What does ripple current mean?
  • yanz
    • Nov 2004
    • 910
    What does "ripple current" mean?
    It always bugs me whenever I think about it. I know that the definition (from panasonic website):
    • Ripple Current
      Ripple current is the rms value of alternating current flowing through a capacitor. This current causes an internal temperature rise due to power losses within the capacitor.
    • ESR (Equivalent Series Resistance)
      Equivalent series resistance causes heat generation within the capacitor when AC ripple current flows through the capacitor. Maximum ESR is normally specified at 120Hz, 20°C.
    So, there is a current flowing through a capacitor, and its value is alternated. The higher the rms value of this ripple current the worse the effect to the capacitor. The internal heat of capacitor will rise as the result of resistance. So this is the use of low esr caps, it's allowed the ripple current flowing through with minimal generated heat in the caps thanks to its low resistance..
    The higher the ripple current rate for the capacitor, the more "strong" the caps can sustain the higher excessive ripple current, and the lower the heat within the caps.
    Do I understand it right?
    What happens if the ripple current is higher beyond the allowed value? Will it change into the heat instead of flowing through the caps?
    And why the caps should allow the ripple current? Isn't its job to smooth the ripple? If the smoothing jobs doesn't run good what is the effect to voltage? I mean, if the ampere decreased, the voltage will increase to keep the same wattage, right?
    I know the relation between the capacitance and transient performance, but is there any relation between low esr and charging/discharging time for a capacitor? What does impedance involve here?
    What is more important, the ripple current rate or the low esr rate? Or does the low esr rate automatically translate to higher ripple current rate?
    What the relation between capacitance and impedance. Now I'm completely lost about impedance, what does impedance mean?
    Did I ask the same question again and again? lol.. Sorry... Your explanation will be appreciated to shed a lot of confusion I have...
    Maybe this is all just a simple theory. So, pls help me to understand it simply better...
    Thanks...
  • PeteS in CA
    • Aug 2005
    • 3581
    • USA, Unsure of Planet
    Re: What does ripple current mean?
    Good Qs, yanz! And you have a lot of it right.
    In a switching power supply, the voltage coming out of the O/P rectifier and into the O/P inductor is a positive-polarity square wave. The O/P inductor and O/P capacitor(s) filter that into a DC voltage. The current through the inductor is a DC level (which goes to the load) with triangle-shaped AC current riding on the DC level. The AC current is due to the charging of the inductor (during the switch "On" time) and discharging of the inductor (during the switch "Off" time). If things are designed properly and operating normally, the inductor never "fully" charges (saturation), nor discharges fully. Almost all of the AC current, several amps rms, goes through the O/P capacitors rather than to the load (if it did, the ripple voltage would be fairly high). While a capacitor's DC resistance is very high, its impedance to AC depends on the frequency of the AC. In the 100KHz range, that impedance is milliohms (thousandths of an ohm). By way of contrast, the effective resistance on the load in the computer is much higher (e.g., if the O/P voltage is 2V and the load current is 20A, the DC "resistance" is 100 milliohms). So it is entirely normal for the capacitors to be conducting several amps of ripple current, as this is due to the capacitors' smoothing action.
    What is impedance? In a capacitor, it has 3 basic components in series with each other: an ideal capacitor; the ESL, equivalent series inductance, of the leads; the equivalent series resistance of the leads, the foils, and the electrolyte. Impedance is the vector sum of the capacitive reactance [1/(6.28xFxC)] X(C), the inductive reactance (6.28xFxL) X(L), and the ESR. At relatively low frequencies, X(C) is basically the impedance. As frequency increases, the impedance falls until the ESR is greater than the X(C), and the ESR is basically the impedance. As frequency continues to rise, the X(L) becomes greater than the ESR, and the impedance is basically the X(L). P/Ss and VRMs operate in the frequency range where the impedance and ESR are approximately the same.
    If the capacitor is conducting ripple current, it is dissipating power (I^2)(ESR), which is heat. The higher the ripple current, the more the heat. If you exceed the ripple current rating, the cap will overheat, unless the ripple current is so high that hydrogen gas is being generated. So the failure mechanisms with excessive ripple current are electrolyte evaporation and evaporation- or gas-related venting.
    PeteS in CA
    • PeteS in CA
      • Aug 2005
      • 3581
      The rate of charging or discharging a capacitor is the product of the capacitance and the resistance through which it is charged or discharged. The ESR of the cap only becomes relevant when it becomes a significant part of the overall resistance in the circuit. In a P/S O/P circuit. however, the charging and discharging rate are determined by the I/P voltage to the inductor, the inductor itself, and the load current.
      The ripple current rating is related to the ESR, the stability of the electrolyte, and the ability of the cap to dissipate heat to the ambient environment. If you are comparing caps of identical case size and temperature rating, it basically comes down to ESR.
      PeteS in CA
      • arneson
        • Sep 2005
        • 1267
        I had an instructor way back who used the electricity to water analogy.
        It works surprisingly well.
        Einstien rolls over in grave.
        Jim
        • davmax
          • Dec 2005
          • 899
          A good descriptions Pete. I have been wondering if it would be profitable for this forum to create a VRM block diagram/equivalent circuit with input caps, converter, output inductor, output caps(electro and ceramic) and load. To include ESR and ESL, conversion ratio (12V in/1.6V out) and how the load on the input caps is changed by the ratio. How the ratio changes the effective ESR need of the input caps compared with the output caps etc.
          Pictures can help.
          What do you think? Can you supply such a diagram?
          160Gb WD SATAII Server grade
          Nvidia 8500GT 256Mb
          Samsung 18x DVD writer
          33 way card reader
          Windows XP Pro SP3
          17" Benq FP737s LCD monitor
          • yanz
            • Nov 2004
            • 910
            Pete, that explains a lot, thanks! While i feel i only understand 70% of it, it answer a lot of my initial question.
            Pictures can help.
            That would be excelent..
            Yup i use it to explain to some friends of mine, but when it is about pawor factor, water analogy doesnt help.
            • mntegra01
              • Nov 2014
              • 31
              Is this statement correct?
              Hey guys, I am trying to do my research on getting the right cap for my TV psb repair. I bought some caps online here and I assume the will fit and are correct. I went by Farad rating and Voltage and usually there was only one choice.
              So reason Im here in this thread now is that I used this http://www.paullinebarger.net/DS/ to find ripple current and specs on CapXon caps that are original to my board.
              Now Im finding that the Rubycon caps I ordered here have higher (by a lot) ripple current ratings. I just want to be sure of what is important when replacing a cap and selecting the right one.
              farad and voltage rating are the biggest factors to go by I understand, but how is a certain series of a cap Important?
              My CapXon are all KF series except two GL. I also have 2 united chemi-con KY on the PSB
              Thanks again for all the help. I am certainly a knowledge seeker and like to continue learning.
                Higher ripple rating than the original is fine, not lower.
                • Queen Daisy
                  • Jun 2017
                  • 14
                  Room for a Quick question guys?...errmh what happens if the ripple current is beyond the permissible value for a capacitor? Does it change into heat instead of flowing through capacitor?
                    • 31017
                    the capacitor will fail to smooth the signal out to the extent of the excess,
                    in the case of computers this could make them unstable at best and even cause damage.
                    it may cause the cap to heat up, but high frequency on a cap with poor esr is the usual cause of heating.
                    caps are complex
                    • PeteS in CA
                      • Aug 2005
                      • 3581
                      Well, it comes down to Ohm's and Watt's Laws. A capacitor has a finite Equivalent Series Resistance (ESR). "Ripple Current" (IR)is the AC current being conducted through the capacitor. So:
                      + (ESR) * (IR) = The AC voltage across the capacitor. For a PSU filter capacitor, that is the ripple voltage on the particular output.
                      + (ESR) * (IR ^2) = The power dissipated by the capacitor. Dissipated power means heat.
                      So, excessive ripple current can cause out of spec ripple on an output, and it could lead to premature failure, due to the capacitor venting its electrolyte or just drying out. In the extreme (I mean extreme like Torquemada) a REALLY high ripple current could fuse the lead of the capacitor. Fusing the lead almost certainly would not happen in the real world (But I've done it, ).
                      PeteS in CA
                      • chth96
                        Is it no harm to replace with capacitor without ripple current rating?
                        by chth96
                        When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                        Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                        But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                        Rubycon YK DataSheet (b...
                        04-19-2024, 05:19 AM
                      • quickname
                        Cyberpower 1500AVR UPS repair
                        by quickname
                        I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
                        I decided to verify that the batteries were...
                        11-12-2023, 09:57 AM
                      • cind12
                        GTX 1080 TI Gigabyte Aorus low resistance on vmem
                        by cind12
                        Hi guys, i was wondering, i've got 9Ohms on Vmem, one of the mosfet was shortet to ground, so i've desoldered hi and low mosfets nad still low res, then i removed all of the memory chips, and the resistance is still low, so did you had maybe a card with that low res on memories, and the card was working fine ?
                        Removed the U1866Q and still without result, i dont have thermal cam so can't see where is hot spot when incjeting voltage.
                        The resistance on core is ok 0.1Ohm ((Power 0.8V when on)
                        Resistance on 12V 4K ohms (Power present when on)
                        Resistance on 12V PEX 4K ohms...
                        12-08-2023, 09:09 AM
                        Is there any high current pouch battery that are size 60mmX80mm maximum thickness 21mm for a battery operated tab welder
                        I have a battery operated tab welder and the battery does not have enough current for the battery tab welder because after about 30 welded it does not have the same current output it voltage has gone down by at least 0.500 volts or maybe a more than that
                        I can fit 21700 battery cells in the enclosure it is very tight fit for four of them that are 35 amp high current capacity 35X4=140 high current output this should work a lot better than what is installed right now
                        I tested the battery cells there are installed right now and they are testing good with no issues that I...
                        02-04-2025, 08:08 PM
                      • Junkrepair
                        Seeking "Ripple Current Confusion" paper by Kemet
                        by Junkrepair
                        Hey everybody.
                        Trying to understand the meaning of ripple-current specs for capacitors, I've seen references to a paper apparently entitled "Ripple Current Confusion", by Kemet. I've found that the links to the paper are broken, and that it doesn't seem to be on Kemet's site.
                        Can you post that paper or a good link to it?
                        Thanks.
                        04-07-2022, 04:28 PM
