Hakko 808 too hot!
  • 4tified
    • Jun 2008
    • 55
    Hakko 808 too hot!
    Recently replaced my Hakko 808 heating element and wasn't paying attention to what I was doing.... shorted the leads coming from the heating element, which in turn blew a resistor. Based on the color bands, I replaced it with an equivalent 1ohm, 2 Watt Resistor with 5% tolerance. (Brown, Black, Gold, Gold). Problem is now, the Hakko desoldering tip glows red after it has heated up, indicating that the temperature is way too high. Turned down voltage as far as it would go and decresed the calibration pot as well, but to no avail.
    Is is possible that the because the resistor is 2 watts versus 1 watt that too much power is going to the heating element or could having the resistor in backwards be an issue? The voltage adjuster is nothing but a potentiameter, so is it possible that the resistor blowing could have harmed that component? No other components look damaged.
    Thanks for the help guys!
  • Krankshaft
    • Jan 2007
    • 2328
    Re: Hakko 808 too hot!
    You installed the wrong value resistor the resistance is wrong. It's very easy when a resistor gets charred for the color bands to be misinterpreted.
    Resistor wattage has nothing to do with your issue. Resistor wattage is like cap voltage as long as it's equal or higher than the original value you're fine. If wattage is too low the resistor will overheat and self destruct that's all.
    • 4tified
      • Jun 2008
      • 55
      I could've sworn I had the right one!
      Do you reckon the 1ohm resistor is too high or too low? I had a feeling the wattage didn't matter, but I just needed to verify.
        • 31140
        got a foto of the old one?
        btw, all the irons i'v seen with a ballast resistor use 5w ceramic box type ones - 2w seems a bit low to me.
        i can imagine a 2w one getting hot enough to desolder itself!
        • 4tified
          • Jun 2008
          • 55
          Unfortunately I don't have the old resistor nor a picture of it. I do know that the resistor is replaced was no more than 2 watts (based on the size and shape), but I am not 100% sure of the resistance. There are no schematics of the 808 that I know of, I've looked everywhere. The two things I know of are the tolerance level and the max wattage. Should I try a higher resistance?
          • Quasar
            • Sep 2010
            • 132
            Sounds like you blew a MOSFET on the temp control board. Need a pic of board or a schematic or component ID's. If the MOSFET that cycles the heater shorted, it would do what you've described.
            Q
            EDIT: Your resistor value is correct. There is an 8 pin IC on the board. Please lookup the part number to see what it does. The whole board (p/n B1738) is around $60.
            Image attached
            • Krankshaft
              • Jan 2007
              • 2328
              Oh man what was I thinking. My brain must have really been fried last night. Nice catch Quasar!
              Your FET is shorted connecting line voltage to the heating element constantly. Temperature is regulated by switching a FET on and off rapidly via a PWM controller. It's feedback is the tips temperature via a thermistor.
              That 8 pin IC is probably a PWM / FET combo. Check underneath the board if there is no SMD transistor on it I'm right. If there is a transistor that IC is a PWM controller and you may luck out and be able to repair this board.
              The IC is made by NEC part number UPC1701C.
              • Quasar
                • Sep 2010
                • 132
                Here: http://www.bdent.com/UPC1701C-p/upc1701c.htm
                Attached ENGLISH datasheet... lol
                Q
                • Krankshaft
                  • Jan 2007
                  • 2328
                  A triac instead of a FET talking about bare bones technology. Saved them the price of a bridge rectifier I guess .
                  Thanks to Q's ENGLISH translation it's a specialty temperature control IC for heating elements.
                  All the brains of your temperature regulator are in this IC.
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    I think this is it. - Doesn't appear to use PWM.
                    Haven't found it in English yet though...
                    Mann-Made Global Warming.
                    - Dr Seuss
                    • Krankshaft
                      • Jan 2007
                      • 2328
                      Yeah the IC is MUCH older I was thinking too modern.
                      It's a circuit that pulses the triac at the zero voltage point of the AC wave.
                      Here's the datasheet thanks to Quasar's link:
                      It says in the datasheet triac controller so there should be a triac somewhere that's shorted out.
                      The triac will be connected across one side of the load. So trace out the two power wires going to the heating element (the other thinner wires go to the temperature sensor) it will be connected inline with one of those wires. It's going to be a dead short.
                      Don't forget to put the old POT back in the board. Depending on what POT you adjusted the temperature may be out of spec after the repair.
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        Here Yar...
                        http://cgi.ebay.com/ANALOG-INTEGRATE...item3a4fe2d69d
                        http://cgi.ebay.com/UPC1701C-Integra...item255dd90bcc
                        - Dr Seuss
                        • 4tified
                          • Jun 2008
                          • 55
                          You guys are awesome! I will take a look when I get home. Thanks for the links!
                          • japlytic
                            • Oct 2005
                            • 2086
                            I misinterpreted a resistor which became discoloured as 10 ohms, where it was actually 22 ohms (I actually measured it, and it was within an E12 value). Fortunately, this resistor was used as part of an RC snubber network across an output rectifier on a power supply board.
                            • Quasar
                              • Sep 2010
                              • 132
                              @4tified - Would you post some pics of this board hooked up to the gun?
                              Especially the underside. I think the triac must be on that side, as it's not shown in the exploded parts diagram.
                              Q
                              • Quasar
                                • Sep 2010
                                • 132
                                -bump-
                                Hello ?
                                • 4tified
                                  • Jun 2008
                                  • 55
                                  Sorry guys, I've been really busy lately. Here are the pics.
                                  • Krankshaft
                                    • Jan 2007
                                    • 2328
                                    It's the component designated as T1 (T for Triac) measure it it's probably shorted.
                                    Measure between the input and output pins (they would be referred to as A1 and A2 in the datasheet) one side of the triac will be connected to line voltage the other to the heating element. This is where your short should be.
                                    Ignore the gate lead which is fed from the temperature control IC.
                                      • 31140
                                      dont ignore the gate lead, it could be leaky to one of the other pins - then it would self-bias and latch on.
                                      i'v seen that happen.
                                      • Toasty
                                        • Jul 2007
                                        • 4171
                                        I attached the pics so we don't lose them (like the last 12 hours did.)
                                        Please upload direct to forums. Use the Advanced Editor and Manage Attachments.
                                        Toast
                                        veritas odium parit
                                        • EasyGoing1
                                          The best way to drive a heating element?
                                          by EasyGoing1
                                          I've got this circuit that I've been playing with on a breadboard. I'm not happy with it mainly because the MOSFET gets too hot and generally controlling the temp of the heating element with the Arduino has proven to be a little more cumbersome than I would like.
                                          What I would like to know, is what is the best way to set up a circuit like this? The heating element is just a PCB and its going to be mounted under a 3D-printed enclosure that a lizard will use to warm his belly.
                                          This is the general setup that I have now.
                                          This is what the...
                                          01-25-2023, 11:29 AM
                                        • jinu_j
                                          by jinu_j
                                          Hi
                                          05-03-2025, 10:51 PM
                                        • mikey5791
                                          Need help to replace burned resistor in 350w atx psu
                                          by mikey5791
                                          Hi to all forum members,
                                          Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                                          The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                                          Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                                          Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                                          12-26-2024, 04:55 AM
                                        • MidnightRoller
                                          Can a resistor lose resistance after hot air?
                                          by MidnightRoller
                                          I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                                          I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                                          02-02-2022, 11:46 PM
                                        • artvandalai
                                          What resistor ohm will work better to repair this waterpik?
                                          by artvandalai
                                          The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                                          01-05-2025, 04:10 PM
