Was wondering if someone would double-check my design here. It's relatively simple. I used an online LED array calculator to get the core array specs. And for the potentiometer, I figured that since the sum of the parallel resistors (since I don't know the internal resistance of the LEDs) is 5.5 Ohms, that adding a 5 ohm pot for dimming would be sufficient, if not overkill possibly.
Each LED is rated at 3.2V 150ma
VCC = 19V from a laptop power supply, so it should be a fairly stable source voltage.
I need the thing to be stable and to be able to dim it. Does this design seem like it would fit that requirement?
And here is the PCB layout, front and back....
