I am having a strange issue with two computers on a network. The network has up to four computers connected to it, but only these two have any issues. One of these computers runs Windows 7 Home Premium and the other computer runs Windows XP Home. On these two computers, I have to click on links in Web pages multiple times before they open. This only occurs rarely on the computer running Windows XP and occurs almost every time someone attempts to open a link on the computer running Windows 7. The link will usually open on the second click, but the computer running Windows 7 sometimes requires a link to be clicked three times before it will open. When links do not open, the browser's loading animation plays and the status stays at "Connecting" until the connection times out. Restarting the browser helps for a few minutes and reinstalling Windows eliminates the problem for a few hours, but it still comes back. What is going on?
Poor Internet connection
Re: Poor Internet connection
For things like this, I like to open a dos window and send a continuous ping like
ping -t 208.67.222.222
The above is the DNS server over at opendns.com
If the pings come back continuously, then you know it is likely not a network problem.
If you really want to see what is going on, then download something like wireshark
http://en.wikipedia.org/wiki/Wireshark
and see why your http sessions are hanging.
I like to capture a "good" http session so I have a reference for later on.--- begin sig file ---
--- end sig file ---
Originally posted by shovenose View PostAre you on AT&T?
Switch to Comcast :P
That's my plan
anyway sounds like you may have a virus. For this i would ensure your system is clean before troubleshooting further, save you some time and assurance down the troubleshooting road.
my favs:
combofix
malware bytes
for the pesky google/search redirect, use above then use:
mbrcheck
tdsskiller (kaspersky) and/or the one from symantec tdssfix i think its called.
by any chance is norton 360 or internet security installed on either. OR any toolbars from antivirus? do you have antivirus?
oh also i would def. check the connection, exactly as retiredcaps describes.
I have a feeling your connection is fine since you have other computers working just fine. but bad cables do happen.Last edited by mattch; 06-13-2012, 09:59 AM.
Can be many things, apart from the things already mentioned it could be some MTU size problem if you use pppoe or similar over dsl. That can behave a bit odd at times.
Could be something with broken/corrupted arp tables in your router, try rebooting the router if you havnt already.
Let us know what you come up with from all the posts so we can suggest more things to check.
That's my plan
Originally posted by mattch View Postby any chance is norton 360 or internet security installed on either. OR any toolbars from antivirus? do you have antivirus?
The computer running Windows 7 is using a wireless connection, but the same problem exists with a wired connection using a known good cable. One of the computers that works properly is also using the wireless connection.
Originally posted by shovenose View PostWhat's odd in your case is that some compters go online just fine.
What software is different on the computers...
Originally posted by mattch View Postanyway sounds like you may have a virus. For this i would ensure your system is clean before troubleshooting further, save you some time and assurance down the troubleshooting road.
my favs:
combofix
malware bytes
mbrcheck
tdsskiller (kaspersky) and/or the one from symantec tdssfix i think its called.Last edited by lti; 06-13-2012, 06:03 PM.
I don't think that it is a matter that concerns your computer hardware at all. Your best bet is to monitor how the network activity is keeping up as that could pretty much spring a lot of stuff to run at the background even without the user fully gaining knowledge over it and what is being utilized. You just have to be really familiar and versed with it. Hope this helps.
Just set up temporarily a router/switch with management and block his connection from the router.
When he notices he has no internet, you can just say the viruses on his computer finally killed his operating system and he'll suddenly find the time for a reinstall.
Actually, you could just go on and rename some system files in the root of c:\ and you won't have to bother with extra hardware.
Or... how about you print some fake warning letters as if they come from the ISP in which they say if he won't clean the computers his internet connection will be terminated? Maybe that will change his mind..
Or, when he's not home/sleeping/whatever pull out the drive, mount the drive in another system and do as best as you can to clean it.
I had a simalar issue but I didn't know the second device had the same issue. It turned out the second device was using dhcp and when my pc was off and the second device conected it took my static ip. This was solved by moving the dhcp pool start address out of the range of all the pc's with static ip's.
I always wondered why it was said that it was bad pratice to have both on the same network.My pc
CPU : AMD PHENOM II x4 @ 3.5Ghz
MB : ASUS M4A89TD PRO USB3
RAM : Kingston ValueRAM 16gb DDR3
PSU : Cooler Master 850W Silent Pro
GPU : ATI Radeon HD 6850
