Maytag Whirlpool Kenmore clothes dryer data bus
This topic has been answered.
  • Joe24
    • Jun 2021
    • 53
    • Eh?
    Patient is a Maytag/Whirlpool/Kenmore clothes dryer. Not sure of exact model, doesn't matter. All boards are out of production.
    Specific problem is a Maytag 8544799 / WP8544799 motor-control board, aka Diehl Controls 708879-05. Customer states the board "doesn't work, motor doesn't run". Not sure how the repairman made that assessment, or if it's even accurate. He can't get replacement boards, and the owner decided to buy a new dryer, so whether this board is the problem is speculation on his part. Again, doesn't matter.
    I've been over the board looking for shorted drivers, missing voltage rails, all the usual stuff. All looks good so far. Nothing obvious.
    The general construction of Maytag/Whirlpool/Kenmore dryers from this era seems to involve 3 control boards: (1) the console board with buttons and display, etc., (2) this motor-control board which is a small 3-phase VFD, and (3) a main control board. All these boards communicate on a 3-wire bus, which I have seen pinned out as Vdd/Vss/Data. So presumably UART or similar protocol.
    Motor control board evidently does not power the bus, as all the data lines are dead except for a few residual mV. Not shorted, just not powered.
    So now I'm curious, because we somehow need to fake this thing into life. Does anybody have experience with the data bus in these or similar units? Surely someone somewhere has compiled a list of commands which pass between boards to indicate status, turn-on commands, etc. I doubt it's very complicated, and if you eavesdropped on the bus while pressing the front console buttons, you could quickly find this data. As long as they didn't pull a dirty trick like encrypting the data (why?).
    The repairman whom I got this from is ripping the other boards out of the (now scrap) unit, along with the motor in case there's current-monitoring where the unit will scram if it doesn't see a motor. And he'll get them to me eventually. So in theory I would be able to compile my own data. But that would only be for this and similar units, not for every machine out there. So just wondering if there's an existing database or website dedicated to this that anyone knows of. I know for other repair sectors there are collections of "dirty little secrets".
    Thanks in advance.
    Click image for larger version  Name:	IMG_20250106_233526.jpg Views:	0 Size:	488.8 KB ID:	3548005
  • Answer selected by Joe24 at 02-26-2025, 02:46 AM.
    Joe24
    • Jun 2021
    • 53
    • Eh?
    Awesome, figured it out! Special thanks to Joe24 , you've been a huge help! 🙄
    • petehall347
      • Jan 2015
      • 4451
      test the motor and work backwards if good
      • Joe24
        • Jun 2021
        • 53
        • Eh?
        As mentioned, I don't have the dryer, don't have the motor, and don't have the other boards. Will get them eventually (maybe), if and when the guy gets around to it.
        The core question here is: does anybody have experience with Maytag/Kenmore/Whirlpool bus codes, or know of a repair / hardware-hacking website where this sort of thing is explored?
        If I can command this board to turn the motor on, then I can see what (if anything) is going on. The problem may not even be on this board, it could be on main control board, etc.
        • Joe24
          • Jun 2021
          • 53
          • Eh?
          Based on the connections to the optoisolators, it appears that the 3 pins for data are GND, TX, RX. (Not Vdd/Vss/Data like the fictional interwebs would have you believe.) So, UART is looking likely.
          • Joe24
            • Jun 2021
            • 53
            • Eh?
            • redwire
              • Dec 2010
              • 3912
              Yes be careful the entire control board is hazardous live, there is no SMPS (isolation) transformer used with a LNK304, only an inductor.
              So that is why the opto-couplers are used.
              I would be curious what serial data is there. Because there is no standard for appliance diagnostics and why can't we look at what is shutting down the machine, instead of the usual expensive "replace everything" and "maybe you just buy a new dryer" rubbish.
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8352
                There is a high chance that the LNK304 is bad if it doesn’t power up. These things can play dead, but look absolutely fine with no shorts measured. I’d be looking at that and the caps around it first.
                  • Jul 2011
                  • 6070
                  What is the part number on “IS7,IS8,IS9”
                  It would help to know what the error code messages that was appearing when it was not working properly
                  • Eaglecrest
                    Whirlpool dryer control board
                    by Eaglecrest
                    I have a Whirlpool dryer that runs for a while then stops with a blinking timer screen. The dryer can't be reset by hitting any input and if you pull the plug and plug it back in it also won't respond. Light is on in the drum when you open the door, but no other sign of life. If I leave it unplugged for a period of time, which is multiple days, it runs again. May be able to get a load done, but now seems to be less than full load before it errors out.
                    Since unplugging will get it to work, I am assuming that there is an error condition that is causing the onboard processor to shut...
                    11-05-2025, 07:09 PM
                  • clearchris
                    Old Kenmore Clothes Dryer
                    by clearchris
                    So, this is a very, very old dryer, and I love it. I can take it apart almost with my eyes closed, it's usually very easy to repair. Anyway, the timer module refuses to advance. I replaced the timer module with a used one (new unavailable), it worked for a few weeks, and now the new (used) timer module isn't advancing again.
                    I opened up the first bad timer module, and the RSI contact was pretty toasty, there was a nearby burn mark like it suffered a big arc at one point. While I had everything apart, I tested the timer motor and it appeared to work. I cleaned the RSI contact and...
                    07-12-2022, 03:38 PM
                  • BigPete
                    Panasonic Heatpump Dryer Repair
                    by BigPete
                    I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                    The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                    In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                    Unfortunately the whole machine has to come apart to fix it.
                    I have...
                    11-01-2025, 06:40 PM
                  • wnlewis
                    Whirlpool RDE3340W electric Range needs On-Off-On rocker switch, McGill 0801-1059, FSP 686605, Whirlpool p/n 865745
                    by wnlewis
                    I am trying to track down a replacement rocker switch for a Whirlpool RDE3340W electric range.
                    The rocker switch was made by McGill under their part number 0801-1059 and supplied to Whirlpool by FSP under their part number 686605. Whirlpool's original part number was 865745.
                    The switch is an On-Off-On type (SPDT) designed for use with either 115 VAC or 230 VAC. It is not lighted.
                    Are there any current switches that could be substituted for this switch?
                    01-04-2025, 09:32 PM
                  • CapLeaker
                    Bosch Nexxt 500 dryer blinking start button - no start fix
                    by CapLeaker
                    My Bosch NEXXT 500 dryer quit today, press start nothing happens and the start button just keeps blinking. Not cool. Reset the dryer, same thing.
                    Even so the buttons feel good, my problem was the start button smd tactile switch on the PCB. Cleaned the switch with alcohol followed with Deoxit and the sucker runs like a champ again.
                    I like these easy evening fixes!
                    12-07-2023, 04:38 PM
