*WARNING* Harbor Freight fuses...
  • Galvanized
    • Mar 2006
    • 468
    Chinese fuses don't and cause electrical fires. I am shocked...shocked I tell you!
    http://www.lawyersandsettlements.com...use-fires.html
  • Krankshaft
    • Jan 2007
    • 2328
    Re: *WARNING* Harbor Freight fuses...
    To be safe I only use name brand fuses from companies like Buss, or Littelfuse.
    If you pay attention to the brands of caps when you recap why shouldn't you pay attention to your fuses?
    • PeteS in CA
      • Aug 2005
      • 3578
      • USA, Unsure of Planet
      Wickmann and Schurter are good, too, especially for 5x20 fuses.
      PeteS in CA
      • Super Nade
        • Jun 2006
        • 294
        I go with Wickmann too. Harbor Freight sell ultra cheap crap. That's it. If any of you have bought drill bits from them, you will know what I'm talking about.
        Q6700 @ 3.6 GHz
        Zippy GSM-6600P
        Curcial Ballistix PC6400 (4 x 1Gb) Micron D9GMH
        Abit IP35Pro
        ATi HD4870
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          its no surprise to me.
          much of the electrical stuff from china is dangerous junk anyway.
          some of those outlet strips are scary looking inside.
          hmmm no blow fuses with a lifetime warrenty.damage to them from car fires not covered.
          we call the place harbor fright.
          • severach
            • Aug 2007
            • 1055
            http://money.cnn.com/2007/09/05/auto...call/index.htm
            Sold under the brand name Storehouse, the sets of blade-type and mini-blade-type fuses were sold as replacement parts and were not used as original equipment in any vehicles. The item numbers are 92939 for the mini-blade-type and 92940 for the blade-type.
            I bought 2 sets of each within the timeframe. That's a big $12 I'm going to get back. Woot!
            I've got a blue Harbor Freight 15amp in my radio circuit right now. The good part is that because they are going to take them back regardless I can do some QC testing if I can find an amp box.
            Part numbers and a clear product description is available in many articles.
            http://www.detnews.com/apps/pbcs.dll...709060341/1148
            http://groups.google.com/group/alt.a...527bf86bbf1022
            sig files are for morons
            • Paul S
              • Sep 2006
              • 326
              Harbor Freight sells "disposable" tools.
              They are OK for a onetime use. If you get to use them two times, you are doing good.
              Sometimes they dispose of themselves before you finish the job!
              I recently bought a regulator/moisture trap/oiler for my compressor. I was spraying some oak doors and trim with polyurathane. The regulator and oiler crapped out and started leaking after about a month. The moisture trap is still working.
              You get what you pay for (if you're lucky).
              • pentium
                • Mar 2006
                • 2778
                I find this ironic that a safety device is being recalled because it's unsafe.
                All my blade fuses are buss. I have several packs in the junk drawer for when my inverter blows a fuse.
                Find Nedry!
                Check the Vending machines!!
                • Galvanized
                  • Mar 2006
                  • 468
                  I only use name brand fuses like Buss and only offered this as a heads-up.
                  I do have a rather large circle of ppl I come in contact with and they know me for being a grumpy old diesel mechanic. I will go as far as lift the hood or test drive a car and offer advice or recommend a repair garage or to buy or not. I do not do home repair of cars and such anymore.
                  With these non-fuses I await the day when someone tells me of a dash fire because it will happen.
                  In trucking the 1/4" round fuses could be replaced with snap-in circuit breakers. These worked a treat with intermittet shorts like on the heater blower or marker lights. I would throw one in when the load HAD to go, telling the driver to write it up at the next garage or upon returning to the main shop.
                  • Krankshaft
                    • Jan 2007
                    • 2328
                    He he you mine as well use a paper clip if your fuse blows rather then use that paper clip in a plastic case from China .
                      Surface Mount Fuses Fundamentals Datasheet
                      TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                      TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                      10-07-2024, 06:07 AM
                    • Sik_6ty_Sixx
                      HH Scott Model A510 Stereo Integrated Amplifier/ Graphic EQ - Blowing fuses in the LEFT speaker channel only. Any Help???
                      by Sik_6ty_Sixx
                      So like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...
                      02-18-2025, 05:06 AM
                      Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
                      12-14-2023, 07:45 PM
                    • x_orange90_x
                      Replacing backlights in Vizio V755-J04
                      by x_orange90_x
                      I've had this monster for several months as I've hesitated to order backlights for it. Finally did order them and they are due to arrive tomorrow. Besides having ample space to work, are there any recommendations for working on such a massive screen? Should I remove the panel by myself or would 2 people be a better choice? I bought the double-cup suction cups from Harbor Freight and have been using them for the last few repairs on smaller screens. They are far superior to the single cup orange ones I used previously that would often let go without warning 😱.
                      I have not replaced...
                      12-03-2024, 07:03 AM
                    • acedogblast
                      Power supply for main amp blows fuses after replacing filter caps.
                      by acedogblast
                      Hello I have a Marantz sr5012 that I have been repairing. After I have replaced the 2 main filter caps the 2 fuses for the power amplifier blows. The original capacitors are ELNA LAO 10,000uF 71V and the replacements are Nichicon LKS 10,000uF 80V.
                      I assume a short circuit connection has occurred so I set my multimeter to measure ohms across the 2 fuse connections and both read 55 Kilo-ohms so I assume that is ok.
                      I am certain that I do not have any bridges on my soldering and after probing around I do find a temporary 0 ohm reading when probing across the positive and negative...
                      02-27-2023, 05:11 PM
