Motherboard recap issue
  • NickLoC
    • 80
    I have done recaps on motherboards before and had no issues. A few years ago I "upgraded" my soldering equipment. I had an old Radio Shack iron. Upgraded to the digital station and a new hand held iron. Now I have nothing but issues. No matter what I try, I cant seem to get the caps to budge on some boards. Last one was a dell motherboard. Caps refused to budge, even with a large solder gun. Wondering what solder station would be best for this? Only want to spend around $100. Looking at a Trakpower TK950 or a Hakko Digital FX888D. I am hoping this will help to solve my issues. Never had an issue until using these newer irons.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Motherboard recap issue
    What did you upgrade to?
    I have the FX-888 (analog), but I don't do a lot of motherboard desoldering so I can't comment how well it will work on 4+ layer boards with large copper planes.
    --- begin sig file ---
    --- end sig file ---
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      Depending on when you are talking about it may not be just that irons are not as good, it could be some years ago you were working on boards with leaded solder whereas if you are now working on newer boards they will have unleaded solder which has a higher melting point. Also at some point I believe they started making boards a little bit thinner then had to add metallic lines to make them stronger.
      This leeches away the heat. Now when using the iron I work in a warm room and pre heat the board with a hairdryer.
      Its great in winter
      @ retiredcaps - Happy new year.
      • Uniballer
        • Jul 2013
        • 334
        I have used an FX-888D to recap motherboards. It works fine with the right tip, e.g. T18-D32 which is a 3.2mm chisel tip. A smaller tip (such as the T18-D16 1.6mm chisel tip that comes with it) may have a harder time moving enough heat. Of course, you also need to keep the tip clean enough and tinned properly to move any heat at all.
        • NickLoC
          • 80
          I am using the radio shack digital soldering station. Properly cleaned and tinned the tip. Just seems to lack enough heating power even turned up all the way. My old radio shack iron was much better. Will more than likely go with the FX-888d. May need to start pre-heating the board. I do have a heat gun.
          • tron
            • Apr 2009
            • 47
            put some leaded solder
            to the rohs-joint beforehand
            cap removal and
            no preheating
            will be required.
            • dj_ricoh
              • 2073
              • uk
              once you use weller you`ll never go back
              • NickLoC
                • 80
                I read the reviews on the weller solder stations. Lots of people had issues with the newer ones. Was going to go with one, but after the reviews I decided not to.
                • tron
                  • Apr 2009
                  • 47
                  radio shack 25w iron
                  with
                  conical(default) tip
                  will get you nowhere
                  FX-888 with chisel tip
                  will lead somewhere
                  where it is possible
                  to solder and
                  de-solder
                  comfortably
                    master hoarder
                    • May 2008
                    • 12175
                    I think you just need to get some flux. That stuff makes a night-day difference with any iron/station I've used. I will now refuse to solder unless I had some flux (or unless it's some emergency fix).
                    • dj_ricoh
                      • 2073
                      • uk
                      get a used one!
                      the guy who had time to teach me a few things about electronics had one, before i came to him and i was around him about 4-5 years.
                      i can tell you this. he always kept it on. that was bad because he bought alot of tips.
                      just before i came he bought a new iron cuz the old one was going on for a couple of years.
                      I got a crap 60W to main wall iron about 15-25 GBP and a gordak station( i can put a small tip on it)
                      but at the end of this month i will get that ws 51 weller; believe me there is now iron can compare to that weller.
                      I can say only thing when you get used to a iron that is magnetize and you will never use a Wick or a pump that`s precious.
                      Good luck!
                      • tron
                        • Apr 2009
                        • 47
                        weller is average, nothing
                        exciting like Metcal or JBC...
                          master hoarder
                          • May 2008
                          • 12175
                          I agree.
                          For those of you who think Weller is nice, wait until you try JBC. I had the chance to use one of their stations and that thing really is the Rolls Royce of soldering stations. Not to mention it never struggled to heat anything. You could probably melt all of the ice in the South pole with it if you tried.
                          • NickLoC
                            • 80
                            Thanks for all the advice. I think the fx-888d looks like a good fit. I know there are better stations out there, but this is a side job, so around $100 is good. The radio shack iron I used was not 25watt. It is a 60 watt. I am a firm believer that things aren't made a well as they should be. It's a lot harder to find well made stuff at a decent price. It will be nice to do a repair and not have to fight with my tools.
                            • retiredcaps
                              • Apr 2010
                              • 9271
                              Happy Belated New Year.
                              As you may have noticed, I don't participate regularly in certain areas anymore. I'm spending my time learning and test and measurement equipment over at eevblog.
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                When I finally decided to upgrade from sort by lowest price 40W 120V AC soldering irons on ebay (usually $4 USD + free shipping), the difference in price between the FX-888 and some Hakko clone was "only" about $30 CDN.
                                With the ever little soldering I do now, I fully expect the FX888 to last my lifetime so spending the extra $30 was a no brainer for me.
                                Now if the FX888 was in the $500 category, I would have bought a $60 Hakko ebay soldering station knockoff.
                                I suggest getting a 3.2mm chisel tip for desoldering.
                                PS. Dave Jones' teardown of the FX888 also convinced me to spend a few $$$ more so my house doesn't burn down to cheap incorrectly wired knockoffs.
                                • SteveNielsen
                                  Retired Tech
                                  • Jun 2012
                                  • 2327
                                  I bought a RS Pro-Line 70W station on sale for about $50 and it is no good for recapping motherboards even using a Hakko 900 type 2mm chisel tip (which is a close fit but the cylinder of the tip that goes over the element is 2mm longer on the inside length). It is rated at 70W but that energy isn't making it to the element or tip and it certainly does not achieve it's max temp of 480c +/- 5%. It is absolutely useless for laminated motherboards.
                                  I used a Mastech MS8264 meter (accurate within 1% up to 400c, 2% up to 1000c) to measure tip temp using the conical tip supplied with the unit. My readings were:
                                  Setting/Actual temp
                                  480c/388c
                                  400c/328c
                                  300c/244c
                                  200c/137c
                                  Using the Hakko 2mm chisel tip it got up to 420c when set at 480c (max) and 155c set at 200c (min). Not even close to the rated +/-5% tolerance. I did open up the controller and could not find any calibration adjustment. Out of the box it is a $50 disappointment for sure. I'm shopping for a better unit and chock this one up to experience.
                                    • Jul 2011
                                    • 6069
                                    Dose Hakko use a switch power supply to the controller part of this iron
                                    • Uniballer
                                      • Jul 2013
                                      • 334
                                      Judging by these teardown photos of the 230V version I would say no. Does it matter?
                                      • Uniballer
                                        • Jul 2013
                                        • 334
                                        Is this the station you bought? If so, temperature alignment procedure is on page 6 of the manual. Also, I think for measuring tip temperature it matters that you have a good blob of hot solder between the tip and thermocouple for good heat conduction. Unfortunately, this might wreck the thermocouple for your meter, but it is the standard procedure for the Hakko FG-100 (I have a cheap ebay clone of one of those and it seems to work OK).
                                          ASUS P5GC-MX motherboard recap
                                          by momaka
                                          Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                                          This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                                          So here is what the motherboard looked like with its original caps:
                                          CPU VRM area up close…...
                                          01-27-2021, 11:59 PM
                                        • Docus
                                          Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
                                          by Docus
                                          Hi everyone 😀,
                                          I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
                                          To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
                                          Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
                                          1. I already own the exact same model, but its plastic chassis is badly damaged.
                                          06-10-2025, 04:24 PM
                                        • MakNCheese
                                          ASUS Zephyrus GA401I Severe Lag, Suspect Motherboard/Power Issue - Need Help Diagnosing
                                          by MakNCheese
                                          I'm having a serious issue with my ASUS Zephyrus GA401I (4 years old, worked perfectly until recently). The system is lagging heavily, even in the BIOS, and is charging extremely slowly (a few percent in hours), making it nearly unusable. I suspect a motherboard or power delivery issue.
                                          Symptoms:
                                          • Severe lag across the system, including BIOS navigation.
                                          • Slow boot times and unresponsive performance in Windows.
                                          • Battery charges very slowly (e.g., ~5% in 2–3 hours).
                                          • No error messages or BSODs, just extreme sluggishness.
                                          What I've Tried:
                                          • Replaced
                                          06-04-2025, 12:48 AM
                                        • fixme2024
                                          Intermittent Power Issue with HP DV6 Motherboard Occasional Failure to Turn On
                                          by fixme2024
                                          Hello everyone, I have an HP DV6 DAOLX6MB6F2 REV: F motherboard. The issue I'm facing is that sometimes the motherboard doesn't turn on. I've checked the voltages for the power on button panel, and they seem to be okay. Right now, it's working perfectly fine, so I can't pinpoint the exact problem. I have the HP DV6-DV7 Quanta LX6_7 (Liverpool) DAOLX6MB6F2 Rev 1A.pdf schematics, a multimeter, and a 5A power supply. If anyone could guide me on where to start checking first, I would greatly appreciate it. This is my first experience with this. Thank you.
                                          Here, I have attached a document...
                                          02-14-2024, 09:24 PM
                                        • varunviolin007
                                          Looking for someone to recap Dell XPS T450 motherboard (Live in suburbs outside of Philly)
                                          by varunviolin007
                                          Hi guys,
                                          I’m looking for someone in the Northeast to do a full electrolytic capacitor recap on a working Dell Dimension XPS T450 motherboard (it's an Intel 440BX, Slot 1). The board runs mostly fine but is beginning to freeze after warm reboots (turns back on for 30 secs or so and then freezes up but is perfectly fine after 12 hr cool down).
                                          I’d be sending just the bare motherboard (CPU, cards, bracket, battery all removed). I’m located in Chadds Ford, PA and happy to ship within the US.
                                          Looking for someone experienced with older PC boards who uses...
                                          07-29-2025, 11:53 PM
