Vertical-Mount Power Resistors
  • PeteS in CA
    • Aug 2005
    • 3583
    • USA, Unsure of Planet
    I noticed yanz likes to upgrade preload power resistors to 5W bathtub-style wire-wounds. The axial lead (horizontal-mount) types are pretty awkward for this, so I thought I'd provide links to info about some radial lead (vertical-mount) types. These will also save a lot of PCB space if you build an external load box. I used to have a load box that I built in an old ATX P/S case. I kept and connected the fan, mounted the power resistors near the fan, and also had window detector circuits that drove LEDs that told me at a glance whether each O/P was in regulation. It was a nice go--no-go tester.
    The URLs for the resistors:
    http://www.krlbantry.com/products/Power/sect-323.htm
    http://www.ohmite.com/cgi-bin/showpa...tww_twm_series
    PeteS in CA
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • GLISIT
    by GLISIT
    01-16-2025, 02:29 PM
  • yaya3gmax
    Laptop Power Issue – Works on Battery, Fails on Adapter Load
    by yaya3gmax
    Dell laptop (E7440, uses the notorious CD3301B power controller + MEC5075 EC + BQ24715 charger IC)
    Symptoms:
    • Laptop works normally on a pre-charged battery.
    • Battery does not charge when adapter is connected.
    • Without battery:
      • Laptop powers on from DC adapter, passes CPU/RAM init checks, then cuts DC power abruptly.(seems to shutdown one of the mosfets in the charger path). Then the loop continues indefinitely
      • Speakers “pop” when power cut occurs indicating harsh sutdown.
      • If RAM is removed, the system shows RAM missing blink error code indefinitely without cutting DC power
    08-21-2025, 07:16 AM
    03-31-2024, 02:12 PM
    09-06-2024, 05:59 AM
