ESR meter upgrades
This is a sticky topic.
    Re: ESR meter upgrades
    Originally posted by Per Hansson View Post
    Yes
    For the extra money i wish i ordered this now
    http://www.ebay.co.uk/itm/2221248490...%3AMEBIDX%3AIT
    if i get a refund for my kit i will purchase one of these then i can send the values too you etc.
      Cheers!
      Do note that the original seller you bought from (At least the one you linked to originally)
      Also sells it assembled.
      So he really should be able to get you either a schematic or at least a picture of it assembled
      http://www.ebay.com/itm/2016-EZM328-...-/331800111900
        Cheers!
        ive emailed the seller a few time all he says in the return messages is "so you cant weld this" i think he means solder it and he has no schematic ive asked twice and to confirm one of yesterdays post i made
        sorry about the confusion (was one of those days yesterday nothing went rite) i misscounted the ebay picture and now just re checked the kit all again yes there are 24 spots on my pcb and 24 resistors fitted on the ebay picture yes just counted ny resistors again 23 plus 1 zero ohm (which isnt shown in any ebay pictures) but without any schematic im still stuck anyway.
          Ok, incase you did not notice the picture in his eBay AD is not of the item he sells.
          They are watermarked "kiss_buy".
          That seller does have the same meter for sale, search for "ESR 2016" in his eBay store...
            I hope the banggood kit has instructions!
              Thanks i have just noticed that too.
                which kit did you go for have you got a link.
                  http://www.banggood.com/DIY-M12864-G...-p-997023.html
                    if you look really closely at the pcb you can see it has the parts printed on it so your fine with that kits thats a good price too i keep forgetting about that site.
                      Good point!
                      Thanks.
                        post pics of both sides of the pcb that are good enough to see all the tracks clearly.
                        i'll work it out for you.
                          stj if you mean mine i will post some asap as light here at the minute is too bad too take any good ones, so bear with me thanks.
                            i almost finished the pcb stuffing list,
                            verify something for me.
                            x2 110 ohm
                            x1 5.6k
                            are you sure about those - specially the 110ohm - is it actually 1k?
                              x1 5.6k measures 0.56 on 20k scale
                              x2 110 ohm measure 1k my mistake sorry
                              x1 2.2k is 2.2k (im not sure if i wrote this as 2.2ohm)
                                wouldnt .56 be 560ohms?
                                  Resistor colour GREEN BLUE BLACK BLACK BROWN cheers for your help stj just checked using hobby -hour calculator 560 ohms
                                    thought so.
                                    in that case - go build it!
                                    r1 - 680r sensing circuit
                                    r2 - 470k sensing circuit
                                    r3 - 680r sensing circuit
                                    r4 - 470k sensing circuit
                                    r5 - 680r sensing circuit
                                    r6 - 470k sensing circuit
                                    r7 - 10k reset pullup
                                    r8 - 33k power control
                                    r9 - 3k3 power control
                                    r10 - 27k
                                    r11 - 100k (says r1 but is next to r10)
                                    r12 - 10k voltage divider for battery sense
                                    r13 - 3k3 voltage divider for battery sense
                                    r14 - 560r display related - led current limit
                                    r15 - 27k
                                    r16 - 0r jumper for AVCC
                                    r17 - 2k2 from tl431 to vcc
                                    r18 - 1k rotary encoder current limit
                                    r19 - 1k rotary encoder current limit
                                    r20 - 10k rotary encoder pullup
                                    r21 - 10k rotary encoder pullup
                                    r22 - 470r frequency input dropper
                                    r23 - 10k frequency input voltage divider
                                    r24 - 10k frequency input voltage divider
                                    rv1 - 10k preset frequency input voltage divider
                                    u3 = tl431
                                    q1 - 4673 (bc557c)
                                    q2 - c945 (bc547)
                                    q3 - c945 (bc547)
                                    c1 - 22pf for crystal
                                    c2 - 22pf for crystal
                                    c3 - 100nf
                                    c4 - 10nf
                                    c5 - 10uf 16v
                                    c6 - 10uf 16v
                                    c7 - 100nf
                                    c8 - 100nf
                                    c9 - 100n frequency input DC blocker
                                      thought so.
                                      r10 - 27k
                                      r15 - 27k
                                      u3 = tl431
                                      q1 - 4673 (bc557c)
                                      q2 - c945 (bc547)
                                      q3 - c945 (bc547)
                                      c3 - 100nf
                                      c4 - 10nf
                                      c5 - 10uf 16v
                                      c6 - 10uf 16v
                                      c7 - 100nf
                                      c8 - 100nf
                                      Big thanks for your help stj i wont be able too get back too this project untill early next week as going down the coast to visit dad (fathers day) suprise etc if weathers nice may spend a few extra days but will update this thread when built.
                                        sorry i forgot too post this yesterday
                                        c5 and c6 are 100uf 25 volts in the kit
                                        then i have x4 104j
                                        x1 103j
                                        cheers again stj for your help
                                          16v was a minimum figure,
                                          104 = 100nf
                                          103 = 10nf
