Re: Who can help to tell the resistor value please?
That looks to be Source resistor for the MOSFET PU4402 which is connected in series with MOSFET PU4201 as half-bridge set up. I expect that resistor to be <1 Ohm.
Why do you believe that resistor is bad?
What is this board for?
You might have better luck posting the board number or model number, What is it's resistance when checked with a meter?
It could be a D01R3721F-GP-U
Hallo
i have a Yoga L380 LKL-1 Mainboard
there the PR4402 is only 0,6 Ohm instead the 1,0 Ohm that results in Slow charge and Fault messages regarding the charger
According Schem its a D01R3721F-GP-U
because you know that resistor .... do you know where i can get it ?
Prefer Europe but i can order world wide
Sorry all posted Values are wrong
Marking R010
acc calculator it should be a 0,01 Ohm
With this low resistance value, the measurement cable must also be taken into account.
Unfortunately, I don't have a milliohm meter at the moment and all other measuring devices are too imprecise.
Best way is to change it to be shure
