Dell E5440 completely dead
  • Andreasbest
    • Aug 2014
    • 1196
    • Hellas ( Greece )
    Hello!
    I got a Dell E5440 that is completely dead, charger doesn't detect any shortcircuit so remains lit when i plug it on laptop.
    No signs of life at all, i only detect some heat on PQ4.
    Plus PQ4 has 19v on pins 1,2,3 & 4 and only 1.8v on the other.
    I replaced it but no luck, same behavior.
    Any help appreciated, thank you in advance!!!
    Schematics and Boardview attached
    • 21907
    Re: Dell E5440 completely dead
    check PR14,PR20,PR21,PR533
    • Andreasbest
      • Aug 2014
      • 1196
      • Hellas ( Greece )
      Hello!
      Check resistance OR short to ground?
        • 21907
        resistance. Desolder and leave them on 1 pad to test
        • Andreasbest
          • Aug 2014
          • 1196
          • Hellas ( Greece )
          PR14 1MΩ
          PR20 10KΩ
          PR21 not present
          PR533 47Ω
          • Andreasbest
            • Aug 2014
            • 1196
            • Hellas ( Greece )
            bump
            • mielta
              • Apr 2015
              • 368
              Hi
              Check PQ400 and check short to ground on PR400
              • Andreasbest
                • Aug 2014
                • 1196
                • Hellas ( Greece )
                Originally posted by mielta
                Hi
                Hi and thank you
                Neither PQ400 or PR400 have short to ground
                I don't think there is a short to ground because charger remains lit when i connect it to MB, if shortcircuit occurred then charger would go immediately off.
                • mon2
                  • Dec 2019
                  • 14667
                  1) voltage @ PQ4 1-2-3 ?
                  2) voltage @ PQ4 (pin 4 = gate) ?
                  3) voltage @ PQ4 (pins 5-6-7-8) ?
                  4) Remove all power. Meter in resistance mode.
                  a) resistance between 1-2-3 (source) & pin 4 (gate)
                  b) resistance between source & drain (5-6-7-8) ?
                  c) resistance between gate (pin 4) & drain (5-6-7-8) ?
                  • Andreasbest
                    • Aug 2014
                    • 1196
                    • Hellas ( Greece )
                    1) PQ4 1-2-3 pins 19.5V
                    2) PQ4 4 pin 18.8v
                    3) PQ4 5-6-7-8 pins 1.87v
                    4) Done
                    a) PQ4 1-2-3 pins to GND 70KΩ & pin4 230KΩ
                    b) Source (black probe) to drain (red) 113KΩ
                    c) Gate (black probe) to drain (red) 323KΩ
                    • mielta
                      • Apr 2015
                      • 368
                      is it possible that PR21 has been lost.
                      Because PQ4 is a P-channel mosfet and the gate should
                      have about 10v. If PR21 were there it would form a voltage divider with PR14 at which about 9.5V would be. thus PR4 could switch
                      • Andreasbest
                        • Aug 2014
                        • 1196
                        • Hellas ( Greece )
                        The problem is that according to boardview the PR21 is not where it susposed to be, on both sides.
                        I'll upload photos of MB and screenshot of Boardview.
                        • mon2
                          • Dec 2019
                          • 14667
                          1) unable to view the posted .brd file
                          2) with PR14 removed, what is the voltage on GATE (pin #4) of PQ4 ?
                          • Andreasbest
                            • Aug 2014
                            • 1196
                            • Hellas ( Greece )
                            1) Have you try with Allegro? Needs some "refining" to show boards properly.
                            Here-> https://www.badcaps.net/forum/showpo...0&postcount=38 (thank you @Spider1211 !!! )
                            2) I'm away from the bench for some days, i'll check it Monday morning and let you know.
                            Check the boardview meanwhile and let me know if that worked.
                            • EP3RROR
                              • Jun 2015
                              • 13
                              • Ελλάδα
                              Had the same happen with one of two 5440 i had.
                              Never managed to get to the bottom of it.
                              i still have the board lying around!
                              • Spider1211
                                • Oct 2019
                                • 532
                                • Mauritius
                                Not necessarily. Check for short on all coils just in case and report back.
                                • Andreasbest
                                  • Aug 2014
                                  • 1196
                                  • Hellas ( Greece )
                                  Aloha Spider!
                                  I'll do it Monday morning and report back.
                                  • Andreasbest
                                    • Aug 2014
                                    • 1196
                                    • Hellas ( Greece )
                                    Hello again.
                                    PL5 one side is indeed grounded but i think is normal, all rest coils are fine, no shortcircuits to ground.
                                    • Andreasbest
                                      • Aug 2014
                                      • 1196
                                      • Hellas ( Greece )
                                      With PR14 removed i still get 18.8v on pin #4. No change.
                                      • Sephir0th
                                        • Oct 2020
                                        • 1289
                                        Hello again.
                                        Afaik PL5 should Show short to GND at both Sides. What is the internal resistance of PL5.
                                        FairRepair on YouTube
                                        • max-power
                                          Dell E6540 laptop completely dead after dssasembly
                                          by max-power
                                          Hi, I disassemble my laptop to replace the speakers, to access them, you have to remove everything including the heat sink and fan, unscrew the motherboard, lift it up a bit to access the speaker wire.
                                          that was not the first time I dissasemble it, i did replace the same speaker a few year ago and I repaste it last year, so I had nothing to worry about. but when I put everything back together, its completely dead.
                                          After a bit of investigating, i found one pin of the status led ribbon cable that was unglued from the cable and bend touching another pin, I bend it back at his place...
                                          03-24-2025, 08:49 AM
                                        • diamon
                                          Dell Latitude 5520 completely dead
                                          by diamon
                                          I have bought a not complete and defective Dell Latitude 5520 for parts (needed the networkconnector (RJ45) to repair a other board).
                                          Have repaired the other board (Dell Latitude 5540) and I wanted to know if I could find out what is wrong with the 5520 board (SouthPeak15 TGL MB 8L 19819-1) and perhaps repair this one also.
                                          After connecting the USB-C charger (both USB-C ports on the laptop, does not have an other option) and pressing the power button, nothing happens (no lights or fans, no capslock).
                                          Have checked with a thermal camera, and there are a couple of things...
                                          03-05-2025, 02:23 PM
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                        • gugutm
                                          Dell Latitude 5410 dead help please.
                                          by gugutm
                                          hi everyone,
                                          need some advice i am not professional just junior , but maybe someone could help me please
                                          i have
                                          Device : Laptop
                                          Brand : DELL
                                          Model : LATITUDE 5410
                                          Board Number: FDZ41 LA-J371P Rev:1.0
                                          i am attaching schematics and board view. [MOD EDIT] Link to schematic - https://www.badcaps.net/forum/troubl...14#post3484414
                                          my problem is its not turning...
                                          08-28-2025, 02:24 PM
                                        • Francesc V.
                                          Dell dockstation WD15 is dead
                                          by Francesc V.
                                          Hi:
                                          A friend gave me this DELL WD15 dockstation that does nothing. Not detected by computer, no digital output.........just leds shines when it’s plugged in.
                                          Here are the findings, followed by good pictures. :-)
                                          When pluged in, LED3 glows
                                          Measuring some voltage in the circuit.
                                          Inductors
                                          - PL202 has 5V
                                          - PL201 has 3.3V
                                          - PL300 has 1V
                                          V. Regulators
                                          - UT30 has 19v as input and 6V as output. It seems ok.
                                          - UT27 (same reference as UT30, has no input/output voltage).
                                          Thermal find...
                                          07-09-2025, 12:12 AM
