Hi BadCaps Forum!
I've gotten interested in learning electronics lately and a few weeks ago I got 2 broken LCD screen that I thought would be good to start to troubleshoot/try to fix.
Before I get started I want to say that I've read all the threads I see when I search for DAC-19M008 here on Badcaps.
There was a bunch of useful information there, and I have come to the conclusion that most likely one of the AOP605 mosfets is fried,
but since I can't seem to find any replacement parts where I live, I wanted to double check so that it's as I suspect before ordering the parts from abroad.
So, here we go.
The monitor is a ACER 1916w. The first thing I checked was if the LCD was still functional, this mostly because I was thinking to make this screen into a diy projector,
but I realized that the panel is to big and also I could use a secondary screen and 19' would be perfect. So using a flashlight I can see that the LCD panel is still Ok, and shows the graphic it is suppose.
So I decided to open the monitor up and see if there was some loose cable to the back light or some easy fix like that. But no go.
What I did after this was to google it, which lead me here. And after reading all I could in you forums I will now post yet another ”help my dac-19m008 is busted” (BF Rev-1A).
In the picture ””DAC-19M00B-BF-01A-TOP”” you will see the different values I got when I checked the voltage on the caps (just after unplugging power) I also checked the fuses and the mosfets.
And if I understand what I read here on the forum, the problem seems to be the first AOP605 mosfet on IC201,
it's the only mosfet giving me a low resistance response (~1-2 ohm using my multimeter set to 200ohm)
The other 3 is not giving me any value on the multimeter, and as I understand when the mosfet malfunctions it's common that it shorts and gives a low resistance reading.
(All the images are also attached in this post)
Symbol - Reading - Info from manual (M = Measure?)
C200 - 0v - ALMINUM CAP, 25v 220uF M 8*11,5
CE101 - +18v - ALMINUM CAP, 25v 220uF M 8*11,5
CE102 - +18v - ALMINUM CAP, 25v 1KuF M 10*20 TP5
CE103 - +18v - ALMINUM CAP, 25v 1KuF M 10*20 TP5
CE104 - 0v - ALMINUM CAP, 10v 1000uF M 10*16 TP5
CE105 - 0v - ALMINUM CAP, 10v 2.2mF M 13*20 TP5
CE108 - 0v - ALMINUM CAP, 25v 330uF M 8*16
CE109 - 0v - ALMINUM CAP, 25v 220uF M 8*11,5
These are done with my multimeter set to 200 Ohm
IC201 AOP605
S1-G1 2 Ohm
S1-D1 0,5 Ohm
G1-D1 2 Ohm
S2-G2 ---
S2-D2 ---
D2-G2 ---
IC202 AOP605
S1-G1 ---
S1-D1 ---
G1-D1 ---
S2-G2 ---
S2-D2 ---
D2-G2 ---
My conclusion after this is that mosfet 1 on IC201 should be dead right?
The F200 fuse is also blown, but this I understand is quite common with mosfet malfunction (or maybe the other way around?)
What makes me a bit confused though is what I should do with the caps, are they busted,
or do I get these readings because the blown F200 fuse and the faulty mosfet, or should I just go ahead and replace them all just for the sake of it?
I've also attached 2 pictures of the caps in profile, and they look pretty ok, but then again I'm a rookie in this subject
Please let me know if there is something else I should check, or if there is something I've done completely backwards
Have a good one!
So, here we go.
IC201 AOP605
S1-G1 2 Ohm
S1-D1 0,5 Ohm
G1-D1 2 Ohm
S2-G2 ---
S2-D2 ---
D2-G2 ---
IC202 AOP605
S1-G1 ---
S1-D1 ---
G1-D1 ---
S2-G2 ---
S2-D2 ---
D2-G2 ---
Have a good one!
