My Uni-T died... looking for a replacement
  • DanFen
    • Apr 2017
    • 201
    • Malta
    Hello people, hope you are all doing well!
    I have a lovely Uni-T UT139C, which I've used during the past couple years, but has unfortunately died on me. It comes up with an ErrE error, and upon a quick search, it seems to be related to communication with the main chip (or the chip itself).
    Putting it aside for the time being, I need a replacement (then possibly trying to repair this Uni-T later). And this is where I need your suggestions, because, I'm not an electronics person, but rather an IT one. I am occasionally doing basic electronic component repair to laptop boards, and occasionally trying to repair electronics on random devices for fun... time permitting!
    I'll be honest, the features of the UT139C are far from what I've ever used, and probably also far from what I will ever use. So my question is, which brand/model do you suggest for my needs? Unfortunately I've had a no brand multimeter that worked for years before the Uni-T, so I'm naturally questioning the reliability of Uni-T... although this could very well be bad luck (just like with any other machine).
    Thanks!
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: My Uni-T died... looking for a replacement
    Well the big thing is what you are willing to pay?
    The new Brymen BM789 (Or EEVBlog branded Brymen BM786) are very nice meters, more aimed at electricians.
    The Brymen BM869 is more for electronics work, both are really cheap for a top brand meter like this.
    Otherwise you can sometimes get really great deals on eBay for a bit older test equipment.
    Like this Fluke 27 that includes both high voltage & RF probes: https://www.ebay.com/itm/393592090990
    However note that I am in no way recommending this specific meter for you unless you have a need for it:
    It looks like military surplus and the US military sometimes uses average responding meters (not True RMS)
    And they are therefore of limited use outside that niche world.
    But Fluke even sells a version of this model to this day, called Fluke 27-II.
    If you need the TRMS version it is called 28-II.
      • 31131
      for electrical work?
      or electronics?
      your 139c has a bad or corrupt eeprom - very unusual to happen btw
      • DanFen
        • Apr 2017
        • 201
        • Malta
        Thanks! I'll have a look at those Brymen, never heard of that brand before.
        Definitely not worth paying hundreds in my case. Maybe the cost of these Brymen would be the max I'd pay. This is because I don't use the meter on a daily basis.
        Like this Fluke 27 that includes high voltage probes: https://www.ebay.com/itm/393592090990
        • DanFen
          • Apr 2017
          • 201
          • Malta
          Electronics. Yeah I read about it, I'll probably create a dedicated thread about this, hoping to find someone who will be willing to assist with troubleshooting
          or electronics?
            • 31131
            best meter for electronics IMO is UNI-T UT-61e (NOT the new mk2 version)
            very good price too.
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8285
              That's debatable… I'd be looking for a Brymen. Some Greenlee's are rebranded Brymen's over here.
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                sigh. My hacked Mastech (with a data logging port) died. Now where can I get another cheap DMM that has logging or easily hacked to log. Else I might have to hack my other meter (Tenma) with logging, but it's not as straightforward to log.
                • televizora
                  ghettomodmaster
                  • Nov 2016
                  • 957
                  • Bulgaria
                  Uni-T and MG and clones are not bad devices for their price.
                  Useful conversions. I don't "speak" imperial. Please use metric, if you want to address me.
                  1km=1000m=100000cm, 1inch=2.54cm, 1mile=1609.344meters, 1ft=30.48cm 1gal(US)=3.785liters, 1lb=453grams, 1oz=28.34grams
                  • madfreak
                    Which multimeter to choose : BRYMEN BM 869S OR UNIT UT18B PRO ?
                    by madfreak
                    Hello, there were probably topics like this, but I need opinions about these 2 multimeters or maybe there is another one on the market worth to buy ? .
                    I am going to change the multimeter and I do not know if the 2x higher price for Brymen will convert into speed and comfort of a work ...
                    What would you recommend?
                    Brymen BM869s or UNIT UT18B pro?
                    I care about accuracy and security, and the meter will be used for computer hardware.
                    Thank you very much in advance for your comments and suggestions
                    04-30-2022, 01:10 AM
                  • ngml
                    Repair of an LG split AC system indoor unit PCB
                    by ngml
                    I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
                    This indicates an error in the communication between the outdoor and the indoor unit.
                    The outdoor unit is fine, so the problem is the indoor PCB.
                    The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
                    I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
                    Does anybody have the schematics of this board,...
                    02-01-2025, 12:55 PM
                  • CoinCoin88
                    Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                    by CoinCoin88
                    I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                    Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                    Yesterday, 03:36 AM
                  • DrDos
                    Unit runs but no speaker output kenwood KR-6030
                    by DrDos
                    I have finished my work. The new lights come on except the one for stereo, I reversed the bulbs to no affect, anyway, the unit powers on, relay clicks. I have no DC voltage in speaker outputs, I also do not have any AC in the speaker outputs. There is some faint crackling in the speaker. This unit cranks up loud so I had the volume on very low. Everything seems to be fine but I can't really check the switch until I can get sound out of the outputs. I was going to do caps for the power supplys and the tone board but thought if it was cranking loud at one time maybe just leave it alone until it...
                    09-14-2025, 09:57 PM
                  • reformatt
                    Macbook Air M2 A2681 Kernel panics after screen replacement
                    by reformatt
                    Just had a customer bring in a M2 MBA A2681 that had had a screen replacement in April at another repairer. Since then, she has been getting intermittent kernel panics. It's an aftermarket screen, and of course it fails in diagnostics as the calibration hasn't been done. The error in the panic log is "No device added after powering on the rails".
                    It seems the original repairer has swapped the board and the screen to other MAC's, and said that it isn't a screen issue. From what I understand, by doing a quick search on Google, this is in fact a screen issue. The panic relates...
                    07-31-2025, 08:37 PM
