Pioneer VSX-40 shut down after a few seconds
  • withalligators
    • Jun 2013
    • 267
    Hey folks,
    This is the first receiver I'm attempting to fix. It is another e-waste bin rescue. After plugging in, it powers off after a few seconds and smells slightly of burnt electrical components. I imagine this is a protection mode. It isn't hooked up to any speakers or anything. Any idea where I should start looking? What is the general methodology to repairing a receiver in protection mode?
    Cheers,
    Alex
  • tibimakai
    • Jan 2012
    • 3680
    Re: Pioneer VSX-40 shut down after a few seconds
    I would start by measuring the final transistors on the big heatsink, I would look for a short.
    • particleman
      • Mar 2014
      • 28
      I would start with a service manual.
      • withalligators
        • Jun 2013
        • 267
        Couldn't find an SM. I thought I found on on elektrotanya, but after downloading it, it was for a different model.
        I'll see if I can find anything on the big heatsink.
        Thanks,
        Alex
        • tibimakai
          • Jan 2012
          • 3680
          Maybe, you can use a similar model's SM.
          • wolf1976
            philips 42pfl3506 working for few seconds and after shut down
            by wolf1976
            hi
            i have the above tv it turns on for few seconds and after shut down
            can you suggest me what can be cause this problem ?
            05-25-2024, 12:18 PM
          • zklgfs
            Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
            by zklgfs
            I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
            08-11-2025, 02:14 PM
          • twonk9098
            Lenovo Legion 5 high fan spin turns off after 34 seconds
            by twonk9098
            I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
            I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
            I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
            I have tried a few new bios but exactly...
            07-14-2024, 11:19 AM
          • Rolin
            Lenovo Legion 5 15IMH05H No Display
            by Rolin
            I have a Lenovo Legion 5 15IMH05H 81y6003yUS that someone asked me to help them with a failing SSD. I installed a new SSD, fresh Win11 installation, updates, etc. Very standard stuff and everything was completed. He said he'll pick it up in a few days so I shut it down and set it aside.
            A few days later came and now it won't POST an image, keyboard lights up, fans spin then shuts itself off after about 40 seconds. I've already tried the typical draining capacitance and removed CMOS battery,etc. No display on an external HDMI monitor as well.. No idea what happened. Suspected a BIOS...
            06-21-2025, 11:32 PM
          • liquidzorch
            Lenovo 15iml05 Power led lights for 12 seconds then off 12 seconds
            by liquidzorch
            Hello. I bought a faulty Lenovo ideapad 3, but it turns out the 3Valw buck converter burnt a hole through the board. I was able to clean it up, and remove all the shorts. I now can power the 3.3v rails from a bench power suppy while connecting the laptop to its psu, and I get the additional 5valw, 1.8v, and 1.05v, form what I can tell in the schematics, those are the only 4 voltages I should see before turning on, and they are present. When I hit the power button, the power indicator on the left side turns on (not the one on the power button), stays on for about 12 seconds, then turns off for...
            10-18-2024, 05:19 PM
