Go Back   Badcaps Forums > General Topics > General Computer & Tech Discussion
Old 10-15-2021, 09:10 AM   #1
shovenose
Send Doge Memes
shovenose's Avatar
City & State: Fairfield, California
I'm a: Forum Junkie
Default Win 10, Multi-Monitor Wallpaper Help
I've spend the past 15 minutes fiddling with wallpaper settings to no avail.
I have three monitors set up like so (see attachment). Monitor 1 is on top then 2 and 3 on the bottom. 1 is centered over 2 and 3.
I want the top one to have a solid black background (which I can do using a picture, that's fine, since Windows will only let you use solid color mode or picture mode not both) and I want one ultra-wide image spanned across the bottom two monitors. Unfortunately, span mode includes the top monitor.
I'd prefer to avoid third-party software, but I have a license for DisplayFusion somewhere if needbe. Just hoping I can do this with Win10's built-in stuff.
Thanks!
shovenose is offline   Reply With Quote
Old 10-20-2021, 06:09 PM   #2
momaka
master hoarder
momaka's Avatar
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
I'm a: Hobbyist Tech
Default Re: Win 10, Multi-Monitor Wallpaper Help
Hmmm... well this may be more of a workaround... but how about split the ultra-wide image into two and set each half to its proper side?
I know - extra work when you want to change backgrounds... should work, though.
Old 10-20-2021, 08:22 PM   #3
shovenose
Send Doge Memes
shovenose's Avatar
I'm a: Forum Junkie
Absolutely brilliant solution. Can't believe I didn't think of this. THANK YOU
Old 10-22-2021, 10:25 AM   #4
ratdude747
Black Sheep
ratdude747's Avatar
City & State: Madison, IN
Line Voltage: 120VAC 60Hz
I had a similar issue at Church when I set them up with an Windows 10 Acer box for the AV system (1280x1024) where the 2nd screen (AV-system input) needed a black background, but the higher resolution front screen I wanted to have something other than black (like the two AV Macs were already set up, since OSX can do that natively). I ended up collage'ing the image I wanted (which was the exact same resolution as the main screen) with a black box 1280 pixels wide in GIMP, and used that for a background. Worked fine when spanned across both displays.
In your case you could probably do the same thing... just make sure everything's in the right spot (in the collage you're making) and shazam.
(Insert witty quote here)
ratdude747 is offline   Reply With Quote
Badcaps.net Technical Forums © 2003 - 2022
