Re: Problems with Samsung 740N monitors
You found the little green fuse under the the left hand side halfway down under the glue between the heatsink and the capacitor.? If it is back in the set what is the voltage on each side with respect to a ground screw. If it is out of the set can we have a picture of the back. Also can you test the secondary windings on the inverter transformers.
Meter on Ohms 2000 give answer in Ohms
