My RX-V677 decided to quit on me.The standby light is not there and when i turn it on it just blinks. I have checked the error codes and there is one `PS3 PRT:127 L` Looks like its a power supply issue. Checked the manual and normal values are
Normal value PS3: 132 to 168 and it monitors 5.5V
I have checked the value of the voltage and it is exactly 5.5V tested. I do get System Version error but i believe it might be because eeprom is not powered up. I have checked these points and the Yellow ones show exact 5.5V. However, the connector highlighted in Green shows 0V. Not sure there should be but i think so.
Any guidance on how to resolve the issue would be appreciated.
PS. I do have soldered all joints on power supply board. I was thinking the power supply might be showing 5.5 v but not sure how to load test? for now even during service mode (brief) the 5.5V email stable.
If I disconnect W108 the device stays on in service mode and does not turn off. But does show the PS3 error. If i connect back W108 (board diagram bottom right) after some time it turns off. Thinking if i should dismantel the bottom board or diagnose on this board?
