Hello to you all. I have been browsing for a couple of days now about my problem but i was unable to find solution so i will try here
I bought used Denon avr 2802 faulty. Receiver turns on like it should relay cliks it responds on all commands ( volume change on lcd, switching between sources , mode selector... ) but there is no sound , i downloaded service manual , i checked all voltages on supply rails and everything looks normal and as it should. I traced input signal from dvd input and signal is lost on TC9459N , there is input signal present on pin 5 and 24 , but no signal is getting out from it od pin 3 and 26. so i assume that this chip is faulty??? But this is present only on DIRECT and STEREO mode on every other mode there is no signal present on input pin of TC9459N. Yesterday when i powered it up i have noticed that there is slight sound on speaker but very very faint and this only happens when you powered it up as soon as you change input source and return it to DVD again there is no signal. I have checked all big amp chips, there is no short on any of them . I ran out of ideas where to check so any help will be appreciated.
Thanks in advance.
Thanks in advance.
