Soldering help.
  • Hornnumb2
    • Feb 2011
    • 218
    Soldering help.
    I am at my wits end trying to get these 2 hole clear. The other 2 holes no problem. I tried low melt, hot air, wick and my solder sucker gun. One hole still has the pin in it. I have my iron up to 450 with a big tip, hot air turned up to 500. Any suggestion? Thanks Michael
    And by the way it took me 10 minutes to find the login button, it sure needs to be a brighter color or something.
    • 31254
    got a picture or 2 of the board?
    • Hornnumb2
      • Feb 2011
      • 218
      Already stuck back in vehicle waiting on relay for it. It’s a fuse block out of a Silverado, only things on board are a bunch of fuse terminal and 5 or 6 relays soldered on.
        • 31254
        you need a big iron and a stainless-steel needle - to poke in the hole when it's heated.
        • petehall347
          • Jan 2015
          • 4440
          tap it if possible . solder should jump out of hole
          • harp
            • Jun 2022
            • 642
            • Planet Earth
            Remove board from houseing, remove all heatsink and all removable elements, connectors, wire... then wrap arround whole board with thick cardboard hard paper (from cookies) to reduce loosing heat by air moving.
            • Aliencomputres
              • Aug 2019
              • 218
              • România
              use hot air+solder simultaneous.
