Hi guys,
I'm sorry cos I'm sure this has been asked a million times before but I'm about to order so I want to make sure I get this right.
I am using this veroboard for building a small motor controller using just a simple 555 timer and transistor. Up to now I've been using Cat5 Ethernet cable, cos I work in IT and have a load of it. Now it's fine but the conductor (as well as the wire) also slips through the hole, so it's awkward to solder.
What size AWG wire will allow the conductor to pass through the hole but block the outer conductor. The spec above says that the diameter of the hole in the veroboard is 1.02mm
thanks.
thanks.
