Recommended BGA Rework Stations
    Hello Community,
    Based on your experiences and knowledge, which BGA Rework stations would you recommend for general use for an enthusiast at the low-mid-to-high price range? Based on what I've seen, £6000 may be considered high. I particularly like those with adjustable focus, built-in suction and ball alignment features, but I appreciate that they may be on the high end.
    Also any thoughts on the PUHUI T-862++ IR Rework Station, LY GXX models, WDS-XXX models?
    I forgot to add that for general consumer electronic repair, I am better off getting an IR or hot air rework station.
      £6k might be high end for home/shop use, but not for professional industry rework stations, they go up to, high 5 figure prices.
      The PUHUI T-862++ IR is 800W total. Ok for small boards like in a phone but no good for TV boards, consoles or laptops.
      When reworking, ideally the whole board needs heating whilst the processor gets extra heat from above and on the more expensive rework stations the bottom. Ideally 3 zone is what you want for more precise temperature control.
      Northwestrepair on youtube just uses a modified t8280 bottom heater and a cheap hot air station to reball GPus and memory. A member on here used a modified toaster oven for bottom heat.
      I personally have a Scotle IR BGA machine. It's only 2 zones, but for the work i do on it it's fine.
        Thanks, Diif! I didn't realise they could be that expensive. I've seen work by that YouTuber. While I lack that skill level, you have me thinking I can get by with something modest for general electronic repairs. Might I ask if you were to get yourself one today, what would you go for (around the price range of 0-$1000)?
        I am considering this one now, considering your advice on the low power of the PUHUI.
        Here
