SMD electrolytics
  • alfredo2j90
    • Oct 2021
    • 4
    SMD electrolytics
    Do SMD electrolytic caps have a shorter shelf life than aluminium electrolytic caps?
    • 31254
    Re: SMD electrolytics
    probably - read some datasheets
    • s675
      • Sep 2015
      • 35
      Just a somewhat related note that if an SMD cap doesn't have vent, it may still still be aluminium electrolytic and not polymer. Some people seem to think that no vent must mean that it is polymer.
      • Adenitz
        Replace electrolytic cap with bipolar one
        by Adenitz
        can I use this cap:
        https://www.tme.eu/en/details/ues1h4...tors/nichicon/
        Capacitor: electrolytic; bipolar; THT; 47uF; 50V
        to replace this capacitor: Electrolytic Radial E 47uF/50V 6.3x11 RM2.5 105°C Jamicon
        What exactly I can expect to install bipolar electrolytic cap instead a regular one?
        Thanks.
        02-02-2022, 07:44 AM
      • Perry Babin
        Derating of polymer electrolytics
        by Perry Babin
        There have been suggestions for derating polymer electrolytics to below the rated values. I've seen documents that recommended this and some that indicate that derating isn't required. The documents recommending derating are often old or refer to old documents. Do polymer caps of this type still require derating for reliability?
        If they require derating, why would the manufacturer give them their rated voltage?
        This is the basic type of capacitor I'm referring to and included simply to eliminate other caps that use similar names.
        https://www.mouser.com/datashe...
        10-24-2025, 11:57 AM
      • madscientist750
        Replacing electrolytic caps by solid caps on old motherboards
        by madscientist750
        I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
        I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
        I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
        10-19-2025, 06:10 AM
      • Perry Babin
        Electrolytic cap endurance
        by Perry Babin
        From what I've found, the endurance of a liquid electrolytic cap is determined by the loss of electrolyte. If a cap is rated for 1000 hours. That's typically for a straight run test. How would the life vary if the cap is intermittently heated to its rated temperature (105C). Maybe for an hour at a time then cooled back to 30-40C (just a random number). Would the life still be 1000 hours?
        Does it make a difference in the life expectancy if the cap is heating from ripple current (internal heating) instead of from the external ambient temperature?
        Why do polymer capacitors...
        10-18-2025, 05:21 PM
      • Perry Babin
        Lowest ESR capacitors, preferably liquid electrolytics but polymer also welcome
        by Perry Babin
        I'm looking for suggestions for electrolytics that are 10mm diameter and up to 25mm tall, through-hole radial capacitors with 5mm lead spacing. The value needs to be in the range of 330uF to 470uF. I typically use 35v caps due to their lower ESR vs 16v caps. Currently, the Panasonic FC is being used but the FM series is under consideration.
        This is for the primary side of a switching power supply in a car audio amplifier.
        Is there a way to calculate power dissipation in a capacitor to predict which will operate at a lower temperature? For example, a 470uF may have a...
        10-16-2025, 05:20 AM
