Has anyone had issues with Rayovac Alkaline batteries leaking
    • Jul 2011
    • 6057
    I have had several issues with batteries leaking what is going on here
    I have emailed the company about this issue and I am waiting for and wanting a reply to this issue
    Because I have had a Fluke meter FC3000 battery terminal break and I have not yet found a replacement battery terminals for this model I found it for other Fluke meters but I do not know if they are the exact same battery terminals or not
    The email that I sent to the company is very detailed about the issue and that meter has been damaged because of this issue and a battery operated kitchen faucet was also had batteries leaking in the battery compartment which I cleaned but if it starts corroding then there is not much that you can do about it and this device is not cheap to replace
    I asked them what are they going to do about this issue
  • ron350
    • Feb 2014
    • 296
    Re: Has anyone had issues with Rayovac Alkaline batteries leaking
    Yep last year or the year before I had a pack of AA’s and a pack of AAA’s all start leaking about the same time.
      • Jul 2011
      • 6057
      Those are the same sizes that are leaking for me as well with an expiration date of 2028 and 2029
      • retiredcaps
        • Apr 2010
        • 9271
        Start using low self discharge nimh cells (AA and AAA) in your expensive equipment. Sanyo/Panasonic Eneloops are the gold standard, but it's rumored that Ikea Ladda Made in Japan nimh are made in the same factory and specs as Eneloops, but are much cheaper.
        I only use Eneloops in all my stuff now for the last 11 years. Zero leaks.
        One of my original AA Eneloops has been recharged about 1,500 (not a typo) times over the last 10 years and still holds 1800mAh+ (out of a max rated 2000mAh and min rated 1900mAh).
        --- begin sig file ---
        --- end sig file ---
        • redwire
          • Dec 2010
          • 3912
          Environmental regulations banning mercury in alkaline batteries, means they now off-gas and leak. Bitumen was also used for the seal and may have also been demonized and replaced with something crappy.
          For the dollars and hassle, I have changed over to Eneloops (Dell has them on sale sometimes) or Ikea Ladda which also seem to be good. Ladda I don't find them the same as the Eneloops and the lineup was changed this year, but anything is better than leaking Duracells.
          I use vinegar to clean out and neutralize the alkaline potassium hydroxide mess, then a water rinse. I find IPA does not work so good.
          There are replacement Fluke battery clips on fleaBay from china; translation called them "schrapnel" for some weird reason. Not sure what the FC3000 uses.
            • Jul 2011
            • 6057
            I did get a reply from my email about issues I am having with there batteries
            They want pictures of the devices in question
            They want pictures of batteries in question
            They want the pictures of damage to the devices in question
            They want pictures of the sale invoice or a link for the device from a company website
            They want to know what the device is used for
            And requesting to me not to continue to use the batteries in question
            I have sent them the information request that they are asking for
            • redwire
              • Dec 2010
              • 3912
              You need to know how much damage was done in dollars.
              I went through the process with Duracell and they freaked out with the dollar value of the multimeter. They don't know what to do when it's not a cheap flashlight or kid's toy or TV remote control. Expensive gear they think you are trying to rip them off instead of understanding cheap batteries can be in expensive situations.
              A lawsuit about leaking Duracell batteries as false-advertising, did not work unfortunately. I recently read California 4/2016 "A federal judge threw out a lawsuit accusing Procter & Gamble Co PG.N of misleading consumers by guaranteeing that Duracell batteries would not fail for 10 years, when in fact the batteries might leak when used or stored normally."
              "Judge Koh said reasonable consumers would understand that P&G's representation that the batteries were “guaranteed for 10 years in storage” was a warranty to repair, replace or refund batteries that failed within that timeframe, and not a promise that the batteries “have no potential to leak.”
              "She also said in her 33-page decision that the complaint did not identify any cause, including any design or manufacturing defect, as to why the batteries might leak."
              She didn't do a thing about damages. It's just stupid- all you'd get is replacement batteries and have no consequences to making junk product that leaks.
                • 31140
                i have had fucking duracell's leak while still sealed in the bubble-pack!!
                i wouldnt guarantee them for 10 months!
                  • Jul 2011
                  • 6057
                  Then is just bunch of crap and the guarantee does not mean shit so what do you do if nicad batteries do not work correctly in certain devices
                  Yeah you can buy 1.5 volt Li-Ion batteries but how do you good ones from bad ones
                  Because alkaline batteries are becoming more expensive and not lasting long enough anymore
                  Because I have a lot device that takes AAA and AA batteries
                  The AA batteries have the Li-Ion more options
                  The AAA batteries have the less Li-Ion options
                    • 31140
                    you buy cheap $ store alk's because anything beats durasell and keep an eye on them.
                    OR
                    you look at other technologies,
                    or you can use AA or AAA size lithiums and adapt the device.
                    • lti
                      • May 2011
                      • 2555
                      I've seen them leak while they were still on store shelves.
                      During one of their many marketing troll renaming stunts (selling a "longer lasting" model that was identical to the standard model), they switched to a cardboard box with a tiny window on the front, so you couldn't see them leaking until you opened the box. I think I posted about one of those packages having every single battery leaking inside it.
                      For poorly-designed products that don't work with NiMH batteries, I've heard that the Energizer lithium batteries are better, but I have seen them leak. The leaking ones were past the use-by date, so that could probably be excused.
                      • CapLeaker
                        Leaking Member
                        • Dec 2014
                        • 8286
                        the only alkaline that didn't leak even after 18 years not were made by Maxell. Like others, I switched from alkaline batteries over to eneloop, duraloop, fujitu, whatever eneloop rebrand made in japan and I don't look back.
                          • Jul 2011
                          • 6057
                          I am looking for 1.5 volt buck converter but have not had much finding any that have a small board
                          Can anyone please help me with this
                          Also who makes a good 14650 or 14500 battery I would prefer that they were made in Japan li-ion batteries
                          4.2 volts
                            • 31140
                            i have bucks that can go atleast down to 1.8v - you could try messing with the resistor values on one.
                            https://www.aliexpress.com/item/32842409405.html
                            i use these a lot - the pads match the pinout of a 78xx linear regulator
                            • CapLeaker
                              Leaking Member
                              • Dec 2014
                              • 8286
                              I use these Anyvolts:
                              https://www.robotshop.com/en/dimensi...regulator.html
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                RayOVac's in Fluke 189. See
                                https://www.eevblog.com/forum/testge...attery-leaked/
                                • mosfetratus
                                  Sure Not
                                  • Feb 2019
                                  • 174
                                  • Resistron
                                  OR
                                  Confirmed.
                                  duracell is pure garbage, they piss before expiring.
                                    • Jul 2011
                                    • 6057
                                    Originally posted by retiredcaps
                                    Thanks for sharing this post with there issue with this meter and batteries
                                    I have used these batteries in the past but I have noticed that they did last as long when I bought the second set of them a year or so later so I do not know if it is a quality issue or not
                                    https://www.ebay.com/itm/19340678632...QAAOSwn2legbsX
                                      • 31140
                                      those batteries, big clive did a teardown of the Jugee branded ones - very interesting products!
                                      there are also NiZN batteries - i think thats the chemicals anyway - they run at 1.5v but not many chargers support them.
                                        • Jul 2011
                                        • 6057
                                        I have bought the NiZN brand before and the first set of them were very good quality but when I bought them again the quality was not there anymore but I see that are some other brands making them I might give them a try again and see if they are any good or not
                                        KENTLI Batteries AA 1.5V 3000mWh Li-ion Rechargeable Battery + Charger I have bought these batteries before also and the first set lasted me about two years with medium use and my son used them in his X Box PlayStation remote all the time but when I went to buy another set of them the quality was not there anymore and not worth the money either
                                        But I see other brands that are having the same concept so I might give them a try and see if they are any better in quality or not
                                        • m1ch43lzm
                                          Replacing 2xAA / 2xAAA alkaline batteries with Li-Ion / LiPo battery?
                                          by m1ch43lzm
                                          Hi, i have this RadioShack IR thermometer Cat. No 22-170 which takes 2xAAA batteriss, I've tried with NiMH AAA rechargeables but it complains about low voltage, it flashes an "empty" battery and doesn't measure anything, even with freshly charged 2xAAA NiMH, so i have to "borrow" the batteries from my multimeter when i want to use it
                                          I'm thinking abour replacing the 2xAAA batteries with a small LiPo battery that fits inside that space, but the voltage would be too high (4.2v)
                                          I'm open to suggestions on whether i should use an LDO or another type of voltage...
                                          05-27-2025, 05:34 PM
                                        • howardc64
                                          Where do repair shops buy MB replacement batteries?
                                          by howardc64
                                          Order my parts from mobilesentrix.com and iPhone batteries have been excellent. Recently got 3x bad A1534 (2015) batteries. All would work until ~30-40+% and drop to < 10% instantly. Typical sign of cheap batteries.
                                          Perhaps the less popular A1534 model's aftermarket batteries are more source limited. Just find it surprising quality from mobilesentrix (usually fairly high quality aftermarket parts) have been so poor.
                                          BTW, this isn't the only defective parts I've had from mobilesentrix. Amongst others including iPad Air touch screen and A1989 touch bar (display was...
                                          07-25-2024, 10:42 AM
                                        • Astonished
                                          Fixing the Charge Circuit of the Batteries of the DC Motor
                                          by Astonished
                                          Hi friends of electronics
                                          What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                                          The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                                          Please help me fix this circuit.
                                          (the datasheet of the IC: https://pdf.datasheet.live/28...
                                          01-28-2025, 06:24 AM
                                        • carrzkiss
                                          Cyberpower cps1500avr not charging batteries
                                          by carrzkiss
                                          Hello, all.
                                          Cyberpower Battery Backup Unit.
                                          I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
                                          When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
                                          In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
                                          Checking the voltage, it was down to 22v.
                                          I quickly removed everything...
                                          06-15-2024, 02:10 PM
                                        • dbuergi
                                          DIY: Modified smart charger for all types of batteries
                                          by dbuergi
                                          sometimes i'm in need of a charger / tester for very small batteries and even if my multimeter doesn't show anything there is a chance that a smart charger helps to revieve. I'm happy with my Keenstone smartcharger and i made a small mod just to use it with smaller batteries like in smartwatches or even camera batteries with special contacts.
                                          Soldering wires on the charger contacts and using needles as probes. I covered both with a shrink hose with integrated solder.
                                          My first work was to bring my Samsung watch battery back to life with was not recognized...
                                          07-18-2025, 03:17 AM
