MacBook Air 13” 2015 A1466 820-00165
  • Dale65
    • May 2018
    • 14
    Hi everyone,
    I have a MacBook Air 13” 2015 A1466 820-00165 that started out booting to apple logo and would try to load then would just reboot . Now the fan is the only thing that will work but it spins and stops and maybe once every so often will stay spinning. The battery will charge and turn green from orange . The hard drive and processor will get pretty hot . I really can't see anything burned out and it never had liquid damage . I tried all the hot keys that where suppose to get it running with no success. Any help or ideas would be greatly appreciated.
  • mon2
    • Dec 2019
    • 14518
    Re: MacBook Air 13” 2015 A1466 820-00165
    hi.
    1) the hard drive on this model is solid state so you are referencing the SSD stick ? It may be warm but cannot see it being hot. Do you no longer see the display working with the usual boot logo and desktop ? The CPU may get hot if the cooling fan is not working or CPU heatsink compound is dry due to age. The heatsink for the CPU should also have a good contact with the CPU topside to allow for the proper heat dissipation.
    2) consider to power down and remove the SSD from the mating slot and power up again. Does this allow for the system to boot to display the flashing folder graphics ?
    3) next, power down and remove the keyboard and keyboard light from the logic board. Power up -> this should allow for the CPU fan to spin and the logic board should boot normally. What are the results ? Have seen where the trackpad caused excessive heating of the logic board. The trackpad had to be replaced. When you disconnect the keyboard cable, the trackpad is also removed from the equation as they are daisy chained together.
    4) be sure that the LCD display cable (LVDS) is properly seated inside the logic board connector. If you do not see a backlight, allow for the system to boot normally and place a flashlight on the backside of the display -> now are you able to see any of the usual graphics ? If yes, the backlight is not working.
    • jhayar18
      • Oct 2021
      • 2
      • NUEVA VIZCAYA
      try to restore your macbook sir
      • Dale65
        • May 2018
        • 14
        Originally posted by mon2
        hi.
        Sorry , Yes the SSD stick . It seems to get hotter than normal . No I don't see the boot up logo anymore. I also did try booting with ssd stick out and that did not help . I will have to give your questions 3 and 4 a try when I put the logic board back in the laptop . I had it out inspecting for any damage. I will post back what happens .
        Thank you
        • Dale65
          • May 2018
          • 14
          [QUOTE=jhayar18;1077349]try to restore your macbook sir[/QUOTE
          Wasn't able to do the restore . Nothing happens .
          Thank you
          • Dale65
            • May 2018
            • 14
            Thanks mon2 . I tried everything in your post but nothing helped . I have the battery out and the mag safe light goes to green to orange and the fan has been staying on but nothing else happens. Any more ideas ?
            • mon2
              • Dec 2019
              • 14518
              So now the fan is no longer pulsing on /off ? Stays on?
              Power down and attach the display. Power up. Does the fan turn on and remain on till you remove the magsafe adapter? For this test, do not attach the keyboard or trackpad. No ssd either. No battery, adapter only.
              Once the fan is confirmed to be on, allow the logic board to boot and apply a flashlight behind the lcd display (around the apple logo on the screen lid).
              Do you see the flashing file folder graphics icon?
              • Dale65
                • May 2018
                • 14
                Yes the fan powers up and remains on . The mag safe light is orange the fans running . I never seem to get a chime either and I don't see any folders with the flash light shining in apple logo.
                • Dale65
                  • May 2018
                  • 14
                  [QUOTE=Dale65;1077873]Yes the fan powers up and remains on . The mag safe light is orange the fans running . I never seem to get a chime either and I don't see any folders with the flash light shining in apple logo. I did find out if I have the keyboard connected the fan does continuously run but at a slower rpm's . Disconnected it runs at a lot faster. But not folders or chimes .
                  • mon2
                    • Dec 2019
                    • 14518
                    1) Is the CPU running cooler with the keyboard not connected? For now, leave the keyboard disconnected.
                    2) Voltage readings for:
                    (with the LCD connected)
                    a) SMBUS_SMC_0_S0_SDA
                    b) SMBUS_SMC_0_S0_SCL
                    c) PP3V3_S0SW_LCD
                    d) PP3V3_S0SW_LCD_UF
                    e) PPHV_S0SW_LCDBKLT
                    • piernov
                      • Jan 2016
                      • 4437
                      • France
                      If machine doesn't POST there's no point in troubleshooting image/backlight…
                      • mon2
                        • Dec 2019
                        • 14518
                        The magsafe light is orange with the system is POSTing and there is single wire communication with the Dallas authentication device.
                        • piernov
                          • Jan 2016
                          • 4437
                          • France
                          There's no relationship at all between POST and 1-wire circuit.
                          • yura8
                            Need BIOS/EFI dump for MacBook Air A1466 2015 EMC 2925 (8gb)
                            by yura8
                            Hi there! I have not so usual situation...
                            I have 2015 MacBook Air A1466 EMC 2925 with 8Gb of RAM. It seams that I've killed it by bad SSD adapter. It starts, cooler works... But no chime, screen is black. SMC reset seams works, NVRAM reset doesnt works...
                            My repair guy has checked all possible. It's all ok with power. The last idea - I could kill EFI firmware... So, I need a firmware of EFI to check it. I have a programmer. But I don't have a similar laptop now to download it and compare
                            P.S. If you have else any ideas about repair, or you had a similar...
                            12-20-2024, 02:31 PM
                          • dicorato
                            Macbook air 2015 - A1466 - PM_SLP_S5_L is 3.1v good?
                            by dicorato
                            I'm trying to diagnose this a1466 board, I'm pretty new with this, but I checked the signals up until PM_SLP_S5_L, which is at 3.1v. Is it a valid level for this signal?
                            11-18-2023, 08:25 AM
                          • psdavid65
                            Macbook Air A1466 820-3437-B Booting Problem
                            by psdavid65
                            I received a 2013 Macbook Air A1466 820-3437-B motherboard with serial number C02L6GQ9FSV8 that came in WITHOUT a bios chip. I got a new bios chip and reprogrammed it. Macbook now powers on but doesn't boot the SSD. I've flashed a ton of bios but still same problem. Windows installation works with this Macbook but never a mac installation. Unfortunately, since I didn't receive this macbook with a bios chip, I don't have the original bios. What can I do now?...
                            06-20-2024, 12:27 AM
                          • twonk9098
                            Macbook Pro mid 2015 battery required to boot?
                            by twonk9098
                            I have read many forums that state the Macbook Pro 2015 needs / does not need a battery to boot. I'm not convinced as yet which is correct.
                            The Macbook Pro mid 2015 I have has no battery and do not really want to buy one just to test.
                            This model has the newer trackpad which is not clickable when turned off.
                            At the moment, without battery it does turn on with no display (with backlight), no chime and then turns off after 13 seconds. I see this from the power draw on my DTPS.
                            If I hold the power button whilst connecting the magsafe 2 charger it turns on, again no image but...
                            12-10-2024, 06:51 PM
                          • Strolch
                            MacBook Air A1466 2015 no Power on
                            by Strolch
                            I have a MacBook Air 2015 2.2GHz i7 A1466 820-00165-A. It had worked normally. Now it doesn't start anymore. When Magsafe is plugged in, the LED will turn solid green and then orange. I can also do an SMC reset. But you can't turn it on.
                            03-18-2022, 11:02 AM
