Re: ESR meter upgrades
yea, but put a fet or a transistor with reverse-diode in it and see how much text it has to display!
when you flash it each time, is it forcing you to calibrate it by shorting all 3 lines and then fitting a small film cap?
because it should.
if not then your problem may be residual crap in the eeprom because you must erase the chip before you program it.
because it should.
