Help with hot air station
  • audiofreak19
    • Apr 2013
    • 556
    • usa
    So I'm trying to solder a as15-f onto a tcon board. I removed the old chip. Put solder paste across the pins and sat the new ic on top and positioned it. I had my rework station up to 400 degrees F. And air at 15-20. As I wave it around the chip I see the solder paste start to flatten out but it never actually melts into solder and goes on the pins. What am I missing with doing this.
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: Help with hot air station
    400 deg F is too low. You want 400 degrees C as read by the station. That, at 1cm away it will be 320C at most, which is perfect.
    Think of it this way: Lead solder melts at 183C, but you always have to set the iron to at least 300C to get it to melt, because thermal transfer between the tip and the solder will never be 100%. Same goes for hot air.
    A working TV? How boring!
    • audiofreak19
      • Apr 2013
      • 556
      • usa
      Yea thanks. The whole Celsius to ferinheight conversion threw me off. I bumped it up to 700-750 ad worked like a charm.
      • cdicky
        • Jul 2014
        • 27
        • England
        But did your T-con board ever again ??
        What make of paste do you use? Do you not like self clean rosin etc?
