Adding AC Adapter to Battery Powered Device
  • newtoCaps101
    • Jul 2011
    • 93
    I have this Exercycle's computer that runs on Alkaline 1.5V Batteries. I cant seem to get it to run on any of my 1.2V rechargeable batteries, the device malfunctions.
    So I was thinking is there anyway I could solder wires and connectors to give it an option to be run with a DC adapter? Maybe grab a cheap ebay 3VDC Adapter and solder the points?
  • cheapie
    null
    • Jul 2010
    • 849
    Re: Adding AC Adapter to Battery Powered Device
    That should work perfectly. Some places also sell adapters that fit into a 2AA holder and have wires coming out, but those are hard to find.
      Typical non-regulated linear power supply will put out more if the it is not load up to the load current spec, so for 3V adapter will put out about 5V, you need to check. You can use dropping resistor if you know what the current draw of the load is.
        12-31-2023, 06:04 AM
      • Caimano
        HP 250 G7 runs slow and battery charge is disabled when adapter is inserted
        by Caimano
        HP 250 G7 with i3 8130U, MB EPK50 LA-G07EP REV 2.0 , PN L65699-601, Windows 10
        Laptop works perfectly when on battery and battery is charged correctly when laptop is off.
        Problem is that when adapter is inserted cpu clock is limited (visible in Task Mgr) and performance drops. Also battery charging is disabled when adapter is used and computer is on. As soon as computer is turned off battery charging starts.
        Tried bios update through Windows from version F38 to F42 . Same problem
        Reinstalled windows same problem.
        I tried 2 different...
        11-07-2022, 03:22 PM
        NVDC charger configuration...
        11-05-2024, 03:28 PM
        DELL XPS 9365 Hybrid (2-in-1) 13 Specification for Upgrade or Repair
        This specification for the DELL XPS 9365 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 9365 boardview and 9365 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL XPS 9365 Hybrid...
        09-06-2024, 05:40 AM
