Bypass works, direct out works. Delay signal is not right. Clock seems to be working. I replaced all 10uf electrolytics just because. No change. Based on sound and experience, should I be looking at the AD part or the DA part? I found a breakdown of how the microcontroller samples 12bit audio, I have a scope, I plan on doing more probing, just bothering me as I sit at home with it on my bench at work waiting to be fixed. If I'm reading correctly pin 7 on IC5 should be ≈ input signal. And pin 7 on IC8 should be delayed waveform? So if I have clean delayed waveform on IC8, the problem is somwhere on the bottom right of the scheme correct? Or in the feedback circuit?
Schematic:
https://www.freestompboxes.org/downl...e04d6bdf7033e8
Thanks for any insight
Schematic:
