Need help on Fluke 87-III mainboard repair
  • theOracle
    • Nov 2012
    • 163
    Hi there!
    I replace caps for a living, but recently decided to try and fix a multimeter I picked up at a yard sale:
    Fluke 87-III
    It is in surprisingly good shape, needs a new battery door and case perimeter seal, seller told me it was operating intermittently.
    so I took it apart and two components are burned which I believe are the following:
    U1 - diode, SI, rectifier, bridge (4 pin chip) -burned beyond recognition (on regular 87 - this chip is BV=50V, IO=1A, p/n DF01M - not sure on 87-III)
    CR1 - diode (marked LTp01 S1G) - (1N4007 is used on regular Fluke 87)
    and one of the mainboard traces connecting those is lifted off, will need to be replaced with heavy wire I reckon
    everything else looks great including beautiful white backlit display
    apparently, some Beavis used cheap fuses rather than the correct Fluke/Bussman fast-blow and then tried to measure high voltage with the cables plugged into amps jack
    any advice on what components I might want to order at digikey? - or just any general advice?
    I fix engine computers (ECU's) so I have pretty good experience and equipment including Hakko FM-202 solder station as well as Hakko 850D hot air rework station.
    This meter also needs a good battery door and it especially needs the main rubber seal around the perimeter of the case if anyone has an extra used one. (I have PayPal!)
    thanks!
    __________________
    the BIG 4
    ~~~ the top tier of low-ESR electrolytic capacitors ~~~
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Need help on Fluke 87-III mainboard repair
    Do basic functions like volts and ohms work fine? Are measurements close to another known good multimeter?
    I don't have a Fluke 87 III (would love to have one again some day), but others do and may be able to contribute some info. I may have some high resolution pictures saved somewhere? I will have to look around.
    Let's see a picture of it and where it is on the board.
    The latest versions had the white backlight whereas the earlier versions had a green one.
    Yup, they need to be the proper fuses.
    Once the components are identified, clean the area with a generous amount of IPA and remove any carbon residue as it conducts.
    I see them on sale once a while on ebay. At $30 USD, it is way too expensive for my liking.
    http://www.ebay.com/itm/252355795852
    --- begin sig file ---
    --- end sig file ---
    • theOracle
      • Nov 2012
      • 163
      here are my candidates: (based on Fluke 87 info, not 87-III)
      for the bridge rectifier chip
      for the diode
      __________________
      the BIG 4
      • retiredcaps
        • Apr 2010
        • 9271
        On my Fluke 85 III, I have DF06S. 47 cents at digikey.
        http://www.digikey.com/product-detai...SCT-ND/3042771
        This is 600V vs 100V used in the original Fluke 87.
        For the diode, I have a backwards c ii 214 on the top line and S1B on the bottom line.
        I will have to search for this code. I don't know who makes that backwards c ii symbol?
        • theOracle
          • Nov 2012
          • 163
          I think if I could just find a service manual for 87-III and a case perimeter seal and a battery door, I would be all set!
          __________________
          the BIG 4
          • retiredcaps
            • Apr 2010
            • 9271
            for the diode
            Your choice of S1M is rated at 1000V maximum repetitive reverse voltage. S1B, in my Fluke 85 III, is rated at 100V.
            • retiredcaps
              • Apr 2010
              • 9271
              You won't find a service manual with a BOM or schematic for the 87 III.
              • retiredcaps
                • Apr 2010
                • 9271
                According to pictures in this thread.
                http://www.eevblog.com/forum/repair/...ii-misbehaves/
                Picture P1120655 shows a S1G which is 400V maximum repetitive reverse voltage and DF06S as well like my Fluke 85 III. That matches your post #1 part.
                • theOracle
                  • Nov 2012
                  • 163
                  I don't want to even say what I think of that, given the $$ we engineers and techs have spent on Fluke over the years, but pathetic is not a strong enough word.
                  __________________
                  the BIG 4
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    In today's world, virtually no manufacturer, Fluke, Keysight, Chinese brands, etc gives out schematics or service manuals anymore.
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      Don't I'm super tired and didn't even notice the S1G in post #1. Doh!
                      • theOracle
                        • Nov 2012
                        • 163
                        what is significance of S1G ?
                        and are my selections at Digikey ideal?
                        __________________
                        the BIG 4
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          Picture P1120655 shows DF06S.
                          • theOracle
                            • Nov 2012
                            • 163
                            I have a rule on new equipment procurement:
                            no schematic, BOM, component locator diagrams, and calibration procedure = NO SALE!
                            __________________
                            the BIG 4
                            • retiredcaps
                              • Apr 2010
                              • 9271
                              The last letter denotes maximum repetitive reverse voltage. I would stick to the original that is in the meter and avoid any "upgrades".
                              In post #4, I gave you the link to DF06S. So buy S1G and DF06S from digikey and you should be good.
                              • theOracle
                                • Nov 2012
                                • 163
                                thanks for EEVBlog pics - that is exactly the meter I have!
                                __________________
                                the BIG 4
                                • retiredcaps
                                  • Apr 2010
                                  • 9271
                                  Once you order the parts and get them installed, please report back to see if current measurement works or not.
                                  I hate it when there is no resolution one way or another (it works or it doesn't work).
                                  • Mirenia
                                    Dell Latitude 7420 - Touchscreen not working since Mainboard replacement
                                    by Mirenia
                                    I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
                                    I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
                                    In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
                                    The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled...
                                    03-30-2025, 06:47 AM
                                  • orcic
                                    MASTER TL240 and new mainboard LW36BKC01
                                    by orcic
                                    I have an old MASTER TL-240 LED TV. Since it stopped working and it had a DVB-T receiver that is being dismissed in Italy, I've decided to replace the mainboard with a DVB-T2 one.
                                    The original problem was that when switching on the TV, the power LED was transitioning from red to steady blue, without showing video or audio.
                                    After checking some voltages on the power supply board (HKL-240101-B Rev. 1.4, HKL from now on) someone suggested me to replace the mainboard.
                                    Now I have some doubts about how to connect the new mainboard to the old power supply.
                                    First of...
                                    05-12-2023, 08:10 AM
                                  • Devonavar
                                    Vizio M43-C1 - How closely do I need to match the mainboard number?
                                    by Devonavar
                                    I have a Vizio M43-C1 stuck in a reboot loop with no backlight.
                                    I've tested all the voltage rails coming out of the power supply and they are "normal" for this model (PS_ON & DIM go high when turned on, BL_ON & 3D_ON are close to zero due to backlight power flowing through the mainboard, 5VSB is 5V, and 12V is 19V, which is apparently normal for this board).
                                    Basically, I get similar results to Garry in this post: https://www.badcaps.net/forum/showthread.php?t=80346
                                    So, I've ruled out the PSU for now.
                                    The reboot loop...
                                    08-14-2022, 08:46 PM
                                  • Malva
                                    Problem LG 49UB850V (Mainboard: EAX65684604 / EBT62954607)
                                    by Malva
                                    I'm trying to repair my LG 49UB850V TV (WebOS 1.0, UHD model from 2014).
                                    Mainboard model: EAX65684604
                                    PCB marking: EBT62954607
                                    SPI chip: Winbond W25X20CLNIG Problem description:
                                    Originally, the TV would turn on (backlight and LED OK if I force them on), but it shut down as soon as any input was received from the IR sensor or remote. The backlight and power board were working fine.
                                    After testing and verifying the voltages (DRY ON, PWR ON, 12V/24V rails), I suspected a corrupted SPI firmware. What I tried so far:
                                    • I bought another
                                    06-25-2025, 02:07 PM
                                  • l0lhaxz1
                                    QN65QN90A - Mainboard MLCC failed - now bootloop
                                    by l0lhaxz1
                                    Hi
                                    I have a QN65QN90A which was purchased around launch I guess making it about 1.5-2 years old... had been working fine until a few days ago, simply went black and would no longer turn on (at all). No standby light and no typical PSU relay click etc. Absolutely dead.
                                    Pulled it apart without doing much research first, suspecting the power supply as it had a faint buzz (I guess due to the forthcoming found short), investigated PSU for some time and concluded there was no fault that I could spot with the board removed.
                                    Came to learn after a bit more research...
                                    02-06-2023, 08:59 AM
