Trouble ID’ing C3 Cap.
  • Tommlynn49
    • Oct 2021
    • 3
    • Us
    This is a Jenn Air stove model # JMW8527 AAW. NO clock or temp. light.
    Disassembled and can see burn spot on one leg of the C3 cap. at the board hole. There is a resistor on that leg also. Only markings on the cap are: RGA105C and H245M. Can't seem to I'D as to the it's capacitance or voltage in order to order a new one. Any help would be greatly appreciated.
  • s675
    • Sep 2015
    • 35
    Re: Trouble ID'ing C3 Cap.
    Could be the Lelon RGA series.
    RGA = series
    105C = temp rating
    H245 = ?
    M = 20% tolerance
    Other Lelon RGA show things like H136 and H736.
    • s675
      • Sep 2015
      • 35
      Do you know the dimensions and lead pitch?
      • s675
        • Sep 2015
        • 35
        Here's the part number scheme I found. Doesn't seem to tell you anything.
        • R_J
          • Jun 2012
          • 9578
          Post a picture, I suspect the value is marked on the other side of the capacitor, similar to this one.
          • Tommlynn49
            • Oct 2021
            • 3
            • Us
            Thanks everyone. This gives me some guidance. I haven’t de soldered and removed the unit yet. As suggested, it may be labeled on the side I can’t see as it’s mounted horizontally and only exposes the upper top portion. I failed to mention, it is a Lelon. Many thanks again.
