Pioneer VSX-44 receiver HDMI dropouts
  • RatherLoopy
    • May 2023
    • 7
    I have an older Pioneer receiver (VSX-44) that's been dropping the HDMI output (black screen) for a few seconds every few minutes. Setup is HTPC -> Pioneer DVD HCMI in -> Pioneer HDMI out -> Samsung TV HDMI in, all with cheap HDMI cables that have never caused trouble before..
    I initially found a lot of play in the receiver's HDMI inputs and output so I kind of squeezed them back into shape and they're making a tighter connection, but the problem persists.
    And also, often, the HDMI will drop out in exactly the same way (black screen) just as my central air conditioning kicks in, and often also when it kicks out. This is a 1,200 sq ft mobile home with a tiny air handler and small condenser, and the lights don't dim or even flicker when the AC kicks in..
    The HDMI signal from the HTPC is solid; when it's plugged straight into the TV it never drops out or even flickers.
    Does this problem ring a bell with anyone? Can anyone recommend further non-multimeter troubleshooting or DIY fixes before I put it in the shop?
  • budwich
    • Jul 2015
    • 3097
    Re: Pioneer VSX-44 receiver HDMI dropouts
    Can you expand on the history the problem? You mention that you have an "older" receiver, so it has been around. Has the problem always existed / when did it start?
    Further, when resolutions / upscaling settings are you using.... bets are 4k. :-) Force the lowest scaling (720p) and see if it has any impact. Go from the result.
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8340
      I’d try cleaning the cable end and the jacks on the receiver with 99% ipa followed with something like Deoxit from Caig. Maybe known good set of HDMI cables, heating up the receiver with a hair dryer (open the lid and clean and heat the boards up a bit, so they are nice and warm, but not so you burn yourself) that’s all you can do without breaking out a multimeter. If you put it to the shop, the tech has to be able to replicate this. So before you do that, I’d set this up at a friends place and make sure this issue is repeatable.
      Let’s say the problem is repeatable, the techie needs a bit more than a multimeter, which then more $$$ come to play.
      • RatherLoopy
        • May 2023
        • 7
        I can't help with the history of the receiver. I bought it off Facebook Marketplace a couple of months ago and the first time I powered it on, it was dropping out every few seconds. I noticed extra play in the HDMI ports so I opened it up and kinda bent them back into shape, and things seemed good... only occasional blackouts until lately.
        I've done as you suggested and changed my video card's resolution to 1280 x 720. My video card is an OEM Nvidia GeForce 640 in an ancient Dell on which I'm running Kodi). I noticed while setting the resolution that my video card was set to take its config from the Nvidia control panel, so I set that back to its default settings so that Windows 10 would control the video.
        I've wired the HDMI back through the receiver and it looks good so far, but time will tell.
        Thanks for your help!
        • RatherLoopy
          • May 2023
          • 7
          I'd try cleaning the cable end and the jacks on the receiver with 99% ipa followed with something like Deoxit from Caig. Maybe known good set of HDMI cables, heating up the receiver with a hair dryer (open the lid and clean and heat the boards up a bit, so they are nice and warm, but not so you burn yourself) that's all you can do without breaking out a multimeter. If you put it to the shop, the tech has to be able to replicate this. So before you do that, I'd set this up at a friends place and make sure this issue is repeatable.
          Let's say the problem is repeatable, the techie needs a bit more than a multimeter, which then more $$$ come to play.
          Thanks so much for your input! You're 100% correct that it needs to be a reproducible problem if I take it to the shop and so far... it's wildly intermittent. I was kinda thinking of just having the HDMI ports replaced, or giving it a go myself. I've never done any SMT work vids I've seen make me think I could give it a go. As far as $$$ goes, I didn't pay much at all for the receiver and would rather repair it (if possible) than add it to my growing stack of dead receivers.
          I've got IPA and DeOxit on hand so I should give that a go. Sure wouldn't hurt anything. When you speak of heading up the board, are we talking about re-liquifying all the solder joints? Would a heat gun be better or worse than a hair dryer?
          • budwich
            • Jul 2015
            • 3097
            hmmm.... that likely suggests a cabling problem. Get a bluray player and hook it up and see what the result is. One other question is how long are the cables that you are using.
            Having said that, you need to be specific on what the resolution was during the problem. Further, any "auto" type setting may cause problems when things are "marginal" along the signal route so your need to specifically choose a "known res". When a computer is involved, you need to ensure that the resolution is supported by all things along the route. In terms of hdmi, there are very specific choices.... usually 720p / 1080p. In addition, frame rates also have to be considered.
            Still further, you mentioned a potential connector issue, try other ports on the receiver to see if that helps.
            As mentioned by capleaker, getting it repaired by a tech will likely be $$$$.
            I would exhaust the suggestions that I mentioned before attempting to "disturb" the interface board on the receiver.... risk is high that you will cause
            problems.
            • RatherLoopy
              • May 2023
              • 7
              problems.
              Thanks again for helping me! I like the idea of trying it with a bluray - that would eliminate a lot of variables. It may take awhile for the problem to re-appear after rewiring the HDMI through the receiver last night, but I'll definitely try that when the dropouts start again.
              Intriguing point about the HDMI cable. From the PC to the receiver, I'm using a skinny 25-foot cable that I bought on eBay a few years back for around five bucks (I'm so poor... lol). I'm wondering if the insertion of the receiver in the chain is degrading an already-marginal HDMI signal... I could certainly spring for a somewhat better cable or move the PC into the same room as the receiver/TV to shorten the signal path so I could use a better cable.
              The video card resolution was set to 3,840 x 2,160, which was marked as native resolution for the Samsung TV. I don't really need 4K, though, so I'd be just fine with a lower res (1080) if that turns out to be a contributing factor. In terms of the signal path, everything component involved supports 4K but there are varying HDMI versions throughout; GPU 1.4 Receiver 2.0 TV 2.1.
              I have tried different receiver HDMI ports. Some seem better than others but none have been problem-free.
              I will certainly do so! Taking a soldering iron to that board would be a last-ditch Hail Mary before heading to the shop (or tossing the receiver on the pile).
              Thanks again, budwich, those are some promising troubleshooting ideas! It seems stable now so it may take hours, or even days, to know if the resolution switch has eliminated the problem, so please stay tuned. I'll update the thread as/when appropriate.
              • RatherLoopy
                • May 2023
                • 7
                problems.
                My video has been rock-solid ever since lowering the resolution to 720. I bumped it to 1080p last night and it's still solid, so I'm going to leave it there and take a break from the darned thing, and just watch some flipping TV for a change.
                I've alwyas had a "wire is wire" kind of attitude about cabling but in this instance, I'd like to upgrade my HDMI cabling. Do you know of a budget mid-grade cable I should be looking at for a 25-foot run?
                Thanks again for your help, budwich. I won't be surprised if the problem resurfaces, but you've given me some good troubleshooting steps to follow for next time!
                • budwich
                  • Jul 2015
                  • 3097
                  25 ft is pushing most hdmi cables in general. You can find the certification spec hdmi on the net. Certainly, the higher PC res that you originally had would be an issue / hit or miss.
                  I haven't bought any cables in a long time as my configuration has been stable although I do run a 30 ft cable to a projector. The other thing that you have to worry about is the "drive power" of the hdmi interfaces involved. Not all devices are designed to push a signal "long distance".... again hit or miss. Some repeater / splitter can be use to increase distance along with things like "active cables" (hybrid or otherwise).... but then $$ start to get involved. I suspect you will likely be able to run 1080p readily as long as the cable hasn't kinked or otherwise in its history damaging any internals of the sheath.
                  • RatherLoopy
                    • May 2023
                    • 7
                    Sounds good, budich. Thanks again for your help!
                    • Servicem4
                      Pioneer lx 701 hdmi issues
                      by Servicem4
                      My receiver pioneer LX 701 doesn't work anymore correctly The history:
                      6 month ago hdmi picture output didnt work anymore but music input through hdmi still worked.
                      Since some weeks even this doesn't work. Right Before this occured i heard a plopping noise from the receiver one evening.
                      The rest of the receiver works, I used spdif for sound input.
                      I now opened the receiver and hoped to find a blown fuse but all look good.
                      Any tips how to progress? Between 2 PCB there is something which looks like a blown cap....
                      Image 20250527-204839 hosted in ImgBB
                      05-27-2025, 01:13 PM
                    • CDNBrewer
                      Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
                      by CDNBrewer
                      Hello Everyone,
                      I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
                      Symptoms:
                      • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
                      • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
                      • I swapped the Left and Right surround
                      08-05-2025, 09:29 PM
                    • spleenharvester
                      Toshiba 50UL2063DB randomly rebooting with HDMI-CEC and/or HDMI-ARC enabled
                      by spleenharvester
                      I have this TV hooked up to only an AppleTV 4K and a Creative soundbar. Originally HDMI-CEC and HDMI-ARC wouldn't work at all, I replaced all the HDMI cables with decent UGREEN cables meeting the latest standards, now it all works perfectly but once or twice a day the TV itself reboots while watching a program, the AppleTV keeps running. I haven't fully pinned down whether it is ARC or CEC causing it yet. All are running latest firmware.
                      I assume it is just HDMI-CEC being buggy as usual on a shitty Vestel machine, but can anyone think of anything I can try before disabling it?
                      03-12-2025, 03:42 PM
                    • RossMoodley1967
                      LG LCD TV HDMI PORT FAULTY
                      by RossMoodley1967
                      LG LCD TV picture comes on intermittenly using hdmi port.The sound is on permantly.The hdmi ports looks fine and soldered in securely.The 3.4v coming to the main board is not present(not sure if will affect the hdmi port or where that voltage goes.)The hdmi cable is fine because it works on another tv.The ceramic caps connected to the hdmi controller ic is reading 39 ohms.Could the hdmi controller ic be faulty(feels very warm to touch).The RCA jacks work normally .Thank you in advance for your assistance..
                      02-28-2024, 08:38 AM
                    • suiramix
                      Pioneer VSX-532 receiver HDMI light blinking
                      by suiramix
                      Hi there,
                      Pioneer VSX-532 receiver almost new, HDMI red light blinking , performed reset (power + surround button for 5 seconds), remove speakers, the amplif power up but after few sec smoke came up from resistor R16FL. Should I go head and remove the final transistors or just Q4FR ?...
                      05-23-2019, 07:45 AM
