I know how to check other components but IC's are always a pain in the a**. I don't have any expensive equipment to test it with, only a multimeter. Also I'd like to know how to test smd resistors and capacitors without desoldering them off the board. Any help is greatly appreciated.
How do I test integrated circuits with a multimeter?
Re: How do I test integrated circuits with a multimeter?
you can't with the resistors and caps... they have to be out of circuit to be tested (otherwise you are testing the whole circuit, which often has other devices in parallel, messing up thee test)
as for ICs, depends on the IC. get a bench PSU, a solderless breadboard, and breadboard wires and build a sample circuit as per the device datasheet.sigpic
(Insert witty quote here) -
The best you can expect is to find shorts where they are not supposed to be. Get the datasheet and find out what the pins do. Some pins are supposed to be shorted. No shorts allowed between power and ground.Comment
This is going to be a bit of an effort for me but will give both approaches a go and see which one works better. Thanks for the suggestion guys. If anyone else has any more ideas I would like to hear them.Guns don't solve problems. I'll take 12
With a multimeter, you can't do a really serious test about the IC, but if you have a good new IC, the same type of the suspect one, you can compare readings and maybe you can spot any significant difference...Comment
There is no easy way to function test ICs except perhaps basic logic gates - of course you can check any IC for dead shorts, though.
Since they all have completely different designs and functions, the only real good test is in the circuit it was designed for, and verify by substitution.
The same way to test a non-SMD part - you can measure it as long as it's not in parallel with anything else, or connected to any other circuitry that can throw off the measurements.
If in doubt, you still have to remove it and test out of circuit. There is no way around that."Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
-David VanHornComment
It's possible to do this if you have a schematic. Even without a schematic it may be possible to spot a gross problem. Part of the challenge is knowing what the circuit does.
With a schematic you can check the value of the resistors and capacitors and use a 'not less / greater than' rule. A good resistor in circuit will never read greater than it's true value because parallel resistances will reduce the resistance. A good capacitor in circuit will never read less than it's rated capacitance because any parallel capacitances will increase the capacitance.
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic.Comment
by dj8452000I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
by jinu_jHi Folks
Need some advice on how to test a subwoofer amplifier if i have access to only a multimeter.
Problem
I have a Boston Acoustics active Subwoofer (soundware S). Its rated output is 200W. But the output i am getting is very low i can barely hear/feel it even if put the gain at max. I replaced all the capacitors in the Subwoofer amplifier but still no change.
Is there anyway to test this without getting an oscilloscope/Function generator to see if the fault is with amplifier, driver or the source??
Any advice would be appreciated...-
by chronic519Hello.
GPU came in, green lines. Spent lots of time using to get the Mats / mods drive working (found on youtube).
Found issue with a RAM block
Replaced, green lines gone.
Trying to test again, assuming getting the false positive. Originally had over 1K on a single bank. Now getting tosses low between banks.
Used a good card to test and same results low errors 32+.
I am just search for some form of command to do a full test on the GPU.
I just ran the mats command with my good GPU and passed after roughly 40 min.
The repaired one, ran... -
Hello All,
I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
https://www.hifivision.com/threads/m...-screen.98243/
Troubleshooting Summary: Majority Internet Radio - Flash Chip...-
by alltvrepairsHi,
i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
Appreciate your help....2 Photos - Loading...
