Jbl prx515
  • Amraks
    • Nov 2011
    • 725
    Jbl prx515
    I have a JBL speaker unit that all of a sudden is not outputting after a few minutes with sound.
    This one has me baffled.
    Anyone have a schematic also?
    Freezing in a certain area of the board does this make this come on. not sure if this is a overheating issue or a badsolder joint or some other component.
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8283
    Re: Jbl prx515
    Just go along the audio chain while playing something like a 1khz tone. Try a can of air upside down and freeze certain IC’s or check every stage with the oscilloscope. If it is a bad op amp audio goes in and nothing comes out. Does the length of time it plays audio change by different volume settings?
    • Amraks
      • Nov 2011
      • 725
      Re: Jbl prx515
      I have found a similar schematic for a the JBL PRX 518
      In the schematic RT2 is meant to be 20kohms
      RT2 = 15kohms
      while this is on spraying RT2 with freeze spray outputs the sound again.
      Question I have is this RT2 bad?
      • Amraks
        • Nov 2011
        • 725
        Re: Jbl prx515
        Here is the schematic for a similar model prx518
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8283
          Re: Jbl prx515
          When the audio disappears, can you make it come back by freezing that component?
          • Amraks
            • Nov 2011
            • 725
            Re: Jbl prx515
            It was a dry solder Joint on the transformer, I touched up all the joints around this area including smd components.
            I discovered if i pushed on u7 it would start again didn't need the freeze spray at all.
            its working and not cutting out anymore.
            I should of done this sooner as its been in my road for awhile now.
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8283
              Re: Jbl prx515
              awesome! Another one saved from the dump.
              • CornholioGSM
                Macbook Pro 15" 2018(820-01041-A) Freezing, Rebooting, Kernel Panics but only with connected Battery
                by CornholioGSM
                I have here one interesting problem.
                Laptop comes to me with freezing and rebooting problem. All inside was relatively clean and no water damage. Only visible problem was one swolled cell on battery...all was looking like batt problem.
                I have put inside new - not original batt, but problem with freezing still. I am able to boot into os, then pc can run few seconds, then freezes and reboot and reboot until force power off.
                Quickly i am able to see battery information...batt is detected normally in os with power cycles hours...
                06-25-2024, 12:27 PM
              • maleksa
                Yamaha MOX8 boot freeze and distorted sound
                by maleksa
                My Yamaha MOX8 synthesizer recently developed two issues.
                Firstly, after booting up, it operates as normal. However, after about 5 minutes, the sound starts to get distorted (broken up screeching sound) almost like putting it through a guitar distortion pedal. After a while, the distorted sounds will go away for a while and comes back. At times, the synthesizer will also freeze I need to power off and on again.
                Secondly, when powering off and on again, there will be times where the synthesizer will freeze during the boot sequence (freezes at the MOX8 Opening Screen),...
                11-07-2024, 03:28 AM
              • EsIstSimon
                Lenovo Ideapad 5 15ARE05 random freeze
                by EsIstSimon
                Hi there,
                i have a Lenovo Ideapad 5 15ARE05 that will freeze randomly.
                Sometimes it wont even post, sometimes i can use it for a couple seconds or minutes before it completely freezes.
                Sometimes the screen freezes, but still displays the last frame, sometimes (pretty rare) the screen goes black
                It does not matter what i do. Installing windows, starting Fedora or just sitting in the bios. After some time it will freeze.
                When the freeze occurs, the laptop draws a pretty constant wattage (it will just stay on the value that it draws, when it locks...
                12-21-2022, 03:03 AM
              • asussucks
                Asus vivobook pro 14x - N7400PC - ram issues, will randomly freeze and displays signs of the ram being disconnected/bad
                by asussucks
                Hi there,
                this is my first post so bear with me
                my device is no longer in warranty. I am comfortable with doing minimal operations on the device. it has no data I formatted it thinking it's a software bug at first, but no it's something else.
                What I tried: running it with disabled dGPU, running it with an external screen, resetting everything, using Linux on it instead of windows, reinstalling BIOS, using a different SSD, running it without internet, keeping it plugged to a wall, using a desktop cooler on the CPU, praying to god, contacting the CEO'S office...
                08-31-2025, 09:16 AM
              • martin83
                Asus Rog G513qr Freezing
                by martin83
                Hello everyone.
                I am here to ask for help identifying a problem with an Asus Rog G513qr, Ryzen 9 5900x and RTX 3070.
                The laptop turns on but turns off or freezes when connecting a USB flash drive (even during the ROG logo). Even without using the USB ports, the laptop is unstable and when the charger is disconnected, it freezes.
                A few months ago, the laptop started freezing when powered only by the battery and in power saving mode.
                After replacing the NVME disk and replacing the liquid metal, thermal grease and thermal putty, it got worse and...
                06-11-2025, 12:35 PM
