ASUS VG32UQA1A t-con board issue
  • damndenis
    Clueless
    • Nov 2024
    • Lithuania
    Hello everybody,
    This is my first post here, I've always loved to tinker with electronics, but never got in-depth with it. Hope I can learn a thing or two from this forum.
    I've got a 31.5" Asus monitor which distorts/flickers at equal intervals of a couple of seconds. From what I've gathered, it's an issue with the T-CON board, but feel free to correct me. Shipping from the manufacturer would cost 3x as much as the part itself. I was wondering, if there is a way to diagnose the board itself and replace the faulty components? I'm good with soldering, but not at all with the former. And if not, how can I find a substitute board that will be compatible with my monitor?
    Monitor output video:
    https://youtube.com/shorts/D6s7ic-kEBw
  • Soulzink
    Samsug washing machine. Power supply DC41-00189a board issue
    by Soulzink
    I am trying to fix a samsung washinmachine power supply main board.
    I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
    Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
    The power supply board reference is the following: DC41-00189a
    I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
    04-19-2025, 06:26 AM
  • Sharx112
    ASUS VA27EHE randomly unstable
    by Sharx112
    Hello community. I've got an ASUS VA27EHE with a Panda LC270lf1l01 panel that started to behave strangely. A bit of intro:
    If you power on the monitor without any inputs it turns on, displays the ASUS logo, shows no signal and goes into standby normally. When you plug it via HDMI sometimes and more recently, most of the times, it distorts the bios logo with horizontal lines, then when loading into windows 50-50 the windows emblem also is in horizontal lines. And after the system loads it almost always works properly, lol. On some rare occasions a part in the top of the monitor is being distorted...
    03-26-2025, 03:42 AM
  • Asraf Atb
    Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
    by Asraf Atb
    Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
    Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
    I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
    01-27-2025, 05:02 PM
  • x_orange90_x
    TCL 50S535 bad tcon or panel issue?
    by x_orange90_x
    Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
    03-29-2025, 11:02 PM
  • notallbad
    TCL 55RP620K power board issue
    by notallbad
    Originally the tv arrived with dimmed backlights (not failed leds) but everything else worked ok. Adjusting backlight in menu did nothing but voltage changed on dimming control pins,
    0% p_dim at 1.65v and a_dim at 1v
    50% p_dim at 3.3v and a_dim at 1.65v
    100% p_dim at 3.3v and a_dim at 2.88v
    Changed backlight leds anyway as always like to have complete peace of mind they wont fail shortly after selling the tv. No change as expected!
    Leds are 2 rows of 15 6v leds.
    On inspection of the power board found diode MBR3200 shorted so replaced with...
    07-12-2025, 05:45 AM
