic tape library that uses an IBM LTO 7 tape drive which is constantly complaining that it needs cleaning. If you insert a cleaning tape, it performs the clean and resets the cleaning counter to 0 hours. It should only require cleaning every 50 or so working hours but after as little as just 1 hours use it requests cleaning. We've purchased a new cleaning tape along with new LTO backup tapes but that has not resolved the problem.
                                          I have taken the library apart and can see no noticeable signs of dust inside. I have removed the tape drive from the...
                                          09-19-2024, 01:54 AM
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                        • IamPritesh
                                          Help me understand this schematic about PROCHOT
                                          by IamPritesh
                                          Can you anyone explain what should be the ideal voltage for PROCHOT according to this schematic.
                                          I have no voltage on AD_IINP.
                                          On U8801 I have 5V on pin 5 and 0.537 volt on pin 3. No output voltage.
                                          Currently board is not triggering at all....
                                          02-23-2023, 03:24 AM
                                        • pecman
                                          Aiwa Z-R700 Music System has very low power when switched on, dim lighting and nothing works
                                          by pecman
                                          I was given an Aiwa Z-R700 from the 1990s era to look at by someone who said the twin tape deck did not work. The whole unit unit powered up ok but there was nothing from the tape deck. I had a look and found all the belts broken, I replaced the belts and then put the tape deck back into place and it still does not work. Also when I now power up the unit all the lighting on the front is very dim and the cd player and the tuner as well as the tape deck do not work. I have checked all the connections and ribbon cables again, there are no burnt or swollen capacitors. Maybe there are capacitors on...
                                          08-05-2025, 10:10 AM
                                        • triplefour
                                          LG 75UN8570AUD panel issue fixed with tape.
                                          by triplefour
                                          I've been seeing a lot of the new TVs (samsung and LG only i think) maybe 1-2 years old suffering from sudden panel death and have been over 50% successful bringing them at least most of the way back to functionality if not all the way, with the tape masking of the LVDS pins method.
                                          add this one to the list. the issue was on the left side of the panel and i ended up blocking just 3 pins on the connector that joins the two panel boards that make up the left side of the panel (it has 4 boards total) i didnt get the picture back to 100% perfect. i spent hours fiddling with which pins to block...
                                          07-17-2023, 10:22 PM
