Samsung Syncmaster 245B - Screen freeze -> screen flash 4 diff colours
  • drkbef
    • Oct 2011
    • 9
    My monitor has experienced a major malfunction. The screen will randomly freeze, and then get uncontrollably brighter and brighters. Sometimes I can use ctrl+alt+del to snap it out, but now it starts rotating the same four screens over and over again. It will switch from dark, to white, to blue and to red-gren-blue-white stripes.
    I searched Google for some answers, and best I could find was this video on Youtube which demonstrates the exact issue I'm having:
    http://www.youtube.com/watch?v=5ulXm4Wix5k
    The poster was able to get Samsung to replace it, however, my warranty expired back in July. What could be wrong, and what is my best option? I would like to see if it is fixable since it is so hard to find any 16:10 monitors for a decent price anymore.
    Thanks!
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Samsung Syncmaster 245B - Screen freeze -> screen flash 4 diff colours
    It could be capacitors. You will have to open up the monitor and look at them.
    For best picture quality and clarity take your boards to a window on a sunny day, turn flash off, and use macro mode. Take a top down view of all your boards (front and back). Make sure the photo is legible so that we can read the PCB printing clearly. A shutter speed of 1/125 or faster will produce nice clear focused pictures. Try to get a photo that is 2000x2000 resolution or as close as possible.
    Here is an example of the pictures we want.
    https://www.badcaps.net/forum/showpo...94&postcount=1
    You can post pictures here and member can help you. Please follow the guidelines in my sig file below.
    --- begin sig file ---
    --- end sig file ---
    • drkbef
      • Oct 2011
      • 9
      Thank you for your kind reply!
      I will do as you ask later in the week when I have time.
      • drkbef
        • Oct 2011
        • 9
        Sorry for the ridiculous delay in getting these images. Just started a new job and things have been hectic.
        Anyway, I have some even closer shots of the boards done in sections should you require. Please let me know.
        Thank you again for your attention and help!
        • retiredcaps
          • Apr 2010
          • 9271
          1) The pics you supplied are excellent. Clear and focused. I wish more people could do the same when asking for help.
          2) You have at least 2 domed/bulged (I'm sure you can determine which 2 are obviously domed) caps by connector CN801 (bottom right hand corner). At minimum, I would replace all 4 in that section.
          3) There are 15 electrolytic caps in total. Since this is a nice big monitor, most here would recommend replacing all of them except the largest one which rarely, but not never, fails.
          4) Capacitors (C designation on the PCB board) die from age, heat, and shoddy build quality. Capacitors DO NOT have to be visibly bloated in order to bad. They can be out of tolerance uF (a 1000uF measures 20uF) and/or have high ESR (ohm). A multimeter will be insufficient to test for ESR. For that you need an ESR tester which costs between $50 and $300.
          5) PCBONEZ talks about how to choose the right series at
          https://www.badcaps.net/forum/showpo...47&postcount=3
          6) If you don't want to do all that work in step 5, then choose Panasonic FR, FM, and FC caps (in that order of preference) from digikey following PlainBill's ordering instructions at
          https://www.badcaps.net/forum/showpo...33&postcount=2
          • PlainBill
            • Feb 2009
            • 7034
            Excellent pictures. I've marked one of them up and attached it.
            Two caps circled in red - obviously bad. The must be replaced with low ESR name brand caps, such as Panasonic FM series.
            Caps circled in yellow. The recommendation is to replace them with low ESR name brand caps such as Panasonic FM.
            Cap circled in blue. Replace if you wish; it is unlikely it is bad.
            Shucks, retiredcaps beat me to it.
            PlainBill
            • retiredcaps
              • Apr 2010
              • 9271
              Also this monitor has problems with the resistors burning up. The three that are suspect are the ones just right of the BN44-00175A. I believe they should read 68 Ohms as per this megathread ...
              https://www.badcaps.net/forum/showth...=245b+resistor
              Since you have the monitor open, it is best to test them now and compare them to the color band as per
              http://en.wikipedia.org/wiki/Electro...r_and_inductor
              Even if they are good, you might want to pre-order spares along with the replacement caps to save on future shipping.
              • drkbef
                • Oct 2011
                • 9
                Wow, such quick replies, you guys are really impressive!
                This is my first time with any electronics repair, and it is kind of intimidating. I'll have to do my research this week on how to replace caps on a board.
                Thank you both RetiredCaps and PlainBill, you're both great!!
                • retiredcaps
                  • Apr 2010
                  • 9271
                  This site has a good recap tutorial at
                  https://www.badcaps.net/forum/showthread.php?t=485
                  Good soldering video at
                  http://www.youtube.com/watch?v=I_NU2ruzyc4
                  If you are not going to do another repair in the future, maybe get one of your family/friends to replace the caps for you.
                  If you are going to replace the caps on your own, then maybe practice on a couple of junk boards?
                  • drkbef
                    • Oct 2011
                    • 9
                    Sadly, I don't have anyone that regularly solders electronics... My only option would be to learn myself, or just buy a board :P
                    • drkbef
                      • Oct 2011
                      • 9
                      I was looking at getting one of those capacitor kits sold on ebay. I messaged the seller, and these where the ones he said came in the kit:
                      1 - 10V 2200uF, Panasonic FM
                      2 - 35V 1000uF, Panasonic FR
                      2 - 10V 1000uF, Panasonic FM
                      1 - 35V 470uF, Panasonic FM
                      1 - 50V 100uF, Nichicon PWM
                      1 - 63V 68uF, Panasonic FC
                      2 - 50V 47uF, Nichicon PWM
                      1 - 10V 47uF, Panasonic FC
                      1 - 50V 22uF, Panasonic FM
                      1 - 50V 10uF, Panasonic FC
                      1 - 50V 1uF, Panasonic FC
                      1 - Resistor uF-3 2w (That triple resistor that often fails in this model monitor)
                      Cost to me would be 16.95 US + 6.95 shipping (I'm in Canada)
                      I don't understand the mixing in of the Nichicon capacitors with the Panasonics... Maybe he doesn't have the equivalent Panasonics on hand.
                      Do these look like they will work?
                      Thanks,
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        See below.
                        He probably doesn't have stock in hand and uses substitutes which is fine.
                        If you follow PlainBill's quick instructions at
                        https://www.badcaps.net/forum/showpo...&postcount=399
                        you can find out that ordering on your own will save you a few dollars and you get all Panasonic caps.
                        I did it just to see what the markup was. Keep in mind that the ebay seller is making much more because he buys in bulk whereas this is only quantity = 1 or 2.
                        1 1 P12357-ND CAP ALUM 2200UF 10V 20% RADIAL 0 0.91000 $0.91
                        2 2 P14445-ND CAP ALUM 1000UF 35V 20% RADIAL 0 1.08000 $2.16
                        3 2 P14378-ND CAP ALUM 1000UF 10V 20% RADIAL 0 0.65000 $1.30
                        4 1 P14441-ND CAP ALUM 470UF 35V 20% RADIAL 0 0.76000 $0.76
                        5 1 P12392-ND CAP ALUM 100UF 50V 20% RADIAL 0 0.48000 $0.48
                        6 1 P10341-ND CAP ALUM 68UF 63V 20% RADIAL 0 0.51000 $0.51
                        7 2 P10321-ND CAP ALUM 47UF 50V 20% RADIAL 0 0.36000 $0.72
                        8 1 P11180-ND CAP ALUM 47UF 10V 20% RADIAL 0 0.47000 $0.47
                        9 1 P14452-ND CAP ALUM 22UF 50V 20% RADIAL 0 0.35000 $0.35
                        10 1 P10316-ND CAP ALUM 10UF 50V 20% RADIAL 0 0.35000 $0.35
                        11 1 P10312-ND CAP ALUM 1UF 50V 20% RADIAL 0 0.35000 $0.35
                        12 3 PPC68W-2CT-ND RES 68 OHM METAL FILM 2W 5% 0 0.58000 $1.74
                        Subtotal $10.10
                        Shipping $8.00
                        GST unknown
                        HST unknown
                        Total unknown
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          One other MAJOR thing. Manufacturers routinely make revisions and sometimes completely change boards. So CHECK your board with the capacitors above BEFORE ordering.
                          PS. Also make sure the height and diameter are okay for your board.
                          PPS. Now would also be a good time to add other things (maybe soldering items) to the digikey order to "ammortize" the $8 USD shipping/handling.
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            I should mention that the PPC68W-2CT-ND part number came from the 245B megathread at (thanks to PlainBill)
                            https://www.badcaps.net/forum/showpo...&postcount=334
                            Feel free to substitute as you see fit.
                            • drkbef
                              • Oct 2011
                              • 9
                              Thanks for the heads up to double check my board.
                              Oddly, my board has 3x 47UF 50V instead of 2 of those and a 47UF 10V. I would have been really confused what to do with that 10V when it arrived :P.
                              • drkbef
                                • Oct 2011
                                • 9
                                I forgot to add, the three resistors on the bottom that everyone recommends to replace are all stuck together with this weird yellow gunk. I tried to gentle wobble the resistors, but this stuff has a death grip on them. What is it and how do I safely remove it so I can replace the resistors?
                                • retiredcaps
                                  • Apr 2010
                                  • 9271
                                  That was new white glue when assembled at the factory to hold the components in place. After time and heat it turns color and can be conductive.
                                  You can use whatever (exacto knife?) to remove it and when you replace the resistors just install them that so they are not touching. You don't have to replace the glue, but I think you can use silicon caulk to hold them in place to ensure they don't touch.
                                  • drkbef
                                    • Oct 2011
                                    • 9
                                    I have finally finished the job. While I am not happy with a lot of the solder joints I made (if you look at the picture), my monitor is, however, functioning right now, so that has to be a good sign! I am staying guarded because the monitor would work for a while before having issues, so we'll see. I also changed the resistors and scraped most of the yellow glue off. After more research, and an inability to find silicon that I was 100% comfortable using on my board, I opted to use heat shrink tubing to insulate them. It seems to be working OK with less mess.
                                    I wanted to sincerely thank you both, retiredcaps and PlainBill. It was your help and kind support that gave me motivation and confidence to attempt to fix this myself.
                                    Thank you!
                                    • retiredcaps
                                      • Apr 2010
                                      • 9271
                                      Good job. Glad you got it working.
                                      • Perineum
                                        • Aug 2010
                                        • 30
                                        I previously recapped my 245B and it worked for some time. Now it does exactly as described above.
                                        All caps were replaced with Panasonic FC and the big one was replaced with a Nichicon AR. Resistors were replaced with heavier wattage ones.
                                        There is one Nichicon VZ 470uf 35v near CN801 and a Panasonic NHG 22uf 50v near the infamous 3 resistors
                                        None of the caps look bulged in any way. Is this now failing from wrong series caps?
                                        • warsztat
                                          Trademi Horizon, freeze after start.
                                          by warsztat
                                          Hi, trademil Horizon freeze after start like video, i try reset (3sek push stop), remove and I put new ones capaticors 3,3V line digital and analog line.
                                          The device in service mode passes all tests, except for the display test, where it hangs. The display in service mode during engine testing, etc. seems to behave correctly, it shows values, the engine is working, I can adjust its speed but only in service mode, in normal operation after pressing start the machine freezes
                                          All the multiplexers that support the display seem to be working. It's like the processor...
                                          03-06-2025, 07:33 AM
                                        • Mandor
                                          Samsung Syncmaster 245b BN44-00195A
                                          by Mandor
                                          Hello people.
                                          I have the samo problem as described in this thread:
                                          https://www.badcaps.net/forum/showth...highlight=245b
                                          The monitor was on standby and one day the screen (or just the backlight) would not turn on. Computer still recognized the monitor and was acting like it was there (5 screen setup). I switched the monitor off with the big switch by the cable, waited 5ish seconds and switched it back on. I heard a loud bang.
                                          Both fuses blown, resistor blown, bad mosfets.
                                          I checked most electrolitic caps in circuit and...
                                          08-06-2020, 10:19 AM
                                        • maleksa
                                          Yamaha MOX8 boot freeze and distorted sound
                                          by maleksa
                                          My Yamaha MOX8 synthesizer recently developed two issues.
                                          Firstly, after booting up, it operates as normal. However, after about 5 minutes, the sound starts to get distorted (broken up screeching sound) almost like putting it through a guitar distortion pedal. After a while, the distorted sounds will go away for a while and comes back. At times, the synthesizer will also freeze I need to power off and on again.
                                          Secondly, when powering off and on again, there will be times where the synthesizer will freeze during the boot sequence (freezes at the MOX8 Opening Screen),...
                                          11-07-2024, 03:28 AM
                                        • soopacrucial
                                          by soopacrucial
                                          Hi folks,
                                          10-29-2024, 02:40 PM
                                        • EsIstSimon
                                          Lenovo Ideapad 5 15ARE05 random freeze
                                          by EsIstSimon
                                          Hi there,
                                          i have a Lenovo Ideapad 5 15ARE05 that will freeze randomly.
                                          Sometimes it wont even post, sometimes i can use it for a couple seconds or minutes before it completely freezes.
                                          Sometimes the screen freezes, but still displays the last frame, sometimes (pretty rare) the screen goes black
                                          It does not matter what i do. Installing windows, starting Fedora or just sitting in the bios. After some time it will freeze.
                                          When the freeze occurs, the laptop draws a pretty constant wattage (it will just stay on the value that it draws, when it locks...
                                          12-21-2022, 03:03 AM
