hanns g hh251 not recognizing input
  • younat
    • Jan 2015
    • 7
    Hello!
    I recently acquired an LCD panel that the lab next door was throwing away. The only historical information I had was a post-it note with the word "Broken" on it. I took it home and powered it up. The green light comes on, a message saying "No input detected" appears on the panel for a few seconds, and it goes straight to standby with the power light turning amber. I tested the vga input with a few computers. The display is recognized by the computers, so I figured the logic board is ok.
    I proceeded to take it apart and test the main capacitor (161 V) and the DC outputs (5.2 V as spec and 12 V as spec when the power light is green). The diodes, 12 V regulator, and fuses all appear to be in good shape as well from multimeter measurements. There are no bulging caps, but I don't have an ESR meter so I wanted to have a good reason before I desoldered all the caps.
    I feel like I've given the power supply a good testing based on what I've read on this forum. Are my symptoms indicative of a bad component on the logic board? Despite my searching I haven't found a post with the same symptoms.
    Any help is greatly appreciated. Thanks!
  • angel-boy
    • 550
    • Romania
    Re: hanns g hh251 not recognizing input
    This model has been discussed, but different problems
    https://www.badcaps.net/forum/showthread.php?t=25295
    https://www.badcaps.net/forum/showthread.php?t=34009
    I hope I was helpful
    • selldoor
      Slow Learner
      • 7870
      You checked the fuse/s on the back of the power supply.?
      Next things to check would be inverter transformers, bulbs, 2 mosfets on the back that drive the inverters.
      You should post pictures of both sides of your boards then we would know what we are dealing with
      • younat
        • Jan 2015
        • 7
        Thanks for the help! I did take a look at those other posts, angel-boy, but didn't seem to have the same issues as described. Here are the pictures of the PSU and logic board. I did some more probing and found a diode on the back of the PSU that appears to be shorted according to my multimeter (there is a red arrow pointing at it). Could that really be the issue that sends the LCD to standby? All the fuses I could find on both boards seem fine.
        • Rtech
          • Jul 2010
          • 1095
          At the moment, it is still not certain which PCB is faulty, it looks like either the Logic OR the Power Supply.I would determine that,by removing the logic board, plug the lamps into the PSU,fit a 1KΩ resistor between the 5v pin and the on/off pin on the connector,this simulates the voltage you would normally get from the Logic when all is working well.Then apply the AC mains as normal.If the lamps light and stay on then the fault would point to the Logic PCB.If the lamps do not work, then the PSU needs fault finding.
          • younat
            • Jan 2015
            • 7
            That is a great idea! I'll give that a try tonight and let you know what I find.
            • younat
              • Jan 2015
              • 7
              Ok, so I tried what Rtech suggested. I put a 1k resistor between the 5.2V and O/F pins (I also tried putting PSON high, but that didn't do anything that I could see). I heard a slight, regular clicking and the backlight flashes with the clicking sound. When I removed the resistor, the clicking sound remained, but the backlight didn't flash. The 5.2V stays constant for all of this, but the voltage on the input of the 12V regular fluctuates between 5-7V when the resistor is connected and 9-11.5V when the resistor is not connected. Somehow the backlight circuit is pulling this down.
              When I plug the logic board in, the backlight behaves as before. 2 seconds on, then straight to standby. There is no clicking at all when the logic board is connected. So this means that the PSU is likely the problem, right? Any ideas? I'm going to replace the burned out diode that I labeled in the uploaded pictures and try again.
              Thanks for the suggestions! I feel like I'm learning a lot.
              • younat
                • Jan 2015
                • 7
                I replaced the diode that I thought was shorted, but the good one appears shorted once it is soldered in the circuit as well... I can't think of any useful circuit where a diode would be shorted in both directions, but I'm not too experienced in electronics.
                I may have to amend my previous post. The clicking and flashing backlight now only occurs when the resistor is holding the backlight control high. The clicking goes away when the resistor holds PSON high. The 12V is stable and reading what it should when the PSON is high. So it appears that I've narrowed it down to something with the backlight circuitry. Does that make sense to you guys?
                  "The green light comes on, a message saying "No input detected" appears on the panel for a few seconds, and it goes straight to standby with the power light turning amber. I tested the vga input with a few computers. The display is recognized by the computers, so I figured the logic board is ok." This means the main board of the monitor did not detect the Video signals from the computer (but the computer does see the signal on the ID pin of the VGA connector) so it goes into stand mode (amber LED). Unless I am wrong, the LED should stay green when it detects the Video, did it do that before it goes into standby? Otherwise you may have power supply or inverter circuit problem.
                  You need to check VGA connector pins for the H sync, V sync pin, and also the R, G, and B pins to see if any one of them shows very low resistance (due to bad protection diode on each one of those pins), most monitor detect the G signal pin to see if it is present or not. If you look real close around the VGA connector, you will see lots of Diodes in that area. The VGA port could have been zapped with static discharge.
                  BTW, yes, they do put diode in parallel with the resistor in certain circuits, that is why you always test the component off the board when you suspect the component is bad.
                  See attached PDF and pictures of typical circuits setup.
                  "The 5.2V stays constant for all of this, but the voltage on the input of the 12V regular fluctuates between 5-7V when the resistor is connected and 9-11.5V when the resistor is not connected. Somehow the backlight circuit is pulling this down." This pulling down of the Voltage by the inverter circuit or the 12V power supply section is weak (bad filter caps). I would check those two 8-pin power MOSFET S and D pin to see if it shows low resistance. The current draw that caused the 12V to drop may have cause the 5V to drop just fast enough to reset the circuit on the main board but your meter is not fast enough to detect.
                  You can remove the fuse F260 (next to jumper JP205) which feed the Voltage to the inverter circuits and see if the monitor still goes into standby mode, I would do this first to help narrow down the problem.
                  • Rtech
                    • Jul 2010
                    • 1095
                    Looks like you are getting somewhere now.BUDM has suggested some tests,lets see what happens ??
                    • younat
                      • Jan 2015
                      • 7
                      Well, I removed the fuse. The monitor still went to sleep with and without a computer plugged in. I checked the MOSFETs and the resistance between the source and drain is in the megaohms for all four. I tried testing the VGA port and saw that the R and G ports are open circuit to their respective R and G grounds. The B port looks ok (it reads 74.7 Ohms to B ground which seems to match the schematic budm posted). So it is probably a case of ESD. All the diodes seem to be ok though. I don't think I want to go to the effort of troubleshooting the logic board anymore. I'm going to order an HDMI cable and with any luck one of the ports will work. As it stands now, the wife wants the dining room table back, so it looks like this project is closed.
                      Thanks for all the help! Although I didn't solve the problem, I learned a lot in the process which is well worth it.
                      • ugamazing
                        820-02020 Super Weird Issue: Keyboard Input Character Map "Wrong"?
                        by ugamazing
                        So, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
                        1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
                        2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not...
                        04-10-2024, 08:06 AM
                        Texas Instruments bq24745 bq24745RHDR bq24745RHDT Battery Charger IC for Laptop Computers Datasheet
                        The bq24745 bq24745RHDR bq24745RHDT is a high-efficiency, synchronous battery charger with an integrated input-current comparator, offering low component count for space-constrained, multi-chemistry battery-charging applications. The input-current, charge-current, and charge-voltage DACs allow very high regulation accuracies that can be easily programmed by the system power-management microcontroller using the SMBus interface. The bq24745 charges two, three, or four series Li+ cells, and is available in a 28-pin, 5-mm x 5 mm QFN package.
                        The bq24745 features dynamic power management...
                        10-23-2024, 02:50 AM
                      • Tarot Superstars
                        Add Stereo Input To Hi-Fi (Sony SONY PMC 107L)
                        by Tarot Superstars
                        Hi.
                        I bought a Cheap HIFI to use as my PC output and speakers and forgot to check if it had an input. It doesn't.
                        Is there any way to add a stereo input. I have a bunch of Phono sockets I am not using.
                        Where in the circuit is the best place to solder the 3 stereo input wires?
                        This is the model and schematics:
                        https://www.manualslib.com/manual/91...7l.html#manual
                        10-31-2023, 03:23 AM
                      • redbaron1007
                        Crua CR270C shorted input.
                        by redbaron1007
                        I've got a Crua CR270C that had a short to ground on the input jack. The input was rated at 12v 4A center pin positive. When I took the board out and powered it with my bench power supply it jumped to 3v and 4A CC and a chip labeled either TM3db2 or TV3db2. I'm not able to find anything online typing in those strings of letters and numbers and searching websites like s-manuals hasn't yielded anything. It is an sot23-6 package type according to my digikey ruler and I was able to work out some of the pinout from voltages on the board and following the traces around. I'm not really sure what a suitable...
                        03-12-2025, 02:10 PM
                        ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
                        Highly Integrated Narrow VDC Battery Charger for Notebook Computers
                        The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
                        for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
                        Narrow VDC applications where the system power source is
                        either the battery pack or the regulated output of the charger.
                        This makes the max voltage to the system equal to the max
                        battery voltage instead of the max adapter voltage. Operating
                        at lower system voltage can improve...
                        11-05-2024, 04:43 PM
