Isolated transformer ?
  • bianchi77
    • Jun 2016
    • 1121
    Everyone,
    Does a DIY isolated transformer safe enough for fixing job ?
    I saw :
    http://www.instructables.com/id/Test...vage/?ALLSTEPS
    Cheers
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8703
    Re: Isolated transformer ?
    Two filament transformers back to back will work and is safe, but the power rating is likely too low to be very useful. Unless you find some really beefy (and identical) filament transformers, probably should probably just get a real isolation transformer, unless you're just working on, say, very low power wall warts.
    • bianchi77
      • Jun 2016
      • 1121
      for example I have two identical 8A 220V primary and 15V secondary..
      Will I get 120VA on the isolated transformer ? or how much is the loss ( efficiency ) ?
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8703
        Usually the secondary is limiting, so if you have a 15V 8A secondary you'll probably get just about 100VA depending on transformer losses, and both would get some losses.
        I was wondering about my 12V 1A filament transformers which wired as an iso transformer I'd only get 100mA 120VAC or less before possibly frying the transformers... and indeed this is only good enough for small wall warts...
        • bianchi77
          • Jun 2016
          • 1121
          so it's 10% efficiency ? 1A to 100 mA ? how do you know it's 100mA from 1A...did you test it with bulb ? 60W bulb with 120V ...it will need 0.5A
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8703
            It's the volt-amps of the inner section that limits, plus losses.
            No, this isn't "efficiency" but rather max power output
            So you have pri:sec -> sec:pri of two filament transformers. When you go through the first transformer you have a max of 12VA because of the 12V 1A. Now that 12VA gets fed into the second transformer, and you get an output of 120V (about). But since you fed in 12VA, you get only 12VA so that means you only can get 100mA out at 120V.
            This is just hypothetical, I didn't actually do this but the math works for this kind of iso transformer..
            If my center voltage stayed at 12V and I need to light a 60VA light bulb =~ 60W, then that center section needs to be 60VA (or more) which means at least 5A needs to be flowing in the secondary.
            Transformer efficiency is a different beast, though as long as the transformer doesn't get warm or leaks too much magnetic field, it should be fairly efficient, at least 80-90% efficient if not more. Multiply the two efficiencies together for the two transformers and get 64% to 81% efficient isolation transformer. However I'd guess that the 80% efficient transformers are kind of rare (and unwanted). Transformers can be built quite efficient.
            A real 1:1 winding iso transformer is definitely more efficient as you only lose on one core and two windings, instead of losing on 2 cores and 4 windings.
            • redwire
              • Dec 2010
              • 3912
              Tried back-back filament transformers but they each have 10-20% regulation and I believe the secondaries are overwound extra turns to make up for copper losses. End result is twice the mush, 30-40% regulation. It depends on the VA rating but too sloppy for some gear.
              I use a transformer with dual 115VAC primaries for isolation- one winding for input, the other winding for output. Works OK but I de-rate by 50% because one winding is feeding the core instead of two.
              Lately I use a GFIC on my workbench to stop any drama. But to 'scope around a primary switcher, gotta have an isolation transformer.
              • R_J
                • Jun 2012
                • 9607
                I built one a long time ago using an old microwave oven transformer, I chopped the highvoltage secondary out of it and rewound it (can't remember the wire guage). aprox 1 volt per turn, it worked quite well.
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8703
                  That MOT modded as a isolation transformer probably handle more watts than any of these filament transformer solution, probably better than my true blue iso transformer (though the one I have is tapped so I can somewhat change the voltage).
                  However I've heard that MOTs were designed on the cheap side and tend to run slightly saturated as the duty cycle of microwaves tend not to be 100% - does the transformer get warm?
                  • Andyy
                    • Aug 2016
                    • 28
                    If you can find a couple dead computer UPS, you can extract the transformers and wire the secondaries to each other. Choose transformers from higher VA rating, and derate when using.
                    • R_J
                      • Jun 2012
                      • 9607
                      that microwave oven transformer did run a bit warm, the laminations are welded together on those. I ran a 1500 watt heat gun off it (for a load test) and the voltage hardly droped. but I did'nt run it all day so it worked fine, I have a hammond 1500va now that I use to isolate the whole bench.
                      • bianchi77
                        • Jun 2016
                        • 1121
                        Can I use 2 transformer with different ampere but same voltage ?
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8703
                          yes but the overall rating will be of the lower rated transformer.
                          • ohren
                            Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                            by ohren
                            Hello!
                            I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                            Measured voltages with no load:
                            After rectifier diodes
                            12V: 6.17 V
                            5V: 5.67 V
                            Secondary transformer pins AC measurement (really don't know if this says anything)
                            12V: 2-2.5 V
                            5V: 1.04 V
                            I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                            03-18-2023, 10:33 AM
                          • mikey5791
                            Is it possible for transformer substitution?
                            by mikey5791
                            Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                            Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                            My questions are
                            1. How do i test to see if the transformer is in good working condition?
                            2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                            Hope you guys understand what i was asking. My intention is...
                            11-03-2022, 02:11 AM
                          • dennis_elx33
                            3PHASE STEP-DOWN Transformer in Check
                            by dennis_elx33
                            Hello All,
                            i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
                            Problem statement: Power tripped Off
                            Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
                            Action Done:
                            1) Replaced the faulty parts with good spare.
                            2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
                            12-02-2024, 06:52 AM
                            ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) Book Specification for Upgrade or Repair
                            This specification for the ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T101HA - X5DHD boardview and T101HA - X5DHD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                            09-06-2024, 04:40 PM
                            ASUS Transformer T304UA-P71SP-CA Hybrid (2-in-1) Pro Specification for Upgrade or Repair
                            This specification for the ASUS Transformer T304UA-P71SP-CA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T304UA-P71SP-CA boardview and T304UA-P71SP-CA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                            09-06-2024, 12:00 PM
